Jetson AGX Orin install jetpack 6.1 failed
Hi there,
I just got a jetson AGX Orin, and I found that it’s pre-installed with R35.4.1 i.e. JetPack 5.
In this case, I would like to install JetPack 6.1 via SDKManager hosted on my desktop with ubuntu 22.04.
I have checked the guide for AGX Orin toolkit have tried both normal mode and recovery mode they both failed with promts below:
22:36:42 ERROR: W: Target Packages (stable/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target Translations (stable/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target Translations (stable/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target Translations (stable/i18n/Translation-en_US.UTF-8) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target Translations (stable/i18n/Translation-zh_CN) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target DEP-11 (stable/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target DEP-11 (stable/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target DEP-11-icons-small (stable/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target DEP-11-icons (stable/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target DEP-11-icons-hidpi (stable/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target CNF (stable/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: Target CNF (stable/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 ERROR: W: https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/amd64/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
22:36:42 ERROR: W: Target CNF (stable/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/archive_uri-https_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1
22:36:42 ERROR: W: Target Packages (stable/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_mirrors_aliyun_com_docker-ce_linux_ubuntu-jammy.list:1 and /etc/apt/sources.list.d/docker.list:1
22:36:42 INFO: Reading package lists…
22:36:42 INFO: Building dependency tree…
22:36:43 INFO: dpkg --configure or the configure menu option in dselect:
22:36:43 INFO: initramfs-tools generic modular initramfs generator (automation)
22:36:43 INFO: command finished successfully
22:36:43 INFO: Install pre check APT repository access for Debian package installation(host). verify succeed.
22:36:43 DEBUG: running command < true >
22:36:43 INFO: exec_command: true
22:36:43 ERROR: shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
22:37:37 INFO: Drivers for Jetson - target_image: libglusterfs0 libibverbs1 libiscsi7 libndctl6 libpmem1 libpmemobj1
22:37:37 INFO: Drivers for Jetson - target_image: libqrencode4 librados2 librbd1 librdmacm1 libsdl2-2.0-0 libspice-server1
22:37:37 INFO: Drivers for Jetson - target_image: liburing2 libusbredirparser1 libvirglrenderer1 msr-tools ovmf pass
22:37:47 INFO: Drivers for Jetson - target_image: will sleep 30 seconds before next attempt
22:38:17 INFO: Drivers for Jetson - target_image: Reading package lists…
22:38:18 INFO: Drivers for Jetson - target_image: Building dependency tree…
22:38:18 INFO: Drivers for Jetson - target_image: Reading state information…
22:38:18 INFO: Drivers for Jetson - target_image: lbzip2 is already the newest version (2.5-2.3).
22:38:18 INFO: Drivers for Jetson - target_image: The following packages were automatically installed and are no longer required:
22:38:18 INFO: Drivers for Jetson - target_image: cpu-checker ibverbs-providers ipxe-qemu ipxe-qemu-256k-compat-efi-roms
22:38:18 INFO: Drivers for Jetson - target_image: libaio1 libboost-iostreams1.74.0 libboost-thread1.74.0 libcacard0 libdaxctl1
22:38:18 INFO: Drivers for Jetson - target_image: libdecor-0-0 libdecor-0-plugin-1-cairo libgfapi0 libgfrpc0 libgfxdr0
22:38:18 INFO: Drivers for Jetson - target_image: libglusterfs0 libibverbs1 libiscsi7 libndctl6 libpmem1 libpmemobj1
22:38:18 INFO: Drivers for Jetson - target_image: libqrencode4 librados2 librbd1 librdmacm1 libsdl2-2.0-0 libspice-server1
22:38:18 INFO: Drivers for Jetson - target_image: liburing2 libusbredirparser1 libvirglrenderer1 msr-tools ovmf pass
22:38:18 INFO: Drivers for Jetson - target_image: qemu-block-extra qemu-system-common qemu-system-data qemu-system-gui
22:38:18 INFO: Drivers for Jetson - target_image: 1 not fully installed or removed.
22:38:18 INFO: Drivers for Jetson - target_image: After this operation, 0 B of additional disk space will be used.
22:38:18 INFO: Drivers for Jetson - target_image: Setting up initramfs-tools (0.140ubuntu13.4) …
22:38:18 INFO: Drivers for Jetson - target_image: update-initramfs: deferring update (trigger activated)
22:38:18 INFO: Drivers for Jetson - target_image: Processing triggers for initramfs-tools (0.140ubuntu13.4) …
22:38:18 INFO: Drivers for Jetson - target_image: update-initramfs: Generating /boot/initrd.img-6.8.0-48-generic
22:38:23 INFO: Drivers for Jetson - target_image: I: The initramfs will attempt to resume from /dev/nvme0n1p3
22:38:23 INFO: Drivers for Jetson - target_image: I: (UUID=1e88a569-2a13-4480-819a-7d96cacc0854)
22:38:23 INFO: Drivers for Jetson - target_image: I: Set the RESUME variable to override this.
> 22:38:27 INFO: Drivers for Jetson - target_image: zstd: error 25 : Write error : No space left on device (cannot write compressed block)
22:38:27 ERROR: Drivers for Jetson - target_image: E: mkinitramfs failure zstd -q -1 -T0 25
22:38:27 INFO: Drivers for Jetson - target_image: update-initramfs: failed for /boot/initrd.img-6.8.0-48-generic with 1.
22:38:27 ERROR: Drivers for Jetson - target_image: dpkg: error processing package initramfs-tools (–configure):
22:38:27 INFO: Drivers for Jetson - target_image: installed initramfs-tools package post-installation script subprocess returned error exit status 1
22:38:27 INFO: Drivers for Jetson - target_image: Errors were encountered while processing:
22:38:27 INFO: Drivers for Jetson - target_image: initramfs-tools
22:38:29 ERROR: Drivers for Jetson - target_image: E: Sub-process /usr/bin/dpkg returned an error code (1)
22:38:29 ERROR: Drivers for Jetson - target_image: Unhandled error when running sudo apt-get install -y lbzip2: E: Sub-process /usr/bin/dpkg returned an error code (1);
22:38:29 ERROR: Drivers for Jetson - target_image: [exec_command]: /bin/bash -c /home/cc/.nvsdkm/replays/scripts/JetPack_6.1_Linux/NV_L4T_DRIVERS_COMP.sh; [error]: Unhandled error when running sudo apt-get install -y lbzip2: E: Sub-process /usr/bin/dpkg returned an error code (1);
22:38:29 INFO: Drivers for Jetson - target_image: [ Package PreInstall Finished with Error ]
22:38:29 INFO: Drivers for Jetson - target_image: [host] [ 7.89 MB used. Disk Avail on Partition /dev/sda3: 195.54 GB ]
22:38:29 INFO: Drivers for Jetson - target_image: [ NV_L4T_DRIVERS_COMP Install took 1m45s ]
22:38:29 ERROR: command error code: 11
22:38:29 ERROR: Drivers for Jetson - target_image: command terminated with error
22:38:29 SUMMARY: Drivers for Jetson - target_image: First Error: Installation failed.
Seems that the installation of drivers for jetson failed due to no space left? then all following installation failed.
Any ideas? Should I remove the linux image of AGX Orin first and reinstall an image and jetpack? Actually I have added a SSD for AGX Orin, but the HW installation path is fixed to /home/usrname/nvidia/nvidia_sdk
Please EXPORT LOGS for more information as shown in the image.
Hi David,
I have solved this problem. It turns out that the host machine does not has enough storage to handle the file during flash, my bad:(.
Thank you very much for your reply!
