I am using Omniverse for Linux (I have Ubuntu) and I could not launch Create from the Launcher as it would remain idle in the splash screen forever.
Log: log_from_launcher.log (7.8 MB)
Then, after looking for similar issues in the forum, I might have found out that it was because of a conflicting non-RTX GPU (I have in fact 2 GPUs: [0] Quadro P6000 and [1] TITAN RTX). Therefore I tried to launch the singleGPU version from the installation folder (omni.create.singlegpu.sh). This time Create started up correctly but for some reason it only detected the Quadro P6000 GPU, instead of the RTX GPU, therefore making it impossible to use cause not supported
Log: log_from_singleGPU.log (408.0 KB)
Is there a way to tell Ominverse Create to use the GPU with ID 1 (TITAN RTX) instead of the Quadro?
I also attach here the nvidia-smi information: gpu.txt (1.2 KB)
Thank you so much for your help.
Lorenzo
