I have an RTX 8000 and installed 472.84 (WIN) and still got an error message saying that is not Compatible with Omniverse. What driver should I install for omniverse?
Regards
Jerry
Regards
Jerry
Hello @jerry.runheim! I am sorry to inform you, but our Quadro RTX 8000 GPUs do not have the compatible tensor cores that are required for rendering in Omniverse.
You can view our minimum required GPUs here: Technical Requirements — Omniverse Create documentation
Hi, @WendyGram Thank you for your answer. I am actually rendering with this card and it seems to work fine, except that I don’t see the play bar, and when choosing a geometry it is not highlighted. I have another Quadro 5000 RTX with Max Q design the same error message comes up with this card? I checked the specs and a 5000 RTX is ok, if not the max Q design is making the error? The same driver as above / windows. Regards Jerry
Hi @jerry.runheim. I will ask the dev team for confirmation! A copy of your log files may help here. If you are able, can you attach them to this post?
C:\Users\<USERNAME>\.nvidia-omniverse\logs
Hi @jerry.runheim! The dev team suggest that you try our latest Quadro driver and see if that fixes the issue. Please let me know!
https://www.nvidia.com/Download/driverResults.aspx/184785/en-us
I am having the same issue. I have an RTX A5000 24GB, which according to your tech specs should be fine. What can be done to remove the compatibility message?
Same same here @WendyGram
Alrighty Gang! I appreciate the information you provided and I have sent it to our development team to take a look. I will bounce back when I hear more!
I have the same issue. Thank your @WendyGram
I am having the same problem. 3080 GPU. Driver version 511
When can we expect this to be resolved?
Hello Everyone. I have escalated this issue with the dev team for help. I am hoping to hear back shortly!
Hi everyone, is anyone able to attach the complete .log file that WendyGram pointed out above?
Without the log file, we can’t determine what potential system setup issue you might have.
Thanks for your patience.
Hi @nnikfetrat see attachment kit_20211219_114704.log (429.1 KB) I hope this helps. All the best J
logs.txt (49.7 KB)
It would be nice to see this resolved.
hello @jerry.runheim and @Digitallywired -
I would like to ask a question on your issue. When you state that the you are having issues with driver compatibility, are you referring to the message you see (with green arrow) in the following display?
Is there any actual problem with using one of the applications? Like Create/View, or is it simply that this message is displayed in the Launcher
Yep! That’s the message. I don’t know? Is it? I am using an RTX 8000 and one RTX 5000. I haven’t noticed anything out of renderings. Except for VDB…That one is giving a strange and inconsistent result.
