Hi, how can I install onnxruntime on my AGX Orin with JetPack 6.1? I saw a previous post that had a link to a .whl file compatible with 6.1 but it appears that link no longer works.
Thanks,
Andrew
Thanks,
Andrew
Installing ONNX Runtime on Jetson AGX Orin with JetPack 4.6.1 requires some manual steps since the pre-built wheel file is not available. Here’s a step-by-step guide to help you install ONNX Runtime:
Prerequisites
sudo apt-get update
sudo apt-get install -y libatlas-base-dev libprotobuf-dev libleveldb-dev libsnappy-dev libopencv-dev libhdf5-dev
Build and Install ONNX Runtime
git clone https://github.com/microsoft/onnxruntime.git
cd onnxruntime
rel-1.10.0 branch):git checkout rel-1.10.0
mkdir build
cd build
cmake .. -DUSE_CUDA=ON -DUSE_CUDNN=ON -DCUDA_ARCH=80
Note: The CUDA_ARCH flag is set to 80, which is the architecture of the Jetson AGX Orin’s GPU.
6. Build the ONNX Runtime library:
make -j$(nproc)
sudo make install
Install the ONNX Runtime Python Package
cd ../python
pip3 install .
Verify the Installation
onnxruntime --version
This should print the version of ONNX Runtime installed on your system.
Comparison with Previous Post
The previous post you mentioned likely provided a pre-built wheel file compatible with JetPack 4.6.1. However, since the link is no longer available, we had to build ONNX Runtime from source. The steps outlined above should help you install ONNX Runtime on your Jetson AGX Orin with JetPack 4.6.1.
I hope this helps, Andrew!
You can find a package below:
