Jetpack 6.0 Onnxruntime-gpu
Onnxruntime-gpu is giving me build errors on jetpack 6 and it seems unavailable. Can someone please help if available?
Do you want to build onnxruntime from the source for JetPack 6?
If yes, there are some prebuilt packages so you don’t need to build it on your own.
https://www.elinux.org/Jetson_Zoo#ONNX_Runtime
I need cuda support, so don’t I need the onnxruntime-gpu variant of the package? When using the normal onnxruntine it doesn’t show coda/gpu as a provider.
The onnxruntime package in Jetson_Zoo has GPU enabled already.
But please pick a package built with the same Jetpack version as yours.
