Hi.
Verified working function on PP.06 (hi/lo), but can I use this signal for wake up NVIDIA from suspend mode?
What is required, how to do it?
Info
cat /sys/kernel/debug/gpio | grep PP.06
gpio-446 (PP.06 | sysfs ) in hi
There is a “wake” column in the spreasheet. Only those with value in that column can be wake pin.
Yes. pin PP.06 is a dedicated pin for wakeup, according to Orin AGX development module spreadsheet.
I 'm HW guy.
Need pin register PP.06 configuration for wake event or register for interrupt activate?
Software patch to linux kernel is required.
I have added a document but it would be ready in next release.
For now, a draft here for you as a reference.
→ Enabling GPIO as a Wake-Up Source
If the pin has an ID in the Wake column in the pinmux spreadsheet, a GPIO pin can wake the device from a suspended stage.
After checking the wake ID from spreadsheet, add the pin information to the <top>/kernel/kernel-5.10/drivers/soc/tegra/pmc.c file, and to update the kernel.
tegra234_wake_events.Here is an example:
Power Button (POWER_BTN_N) - GPIO3_PEE.04 - wake29
static const struct tegra_wake_event tegra234_wake_events[] = {
TEGRA_WAKE_GPIO("power", 29, 1, TEGRA234_AON_GPIO(EE, 4)),
note:
The third parameter of TEGRA_WAKE_GPIO is the instance of the GPIO group.
- For a AON GPIO, it must be 1.
- For a MAIN GPIO, it must be 0.
