Based on the forum post solved by @KevinFFF
I’m attempting to use CAN1_DIN on the 40-pin expansion header as a wakeup source.
My system:
Jetson Orin AGX Dev Kit
Jetpack 6.0.3
L4T Version: R36.4.3
What I’ve done so far:
- modified
/drivers/soc/tegra/pmc.cas follows to include the pin as a wakeup source
static const struct tegra_wake_event tegra234_wake_events[] = {
TEGRA_WAKE_GPIO("power", 29, 1, TEGRA234_AON_GPIO(EE, 4)),
TEGRA_WAKE_GPIO("gpio_wake", 43, 1, TEGRA234_AON_GPIO(AA, 3)),
- rebuilt the kernel and modules and installed them
- updated
/boot/extlinux/extlinux.confas follows to boot using my overlay and new image
LABEL WakeupImage
MENU LABEL Custom Header Config: <Wakeup Image with Overlay>
LINUX /boot/Image
FDT /boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb
INITRD /boot/initrd
APPEND ${cbootargs} root=PARTUUID=abed36ac-013c-44be-965c-f8dbccaa0aa4 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config
OVERLAYS /boot/custom_wakeup_pin_overlay.dtbo
- Created the following overlay
custom_wakeup_pin_overlay.dts
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/gpio/tegra234-gpio.h>
#include <dt-bindings/input/input.h>
#include <dt-bindings/pinctrl/pinctrl-tegra.h>
#include <dt-bindings/input/gpio-keys.h>
jetson-header-name = "Jetson 40pin Header";
overlay-name = "Wake via CAN1_DIN (PAA.03)";
compatible = "nvidia,p3737-0000+p3701-0005";
fragment@0 {
target-path = "/";
__overlay__ {
gpio-keys {
compatible = "gpio-keys";
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&gpio_wake_pinmux>;
/* Pinmux settings to reconfigure CAN1_DIN (PAA.03) as GPIO input */
gpio_wake_pinmux: gpio_wake_pinmux {
hdr40-pin37 {
nvidia,pins = "can1_din_paa3";
/* Set to 'rsvd1' to disable CAN and treat as GPIO */
nvidia,function = "rsvd1";
/* Enable internal pull-up resistor: 2 = TEGRA_PIN_PULL_UP */
nvidia,pull = <TEGRA_PIN_PULL_UP>;
/* Enable tristate (hi-Z when not driven): 1 = TEGRA_PIN_ENABLE */
nvidia,tristate = <TEGRA_PIN_ENABLE>;
/* Enable input buffer: 1 = TEGRA_PIN_ENABLE */
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
/* Wake event on GPIO 3 = TEGRA234_AON_GPIO(AA, 3) = CAN1_DIN = PAA.03 */
key-wake {
label = "Wake";
/* GPIO controller: gpio_aon, pin 3, active-low */
gpios = <&gpio_aon 3 1>;
/* Standard Linux input key event configuration EV_KEY==1, KEY_WAKEUP==143 */
linux,input-type = <EV_KEY>;
linux,code = <KEY_WAKEUP>;
/* Trigger on assertion (line goes low) EV_ACT_ASSERTED */
wakeup-event-action = <EV_ACT_ASSERTED>;
/* Register this as a wakeup source */
wakeup-source;
Compiled using:
$ cpp -nostdinc -I /usr/src/kernel/kernel-jammy-src/include -I /usr/src/kernel/kernel-jammy-src/include/dt-bindings -undef -x assembler-with-cpp custom_wakeup_pin_overlay.dts | dtc -@ -I dts -O dtb -o custom_wakeup_pin_overlay.dtbo
Then copied it to the /boot directory
5. rebooted
Results:
$ sudo cat /sys/kernel/debug/gpio | grep PAA.03
gpio-319 (PAA.03 )
Doesn’t seem like my changes are picking up the correct settings for the pin.
Any thoughts?
