Hi All,
i recently bought a Jetson Nano and i 'd like to leverage its GPU features learning to use Tensorflow + TensorRT for a basis image classification Python model (i’m a begineer on all those stuff so i apologize in advance if i say nonsense! :) ).
I download the sd card image from official Nvidia page (Jet 4.4.1 for JetsonNano 4Gb)
I prepared a Dockerfile with the following instructions:
FROM nvcr.io/nvidia/l4t-base:r32.4.4
RUN apt-get update -y && DEBIAN_FRONTEND=noninteractive apt-get install -y gcc curl wget build-essential cmake \
pkg-config git zlib1g-dev libffi-dev libssl-dev ca-certificates apt-transport-https apt-utils unzip libjpeg-dev \
libfreetype6-dev libxml2 libopenjp2-7 libatlas-base-dev libgl1-mesa-glx libgtk2.0-0
RUN apt-get install -y python3-pip
Tensorflow installation
RUN apt-get install -y libhdf5-serial-dev hdf5-tools libhdf5-dev zlib1g-dev zip libjpeg8-dev liblapack-dev libblas-dev gfortran
RUN python3 -m pip install testresources setuptools==49.6.0 cython==0.29 numpy==1.16.1 future==0.18.2 mock==3.0.5
keras_preprocessing==1.1.1 futures protobuf pybind11
RUN python3 -m pip install h5py==2.10.0 keras_applications==1.0.8 termcolor==1.1.0 absl-py==0.7.0 six==1.12.0 \
grpcio==1.8.6 astunparse==1.6.3 wrapt==1.11.1 google-pasta==0.1.8 gast==0.3.3 opt-einsum==2.3.2 tensorboard==2.3.0
tensorflow-estimator==2.3.0
RUN pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v44 tensorflow
Tensorflow seems to work:
sudo docker run -it --rm --net=host --runtime=nvidia 88128a177626 bash
root@jetson-desktop:/# python3 -c “import tensorflow as tf; print(tf.test.is_gpu_available())”
2021-01-15 12:28:53.120944: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
WARNING: Logging before flag parsing goes to stderr.
W0115 12:28:59.815237 548049068048 deprecation.py:323] From :1: is_gpu_available (from tensorflow.python.framework.test_util) is deprecated and will be removed in a future version.
Instructions for updating:
Use tf.config.list_physical_devices('GPU')
instead.
2021-01-15 12:28:59.847165: W tensorflow/core/platform/profile_utils/cpu_utils.cc:108] Failed to find bogomips or clock in /proc/cpuinfo; cannot determine CPU frequency
2021-01-15 12:28:59.848116: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x2645b60 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2021-01-15 12:28:59.848220: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Host, Default Version
2021-01-15 12:28:59.884836: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcuda.so.1
2021-01-15 12:29:00.083276: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-15 12:29:00.083669: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x139bef0 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2021-01-15 12:29:00.083737: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): NVIDIA Tegra X1, Compute Capability 5.3
2021-01-15 12:29:00.109162: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-15 12:29:00.109384: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1742] Found device 0 with properties:
pciBusID: 0000:00:00.0 name: NVIDIA Tegra X1 computeCapability: 5.3
coreClock: 0.9216GHz coreCount: 1 deviceMemorySize: 3.86GiB deviceMemoryBandwidth: 194.55MiB/s
2021-01-15 12:29:00.109520: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-01-15 12:29:00.170782: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-01-15 12:29:00.230702: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2021-01-15 12:29:00.281430: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2021-01-15 12:29:00.399895: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10
2021-01-15 12:29:00.445063: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10
2021-01-15 12:29:00.457161: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-01-15 12:29:00.457467: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-15 12:29:00.457771: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-15 12:29:00.457911: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1884] Adding visible gpu devices: 0
2021-01-15 12:29:00.483444: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-01-15 12:29:05.481419: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1283] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-01-15 12:29:05.481581: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1289] 0
2021-01-15 12:29:05.481638: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1302] 0: N
2021-01-15 12:29:05.498906: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-15 12:29:05.499234: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-15 12:29:05.499502: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1428] Created TensorFlow device (/device:GPU:0 with 244 MB memory) -> physical GPU (device: 0, name: NVIDIA Tegra X1, pci bus id: 0000:00:00.0, compute capability: 5.3)
True
TensorRT seems to work:
root@jetson-desktop:/# python3 -c “import tensorrt as tf; print(tf.version)”
7.1.3.0
So i decided to try an interesting face recognition model (i cant push the link because i crossed the threshold of 3 links!), but i noticed that i got an issue on graphsurgeon module:
root@jetson-desktop:/# python3 -c ‘import graphsurgeon as gs; print(gs.version)’
2021-01-15 17:03:27.224315: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
File “”, line 1, in
File “/usr/lib/python3.6/dist-packages/graphsurgeon/init.py”, line 58, in
from graphsurgeon.node_manipulation import *
File “/usr/lib/python3.6/dist-packages/graphsurgeon/node_manipulation.py”, line 42
node.attr[“dtype”].type = 1
IndentationError: unexpected indent
My understanding is that the grapth surgeon should be a module of tensorRT that it’s a default module on the base docker image that i’m using --> nvcr.io/nvidia/l4t-base:r32.4.4
What am i doing wrong?
Could you please help me?
Thanks & Regards,
Dario
