Not sure if this is the right place to post this (did not find a support forum) but im having trouble initializing the RTX engine. Which is odd as my card should support RTX. Getting two errors (see image). Ive tried running create on a single GPU which was a solution in another thread. Any other options?
specs:
windows 10
Geforce 1070 TI
Intel(R) Core™ i7-9700K CPU @ 3.60GHz 3.60 GHz
16 GB Ram
Hello @UnbreakablePocky! Accorinding to the error message, it indicates that you are using a GTX 1070 Ti. This GPU lacks the Ray Tracing Tensor Cores and VRAM required to run Omniverse. You can check out our Technical Requirements to see what GPU is needed to run Omniverse.
I’d like to inform you that we are working on a Cloud version of Omniverse which will allow instant Access NVIDIA Omniverse from any device, anywhere. You can find out more information on this here: Omniverse Cloud Platform | NVIDIA
