I know the system spec says i7 as the base processor, but really no Xeon workstation support or am I missing something? I’ve installed Omniverse Create but get a heap of errors and no viewport display.
Does anyone have any ideas?
RTX 2080 Ti x2
E5-2667 v3 x 2
130 GB
Window 10 pro
@Wildfire_Studios -
Can you tell me the driver versions for the 2080’s ?
And do you perhaps have another card too (like something other than the Nvidia cards you stated)
Dan -
Not exactly sure what is wrong. Need to look into this. But can you try the following
without Create running
remove folder at location below. Use your user name instead of colossus. Delete the entire folder. May not be named 528-xxxxxx , just delete whatever it at that location.
I did that and we are still getting a heap of errors. (Log file attached)
So far I have tried:
Removing one of the RTX cards
Reinstallng Nvidia Studio drivers
Deleting the files as you suggested
Uninstalling and re-installing Ominiverse launcher and Omniverse Create
Then I had a cup of coffee and scratched my head (this did not work either)
Hey - yes I took it out of the case. To be scientific I guess I should have swapped out one and then the other seeing as they are slightly different hardware revision versions. I’ll do that on Monday generate a log file for each one to send to you.
Okay - I made a little white lie before and only disconnected the power to one of the cards - but this time I took them out one by one and the log files are attached, then I put them both in and ran it again or a reference log file (attached)
The outcome is that on the single cards it ran perfectly on both of them.
With the dual set-up, it will not work.
So I’m guessing that what in theory is a benefit of having two 2080ti cards is actually a handicap in Omniverse.
The Dual Card setup works with all the other programs I use and primarily for Redshift for Cinema 4D - they work great.
It’s a shame I can’t experiment with Omniverse, but it’s not the end of the world and I realise it is only experimental at the moment so not every system can be accommodated. kit_20210427_165728(single card).log (139.5 KB) kit_20210427_170621(single card).log (137.5 KB) kit_20210427_173242(dual).log (165.5 KB)
One thought - would it be worth me buying an NVLink Bridge to get them to talk to each other?
@Wildfire_Studios -
Still working on the dual 2080 issue. Will file a case.
But if you want to try OMNI with both cards in your system. We can use an option to only select one of them. This might allow you to continue with Omniverse without having to remove a card.
Based on that log, can you try deleting C:/Users/Z840/AppData/Local/ov/cache/Kit/100.3/528-c8003e0d-release and see if that lets you use both your cards in Create?
Thanks! Based on this log and the single GPU one, it looks like you updated Windows in the meantime. Is it possible to also attach a current log (from today) of the working single-GPU mode?
No problem - here is a log from a working single GPU run just a min ago. If things look slow in the logs it’s because I have a Redshift render going on in the background. But even with that going on the single card method worked fine.
