Hi all,
I am encoutering some troubles while trying to launch Omniverse Create.
I have a P4000 gpu, does it work or is it not supported?
Driver is 526.67 version.
On startup it tells forever “RTX Loading” in the viewport and nothing happens.
Console reports:
Basically it says that it cannot find an RTX GPU, nor does it support RayTracing; but being a Quadro series I guess it should be supported.
Anyone that knows the reason?
Hello @andrea18! Unfortunately, the P4000 GPU does not have the required Ray Tracing Tensor cores. Most of our apps require, at minimum, an RTX 3070 which has 46 RT Cores. You can take a look at our Technical Requirements for more information.
You may be interested in Omniverse Cloud which allows you to access Omniverse anywhere from any device.
