nvidia-smi
Fri Sep 10 15:37:11 2021
| NVIDIA-SMI 470.63.01 Driver Version: 470.63.01 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA TITAN RTX Off | 00000000:17:00.0 Off | N/A |
| 41% 33C P8 14W / 280W | 1MiB / 24220MiB | 0% Default |
| | | N/A |
| 1 Quadro GV100 Off | 00000000:73:00.0 Off | Off |
| 34% 47C P2 26W / 250W | 214MiB / 32507MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 1 N/A N/A 22063 G /usr/bin/X 183MiB |
| 1 N/A N/A 22125 G /usr/bin/gnome-shell 28MiB |
Both cards are shown (gv100 is default card / connected to monitor), however if nvidia-settings is ran the user can see the order get flops (TITAN RTX becomes gpu 1 and gv100 gpu 0)
Omniverse will successfully launch with the following cmd:
./omniverse-launcher-linux.AppImage --no-sandbox (also tried with --no-windows flag)
Once omniverse loads and the user selects Create, the program begins to load then eventually produces the following error codes:
2021-09-10 19:06:41 [15,828ms] [Error] [carb.python] RTX engine creation failed. RTX renderers in viewport will be disabled. Please make sure selected GPU is RTX-capable, and GPU drivers meet requirements.
2021-09-10 19:06:42 [15,870ms] [Error] [carb.python] Available GPUs are not supported. List of available GPUs:
[‘Quadro GV100’]
Has anyone encountered anything similar to this?
Thanks and any ideas are very much appreciated!
