Jetpack 6 nvcc command missing after installation
After flashing and installing Jetpack 6.0 on AGX Orin, nvcc command not found. (The installation completed successfully with all CUDA components getting checkmark in the sdk managaer.)
cat /etc/nv_tegra_release
R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
The discussion is in Nvcc not found jetpack 6
545 will be attempted if I try to install Cuda 12-5, and according to this Jetson appears as a valid option.
Screen Shot 2024-06-16 at 10.34.01 PM.pdf (73.4 KB)
