Jetpack 2.2.1 and L4T R21.5 for Jetson TK1
NVIDIA’s released the latest update for TK1, Jetpack 2.2.1.
Package contents include:
o L4T 21.5
o CUDA 6.5.53
o cuDNN v2.0
o OpenCV4Tegra 2.4.13
o VisionWorks 1.4
Release Notes http://developer.nvidia.com/embedded/dlc/l4t-Jetson-TK1-Driver-Package-Release-Notes-R21-5
JetPack https://developer.nvidia.com/embedded/jetpack
L4T R21.5 https://developer.nvidia.com/linux-tegra-r215
Software Overview https://developer.nvidia.com/embedded/develop/software
Archive Page https://developer.nvidia.com/embedded/linux-tegra-archive
Embedded DLC https://developer.nvidia.com/embedded/downloads
Production Image https://developer.nvidia.com/embedded/develop/production
To get started, download JetPack to an x86_64 Linux machine used for flashing and select ‘Jetson TK1’ after starting JetPack.
This release includes an updated CPU clock maximum frequency to meet 5-year lifetime guarantees.
Depending on operating use-case, please refer to the Release Notes above or the Tegra K1 Datasheet for more information.
Hello Dusty,
One little thing that nearly caught me out, the download link on https://developer.nvidia.com/embedded/jetpack currently still links to Jetpack 2.2, not 2.2.1. If others are looking it can be downloaded from here: https://developer.nvidia.com/embedded/dlc/jetpack-l4t-2_2_1.
There’s support for Ubuntu 16.04 as a host! Congrats on making the jump to a shiny new LTS.
Are there any specific updates on CSI firmware or tegra_camera changes? I’ve got issues with CSI which is working fine in previous R21.4:
https://devtalk.nvidia.com/default/topic/953732/jetson-tk1/tegra-k1-with-mipi-csi-4-lanes-device-issues-in-r21-5/post/4941285/#4941285
Does the version of OpenCV4Tegra included in this release of JetPack fix all the compatibility issues with ROS that existed in previous versions? I was able to install ros-indigo-desktop correctly and use rqt_logger_level (which did not work on OpenCV4Tegra 2.4.10 which I previously had installed) but I’m wondering if the problems mentioned on http://wiki.ros.org/NvidiaJetsonTK1 such as the cv_bridge linking problem have been resolved (or if the “hack” mentioned on that page still needs to be performed).
UPDATE: For anyone interested, I did some testing of my own and the linking problems with cv_bridge and image_geometry are still present, but the fix available at http://myzharbot.robot-home.it/blog/software/ros-nvidia-jetson-tx1-jetson-tk1-opencv-ultimate-guide/ took care of it for me. I’m happy to finally be at a point where I can use OpenCV in ROS on the Jetson TK1 without any problems (at least, problems that I know about!).
Glad to have been helpful for you ^_^
Walter
Doing an upgrade killed my working nVIDIA TK1. I tried from Jet PACK 1 to 3 and nothing seems to work. It falshes and then when we reboot the system, LED is on for few seconds (fan running) and then goes OFF making system presumably shutdown.
Any idea as to what could be problem?
Basically you’d need to attach a serial console to see what’s going on (settings 115200 8N1, CTS/DTS flow control or software flow control).
One hardware check is to see if it can be put in recovery mode. If so, then the host will see the Jetson via “lsusb -d 0955:772”. If this works, and if it can remain on, then chances are it is not a hardware problem. If this can’t succeed, then it is a hardware issue.
If it turns out lsusb succeeds and the unit can remain on, then you could clone the eMMC to extend the hardware testing. Being able to clone would almost certainly mean hardware is fully functional. If lsusb works, then clone information is here:
http://elinux.org/Jetson/Cloning
Where can I find informations about the licenses of these products, especially OpenCV4Tegra ?
Thank you.
Hello, the licenses are provided by JetPack after the installation begins.
Greetings to all, I’ve been gone a while…
head -n 1 /etc/nv_tegra_release
shows “# R21 (release), REVISION: 3.0, GCID: 5091063, BOARD: ardbeg, EABI: hard, DATE: Tue Feb 3 02:03:23 UTC 2015”
I’m at L4T 21.3.
Is there any particular reason for me to go to the trouble of upgrading to 21.5?
Additionally: are there any signs that the TK1 will ever have any new upgrades released?
For example, will there ever be a release to a 4.x.x kernel, and/or Ubuntu 16.04 or higher?
I can’t be specific, but I do perceive R21.5 as being more reliable and probably worthwhile.
Is there an actual changelog between L4T 21.4 and 21.5?
What changed besides the new maximum CPU frequency?
