I try use GS Streamer launch pipeline
with yolov8n model detect person.
if the camera disconnect the frame display black,
else open camera to display.
I look the gs version is 1.16.3
,and view the gs-streamer official options,
GStreamer 1.16 release notes
It’s have input-selector
this options
but can’t work.
I try theese command to reinstall gs-streamer:
sudo apt-get remove 'gstreamer*'
sudo apt-get autoremove
sudo apt-get install gstreamer1.0-tools gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly
But Display No such element or plugin 'input-selector'
ls /opt/nvidia/deepstream/deepstream/lib/gst-plugins
~/.bashrc:
Jetson info:
Software part of jetson-stats 4.2.12 - (c) 2024, Raffaello Bonghi
Model: Jetson AGX Orin - Jetpack 5.1.1 [L4T 35.3.1]
NV Power Mode[0]: MAXN
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
- Module: Check with sudo
Platform:
- Distribution: Ubuntu 20.04 focal
- Release: 5.10.104-tegra
jtop:
- Version: 4.2.12
- Service: Active
Libraries:
- CUDA: 11.4.315
- cuDNN: 8.6.0.166
- TensorRT: 8.5.2.2
- VPI: 2.2.7
- Vulkan: 1.3.204
- OpenCV: 4.10.0 - with CUDA: YES
gs-launch command:
gst-launch-1.0 \
nvstreammux width=1920 height=1080 batch-size=2 live-source=1 name=mux ! \
nvinfer config-file-path=config_infer_primary_yoloV8.txt ! \
nvtracker tracker-width=640 tracker-height=480 gpu-id=0 ll-config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so ! \
nvmultistreamtiler rows=2 columns=2 width=1920 height=1080 name=tiler ! \
nvdsosd ! \
nvvideoconvert ! \
autovideosink sync=false \
input-selector name=sel0 ! mux.sink_0 \
v4l2src device=/dev/video0 ! nvvideoconvert ! sel0.sink_0 \
videotestsrc pattern=black ! videoconvert ! sel0.sink_1 \
input-selector name=sel1 ! mux.sink_1 \
v4l2src device=/dev/video1 ! nvvideoconvert ! sel1.sink_0 \
videotestsrc pattern=black ! videoconvert ! sel1.sink_1 \
input-selector name=sel2 ! mux.sink_2 \
v4l2src device=/dev/video2 ! nvvideoconvert ! sel2.sink_0 \
videotestsrc pattern=black ! videoconvert ! sel2.sink_1 \
input-selector name=sel3 ! mux.sink_3 \
v4l2src device=/dev/video3 ! nvvideoconvert ! sel3.sink_0 \
videotestsrc pattern=black ! videoconvert ! sel3.sink_1
How Can I Fix It?
