hi,我正在使用PC ubuntu18.04编译JetPack6.1系统镜像,执行 ./apply_binaries.sh命令时报错如下。
jiangyinghao@mogo:~/work/JP61/Linux_for_Tegra$ sudo ./apply_binaries.sh
Using rootfs directory of: /home/jiangyinghao/work/JP61/Linux_for_Tegra/rootfs
Installing extlinux.conf into /boot/extlinux in target rootfs
/home/jiangyinghao/work/JP61/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
Root file system directory is /home/jiangyinghao/work/JP61/Linux_for_Tegra/rootfs
Copying public debian packages to rootfs
Skipping installation of nvidia-igx-oem-config_36.4.0-20240912212859_arm64.deb ....
Skipping installation of nvidia-igx-systemd-reboot-hooks_36.4.0-20240912212859_arm64.deb ....
Skipping installation of nvidia-l4t-dgpu-apt-source_36.4.0-20240912212859_arm64.deb ....
Skipping installation of nvidia-l4t-dgpu-config_36.4.0-20240912212859_arm64.deb ....
Skipping installation of nvidia-l4t-dgpu-tools_36.4.0-20240912212859_arm64.deb ....
Skipping installation of nvidia-l4t-dgpu-x11_36.4.0-20240912212859_arm64.deb ....
Skipping installation of nvidia-l4t-factory-service_36.4.0-20240912212859_arm64.deb ....
Skipping installation of nvidia-igx-bootloader_36.4.0-20240912212859_arm64.deb ....
Skipping installation of nvidia-l4t-jetson-orin-nano-qspi-updater_36.4.0-20240912212859_arm64.deb ....
Start L4T BSP package installation
QEMU binary is not available, looking for QEMU from host system
Found /usr/bin/qemu-aarch64-static
Installing QEMU binary in rootfs
~/work/JP61/Linux_for_Tegra/rootfs ~/work/JP61/Linux_for_Tegra
Host qemu-aarch64-static version: 2.11.1(Debian
dpkg: warning: version '2.11.1(Debian' has bad syntax: invalid character in version number
Installing BSP Debian packages in /home/jiangyinghao/work/JP61/Linux_for_Tegra/rootfs
qemu: Unsupported syscall: 293
Selecting previously unselected package nvidia-l4t-core.
(Reading database ... 166870 files and directories currently installed.)
Preparing to unpack .../nvidia-l4t-core_36.4.0-20240912212859_arm64.deb ...
Pre-installing... skip compatibility checking.
Unpacking nvidia-l4t-core (36.4.0-20240912212859) ...
Setting up nvidia-l4t-core (36.4.0-20240912212859) ...
Processing triggers for libc-bin (2.35-0ubuntu3.8) ...
qemu: uncaught target signal 11 (Segmentation fault) - core dumped
Segmentation fault
Segmentation fault
dpkg: error processing package libc-bin (--install):
installed libc-bin package post-installation script subprocess returned error exit status 139
Errors were encountered while processing:
libc-bin
请问JetPack6.1对PC ubuntu版本有要求吗?
