Jetson AGX Orin Developer Kit (64GB) - 10 Gigabit Ethernet Support?
For my project I need to buy the “Jetson AGX Orin Developer Kit (64GB)”.
I need 10 Gigabit Ethernet.
Unfortunately, when searching for the product at different vendor shops, the specifications are mostly unclear if the developer kit has true 10GBE support or not - on many pages it only says “Gigabit Ethernet”.
So do all Jetson AGX Orin Developer Kits (64GB) support 10GBE, or is it somehow vendor specific?
Yes, all Jetson AGX Orin Developer Kits (64GB) support 10GBE. But you have to make sure what you buy is the Orin AGX devkit.
Thanks! Sorry but I’m still left with a bit of uncertainty.
This document:
…says:
“Gigabit Ethernet, 1 XFI interface for 10 Gigabit Ethernet”
Its still unclear to me - do I need some additional module/interface to get 10gbe Ethernet, or is 10gbe provided by the “regular” Ethernet port of the developer kit?
You’re right, it is unclear from the technical brief, whether it’s just supported on the board (to populate) or whether the actual physical Ethernet port supports it. But I’ve tested it and it’s 10Gbps. ethtool also reports the following advertised rates:
Supported link modes: 100baseT/Half 100baseT/Full
1000baseT/Full
10000baseT/Full
1000baseKX/Full
10000baseKX4/Full
10000baseKR/Full
2500baseT/Full
5000baseT/Full
Some vendors will make their own custom board and enable one extra Gigabit Ethernet.
But this Gigabit Ethernet was by default not exists on NV devkit. NV devkit only has XFI 10G eth.
