Hi team,
We want to use 2x 10G Ethernet interface in our board. But as per Jetson AGX Orin module design guide, there is only 1x XFI port is available to use for 10G Ethernet connectivity while in pinmux, we can select UPHY2_TX4/RX4 ~ UPHY2_TX7/RX7 as XFI ports and also there are 2x 10G ethernet ports have been used on ConnectTech Rogue and Forge Carrier board.
Could you please let us know how many XFI ports we can use on Jetson AGX Orin module?
We want to use XFI0 and XFI1 ports to get 2x 10G Ethernet connectivity by using two PHY chip on each XFI port.
Thank you
