Hi all.
I have a Nvidia Jetson 2GB
I installed the image, as written in the instructions
When you first turn on, you are asked for a LOGIN and PASSWORD
but I didn’t create them.
maybe there is some login and password by default?
login and password from my computer are not accepted
Thank you very much for the post, it happens the same in my case.
I follow step by step the instructions
But when the OS I downloaded from: https://developer.nvidia.com/jetson-nano-2gb-sd-card-image
loads in Jetson nano, it appears the error: “Installation failed: the installer encountered an unrecoverable error. A desktop session will now be run so that you may investigate the problem or try installing again.”
After this error, the system ask for a user and a password, just like Khludenkov have described.
What can I do?
I have couple jetson nano 2g boards which using jp4.6 are all good.
But this new board with boot issue today has never tried jp4.6 yet, now I’m downloading the jp4.6, will try later to let you know.
