I’ve been digging around the Jetpack 4.1 preview version, and it turns out that the included L4T flash utility does support the TX2, by running
sudo ./flash.sh jetson-tx2 mmcblk0p1
This produced a working ubuntu 18.04 environment.
Furthermore, I’ve downloaded the Cuda, Cudnn and TensorRt .deb files to the TX2 and installed them there, and they seem to be working as well: I’ve succesfully run the included cuda and tensorrt samples.
@eric.creusen
Where did you get the .deb files for Cuda, Cudnn and TensorRt? I see some in the JetPack downloads folder after running JetPack 4.1, up to the ‘install on target’ (I don’t have an xavier). Did you just move those to the TX2 after running flash.sh?
Thank you for your help
