【Jetson AGX Orin】Gmsl camera failed after displaying a few frames
Hi :
Please help!!!
when use gst-launch-1.0 test camera, I got error:
[ 733.058315] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
[ 733.091356] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
[ 733.124383] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
[ 733.157403] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Hi NVIDIA:
trace log:
gst-launch-1.0-4680 [002] … 3575.456416: tegra_channel_open: vi-output, ar0231 2-0050
v4l2src0:src-4682 [008] … 3575.465459: tegra_channel_set_power: ar0231 2-0050 : 0x1
v4l2src0:src-4682 [008] … 3575.465483: camera_common_s_power: status : 0x1
v4l2src0:src-4682 [008] … 3575.476010: tegra_channel_set_power: nvcsi–16 : 0x1
v4l2src0:src-4682 [008] … 3575.476013: csi_s_power: enable : 0x1
v4l2src0:src-4682 [008] … 3575.476100: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1536 fmt 13
v4l2src0:src-4682 [008] … 3575.485833: tegra_channel_set_stream: enable : 0x1
kworker/4:3-137 [004] … 3575.491749: rtcpu_string: tstamp:112503880152 id:0x04010000 str:“VM0 activating.”
v4l2src0:src-4682 [005] … 3575.502185: tegra_channel_set_stream: nvcsi–16 : 0x1
v4l2src0:src-4682 [005] … 3575.502187: csi_s_stream: enable : 0x1
v4l2src0:src-4682 [005] … 3575.502517: tegra_channel_set_stream: ar0231 2-0050 : 0x1
kworker/4:3-137 [004] … 3575.547349: rtcpu_vinotify_event: tstamp:112504445728 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3600131744608 data:0x379d580010000000
kworker/4:3-137 [004] … 3575.547351: rtcpu_vinotify_event: tstamp:112504445903 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3600131751136 data:0x0000000031000001
kworker/4:3-137 [004] … 3575.547352: rtcpu_vinotify_event: tstamp:112504446108 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3600131802592 data:0x379d550010000000
kworker/4:3-137 [004] … 3575.547352: rtcpu_vinotify_event: tstamp:112504446287 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3600131809216 data:0x0000000031000002
kworker/4:3-137 [004] … 3575.547354: rtcpu_vinotify_error: tstamp:112504637017 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3600148362784 data:0x0000000000000001
kworker/4:3-137 [004] … 3575.547354: rtcpu_vinotify_event: tstamp:112504783847 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3600148362784 data:0x0000000000000001
kworker/4:3-137 [004] … 3575.547355: rtcpu_vinotify_event: tstamp:112505121887 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600161574880 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.547356: rtcpu_vinotify_event: tstamp:112505122044 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3600161574880 data:0x0000000800000000
kworker/4:3-137 [004] … 3575.547356: rtcpu_vinotify_event: tstamp:112505122179 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3600162207936 data:0x0000000000000001
kworker/4:3-137 [004] … 3575.547356: rtcpu_vinotify_event: tstamp:112505122331 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600162209504 data:0x0000000008020001
kworker/4:3-137 [004] … 3575.547357: rtcpu_vinotify_event: tstamp:112506010305 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3600192156512 data:0x0000000005ff0002
kworker/4:3-137 [004] … 3575.547357: rtcpu_vinotify_event: tstamp:112506010462 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3600192157088 data:0x0000000000000000
kworker/4:3-137 [004] … 3575.547358: rtcpu_vinotify_event: tstamp:112506010597 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600192159584 data:0x0000000002020001
kworker/4:3-137 [004] … 3575.547358: rtcpu_vinotify_event: tstamp:112506010751 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:3600192249888 data:0x0000000006000040
kworker/4:3-137 [004] … 3575.547358: rtcpu_vinotify_event: tstamp:112506010886 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600192255776 data:0x0000000001020001
kworker/4:3-137 [004] … 3575.547359: rtcpu_vinotify_event: tstamp:112506011038 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600192283328 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.547359: rtcpu_vinotify_event: tstamp:112506011174 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3600192283360 data:0x0000000800000000
kworker/4:3-137 [004] … 3575.603188: rtcpu_vinotify_event: tstamp:112506338808 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3600192334656 data:0x379d580010000000
kworker/4:3-137 [004] … 3575.603191: rtcpu_vinotify_event: tstamp:112506338944 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3600192341184 data:0x0000000031000003
kworker/4:3-137 [004] … 3575.603191: rtcpu_vinotify_event: tstamp:112506339101 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600194608480 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.603192: rtcpu_vinotify_event: tstamp:112506339238 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3600194608480 data:0x0000000800000000
kworker/4:3-137 [004] … 3575.603192: rtcpu_vinotify_event: tstamp:112506339395 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3600195241664 data:0x0000000000000001
kworker/4:3-137 [004] … 3575.603193: rtcpu_vinotify_event: tstamp:112506339527 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600195243200 data:0x0000000008020002
kworker/4:3-137 [004] … 3575.603193: rtcpu_vinotify_event: tstamp:112507114447 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3600225190304 data:0x0000000005ff0002
kworker/4:3-137 [004] … 3575.603193: rtcpu_vinotify_event: tstamp:112507114584 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3600225190912 data:0x0000000000000000
kworker/4:3-137 [004] … 3575.603194: rtcpu_vinotify_event: tstamp:112507114741 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600225193344 data:0x0000000002020002
kworker/4:3-137 [004] … 3575.603194: rtcpu_vinotify_event: tstamp:112507114872 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:3600225283968 data:0x0000000006000040
kworker/4:3-137 [004] … 3575.603195: rtcpu_vinotify_event: tstamp:112507115025 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600225289824 data:0x0000000001020002
kworker/4:3-137 [004] … 3575.603195: rtcpu_vinotify_event: tstamp:112507115155 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600225317408 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.603196: rtcpu_vinotify_event: tstamp:112507115322 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3600225317440 data:0x0000000800000000
kworker/4:3-137 [004] … 3575.603196: rtcpu_vinotify_event: tstamp:112507115452 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3600225358464 data:0x379d550010000000
kworker/4:3-137 [004] … 3575.603196: rtcpu_vinotify_event: tstamp:112507115601 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3600225365024 data:0x0000000031000004
kworker/4:3-137 [004] … 3575.603197: rtcpu_vinotify_event: tstamp:112507115729 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600227642176 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.603197: rtcpu_vinotify_event: tstamp:112507420579 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3600227642208 data:0x0000000800000000
kworker/4:3-137 [004] … 3575.603198: rtcpu_vinotify_event: tstamp:112507420712 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3600228275456 data:0x0000000000000001
kworker/4:3-137 [004] … 3575.603198: rtcpu_vinotify_event: tstamp:112507420864 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600228276992 data:0x0000000008020003
kworker/4:3-137 [004] … 3575.659181: rtcpu_vinotify_event: tstamp:112508096726 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3600258223808 data:0x0000000005ff0002
kworker/4:3-137 [004] … 3575.659183: rtcpu_vinotify_event: tstamp:112508096887 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3600258224416 data:0x0000000000000000
kworker/4:3-137 [004] … 3575.659184: rtcpu_vinotify_event: tstamp:112508097025 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600258226880 data:0x0000000002020003
kworker/4:3-137 [004] … 3575.659184: rtcpu_vinotify_event: tstamp:112508097179 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:3600258317504 data:0x0000000006000040
kworker/4:3-137 [004] … 3575.659184: rtcpu_vinotify_event: tstamp:112508097311 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600258323328 data:0x0000000001020003
kworker/4:3-137 [004] … 3575.659185: rtcpu_vinotify_event: tstamp:112508097466 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600258350944 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.659185: rtcpu_vinotify_event: tstamp:112508097603 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3600258350944 data:0x0000000800000000
kworker/4:3-137 [004] … 3575.659186: rtcpu_vinotify_event: tstamp:112508434649 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600260676000 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.659187: rtcpu_vinotify_event: tstamp:112508434788 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3600260676000 data:0x0000000800000000
kworker/4:3-137 [004] … 3575.659187: rtcpu_vinotify_event: tstamp:112508434940 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3600261309216 data:0x0000000000000001
kworker/4:3-137 [004] … 3575.659187: rtcpu_vinotify_event: tstamp:112508435069 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600261310752 data:0x0000000008020004
kworker/4:3-137 [004] … 3575.659188: rtcpu_vinotify_event: tstamp:112509102444 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3600291257632 data:0x0000000005ff0002
kworker/4:3-137 [004] … 3575.659188: rtcpu_vinotify_event: tstamp:112509102578 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3600291258208 data:0x0000000000000000
kworker/4:3-137 [004] … 3575.659189: rtcpu_vinotify_error: tstamp:112509198962 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600294343008 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.659190: rtcpu_vinotify_event: tstamp:112509415055 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600291261824 data:0x0000000002020004
kworker/4:3-137 [004] … 3575.659190: rtcpu_vinotify_event: tstamp:112509415186 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:3600291351296 data:0x0000000006000040
kworker/4:3-137 [004] … 3575.659191: rtcpu_vinotify_event: tstamp:112509415338 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3600291357184 data:0x0000000001020004
kworker/4:3-137 [004] … 3575.659191: rtcpu_vinotify_event: tstamp:112509415466 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600291384736 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.659191: rtcpu_vinotify_event: tstamp:112509415617 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3600291384768 data:0x0000000800000000
kworker/4:3-137 [004] … 3575.659192: rtcpu_vinotify_event: tstamp:112509415750 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600293709760 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.659192: rtcpu_vinotify_event: tstamp:112509415901 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600294343008 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.715180: rtcpu_vinotify_error: tstamp:112510231269 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600327376736 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.715184: rtcpu_vinotify_event: tstamp:112510429229 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600324418464 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.715185: rtcpu_vinotify_event: tstamp:112510429385 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600326743520 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.715185: rtcpu_vinotify_event: tstamp:112510429518 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600327376736 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.715186: rtcpu_vinotify_error: tstamp:112511263569 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600360410400 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.771181: rtcpu_vinotify_event: tstamp:112511443410 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600357452256 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.771184: rtcpu_vinotify_event: tstamp:112511443543 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600359777280 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.771184: rtcpu_vinotify_event: tstamp:112511443696 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600360410400 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.771186: rtcpu_vinotify_error: tstamp:112512295860 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600393444128 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.771187: rtcpu_vinotify_event: tstamp:112512296299 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600390485856 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.771187: rtcpu_vinotify_event: tstamp:112512296452 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600392810912 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.771189: rtcpu_vinotify_event: tstamp:112512296585 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600393444128 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.827173: rtcpu_vinotify_event: tstamp:112513268924 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600423519584 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.827174: rtcpu_vinotify_error: tstamp:112513328176 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600426477856 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.827175: rtcpu_vinotify_event: tstamp:112513606903 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600425844640 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.827175: rtcpu_vinotify_event: tstamp:112513607073 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600426477856 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.827175: rtcpu_vinotify_event: tstamp:112514283066 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600456553376 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.827176: rtcpu_vinotify_error: tstamp:112514360479 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600459511648 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.827176: rtcpu_vinotify_event: tstamp:112514621048 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600458878400 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.827177: rtcpu_vinotify_event: tstamp:112514621179 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600459511648 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.883166: rtcpu_vinotify_error: tstamp:112515392787 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600492545408 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.883167: rtcpu_vinotify_event: tstamp:112515635187 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600489587200 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.883167: rtcpu_vinotify_event: tstamp:112515635321 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600491912192 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.883168: rtcpu_vinotify_event: tstamp:112515635473 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600492545408 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.883168: rtcpu_vinotify_error: tstamp:112516425091 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600525579200 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.939167: rtcpu_vinotify_event: tstamp:112516649338 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600522620928 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.939168: rtcpu_vinotify_event: tstamp:112516649518 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600524945952 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.939168: rtcpu_vinotify_event: tstamp:112516649653 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600525579200 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.939169: rtcpu_vinotify_error: tstamp:112517457392 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600558612832 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.939169: rtcpu_vinotify_event: tstamp:112517663471 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600555654720 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.939170: rtcpu_vinotify_event: tstamp:112517663604 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600557979744 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.939170: rtcpu_vinotify_event: tstamp:112517663753 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600558612832 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.995177: rtcpu_vinotify_event: tstamp:112518397064 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600588688320 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.995178: rtcpu_vinotify_error: tstamp:112518489698 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600591646528 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.995178: rtcpu_vinotify_event: tstamp:112518711396 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600591013376 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.995178: rtcpu_vinotify_event: tstamp:112518711528 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600591646528 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.995179: rtcpu_vinotify_error: tstamp:112519522003 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600624680320 data:0x00000000000003c9
kworker/4:3-137 [004] … 3575.995179: rtcpu_vinotify_event: tstamp:112519725536 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600621722272 data:0x0000000000000020
kworker/4:3-137 [004] … 3575.995179: rtcpu_vinotify_event: tstamp:112519725667 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600624047072 data:0x0000000000000010
kworker/4:3-137 [004] … 3575.995180: rtcpu_vinotify_event: tstamp:112519725816 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600624680320 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.051166: rtcpu_vinotify_error: tstamp:112520554309 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600657714080 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.051166: rtcpu_vinotify_event: tstamp:112520739680 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600654755808 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.051167: rtcpu_vinotify_event: tstamp:112520739840 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600657080864 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.051167: rtcpu_vinotify_event: tstamp:112520739973 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600657714080 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.051167: rtcpu_vinotify_error: tstamp:112521586615 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600690747840 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.051168: rtcpu_vinotify_event: tstamp:112521753821 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600687789888 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.051168: rtcpu_vinotify_event: tstamp:112521753955 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600690114624 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.051168: rtcpu_vinotify_event: tstamp:112521754112 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600690747840 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.107321: rtcpu_vinotify_error: tstamp:112522618917 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600723781632 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.107325: rtcpu_vinotify_event: tstamp:112522767954 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600720823360 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.107325: rtcpu_vinotify_event: tstamp:112522768107 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600723148416 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.107326: rtcpu_vinotify_event: tstamp:112522768238 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600723781632 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.163318: rtcpu_vinotify_event: tstamp:112523631251 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600753857152 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.163321: rtcpu_vinotify_event: tstamp:112523631382 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600756182176 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.163323: rtcpu_vinotify_error: tstamp:112523651218 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600756815264 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.163323: rtcpu_vinotify_event: tstamp:112523951130 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600756815264 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.163324: rtcpu_vinotify_event: tstamp:112524627280 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600786890656 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.163325: rtcpu_vinotify_error: tstamp:112524683521 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600789848960 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.163325: rtcpu_vinotify_event: tstamp:112524965265 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600789215808 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.163326: rtcpu_vinotify_event: tstamp:112524965396 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600789848960 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.219194: rtcpu_vinotify_event: tstamp:112525641433 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600819924704 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.219198: rtcpu_vinotify_error: tstamp:112525715833 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600822882752 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.219198: rtcpu_vinotify_event: tstamp:112525979409 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600822249504 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.219199: rtcpu_vinotify_event: tstamp:112525979560 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600822882752 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.219199: rtcpu_vinotify_event: tstamp:112526655571 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600852958272 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.219200: rtcpu_vinotify_error: tstamp:112526748128 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600855916544 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.219200: rtcpu_vinotify_event: tstamp:112526993577 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600855283296 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.219201: rtcpu_vinotify_event: tstamp:112526993708 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600855916544 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.275315: rtcpu_vinotify_error: tstamp:112527780436 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600888950304 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.275319: rtcpu_vinotify_event: tstamp:112528007703 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600885992288 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.275320: rtcpu_vinotify_event: tstamp:112528007839 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600888317056 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.275320: rtcpu_vinotify_event: tstamp:112528007995 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600888950304 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.331314: rtcpu_vinotify_error: tstamp:112528812728 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600921984064 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.331318: rtcpu_vinotify_event: tstamp:112528813167 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600919025792 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.331318: rtcpu_vinotify_event: tstamp:112528813320 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600921350848 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.331319: rtcpu_vinotify_event: tstamp:112528813451 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600921984064 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.331319: rtcpu_vinotify_event: tstamp:112529765499 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600952059680 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.331320: rtcpu_vinotify_error: tstamp:112529845047 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600955017728 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.331321: rtcpu_vinotify_event: tstamp:112530103471 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600954384608 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.331321: rtcpu_vinotify_event: tstamp:112530103626 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600955017728 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.387169: rtcpu_vinotify_error: tstamp:112530877346 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600988051424 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.387173: rtcpu_vinotify_event: tstamp:112531117617 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3600985093376 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.387174: rtcpu_vinotify_event: tstamp:112531117774 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3600987418240 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.387175: rtcpu_vinotify_event: tstamp:112531117905 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3600988051424 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.387175: rtcpu_vinotify_error: tstamp:112531909653 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601021085184 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.387176: rtcpu_vinotify_event: tstamp:112532131758 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601018127200 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.387176: rtcpu_vinotify_event: tstamp:112532131891 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601020451968 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.387176: rtcpu_vinotify_event: tstamp:112532132043 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601021085184 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.443171: rtcpu_vinotify_error: tstamp:112532941956 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601054118976 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.443176: rtcpu_vinotify_event: tstamp:112533145895 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601051160640 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.443177: rtcpu_vinotify_event: tstamp:112533146048 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601053485696 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.443178: rtcpu_vinotify_event: tstamp:112533146178 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601054118976 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.443178: rtcpu_vinotify_error: tstamp:112533974260 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601087152736 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.499313: rtcpu_vinotify_event: tstamp:112534160038 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601084194752 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.499316: rtcpu_vinotify_event: tstamp:112534160172 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601086519520 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.499317: rtcpu_vinotify_event: tstamp:112534160323 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601087152736 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.499318: rtcpu_vinotify_event: tstamp:112534913935 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601117228224 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.499319: rtcpu_vinotify_error: tstamp:112535006568 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601120186528 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.499320: rtcpu_vinotify_event: tstamp:112535241896 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601119553248 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.499320: rtcpu_vinotify_event: tstamp:112535242034 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601120186528 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.555177: rtcpu_vinotify_error: tstamp:112536038872 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601153220128 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.555181: rtcpu_vinotify_event: tstamp:112536256022 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601150262144 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.555181: rtcpu_vinotify_event: tstamp:112536256160 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601152587040 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.555182: rtcpu_vinotify_event: tstamp:112536256314 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601153220128 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.555182: rtcpu_vinotify_error: tstamp:112537071178 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601186253824 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.555182: rtcpu_vinotify_event: tstamp:112537270008 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601183295616 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.555183: rtcpu_vinotify_event: tstamp:112537270167 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601185620640 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.555183: rtcpu_vinotify_event: tstamp:112537270300 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601186253824 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.611313: rtcpu_vinotify_error: tstamp:112538103481 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601219287648 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.611317: rtcpu_vinotify_event: tstamp:112538284151 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601216330528 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.611318: rtcpu_vinotify_event: tstamp:112538284286 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601218654368 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.611318: rtcpu_vinotify_event: tstamp:112538284443 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601219287648 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.611318: rtcpu_vinotify_error: tstamp:112539135785 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601252321376 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.667160: rtcpu_vinotify_event: tstamp:112539298292 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601249363104 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.667161: rtcpu_vinotify_event: tstamp:112539298452 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601251688192 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.667161: rtcpu_vinotify_event: tstamp:112539298586 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601252321376 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.667162: rtcpu_vinotify_event: tstamp:112540148119 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601282396864 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.667162: rtcpu_vinotify_event: tstamp:112540148250 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601284721920 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.667163: rtcpu_vinotify_error: tstamp:112540168088 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601285355168 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.667164: rtcpu_vinotify_event: tstamp:112540481475 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601285355168 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.723173: rtcpu_vinotify_event: tstamp:112541157619 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601315430400 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.723174: rtcpu_vinotify_error: tstamp:112541200392 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601318388928 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.723175: rtcpu_vinotify_event: tstamp:112541495604 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601317755712 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.723176: rtcpu_vinotify_event: tstamp:112541495737 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601318388928 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.723176: rtcpu_vinotify_event: tstamp:112542171762 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601348464576 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.723177: rtcpu_vinotify_error: tstamp:112542232699 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601351422560 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.723178: rtcpu_vinotify_event: tstamp:112542509741 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601350789472 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.723179: rtcpu_vinotify_event: tstamp:112542509896 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601351422560 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.779312: rtcpu_vinotify_event: tstamp:112543185904 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601381498048 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.779316: rtcpu_vinotify_error: tstamp:112543265001 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601384456288 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.779317: rtcpu_vinotify_event: tstamp:112543523889 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601383823104 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.779317: rtcpu_vinotify_event: tstamp:112543524026 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601384456288 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.779318: rtcpu_vinotify_error: tstamp:112544297306 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601417490048 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.835166: rtcpu_vinotify_event: tstamp:112544538023 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601414532000 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.835169: rtcpu_vinotify_event: tstamp:112544538159 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601416856800 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.835170: rtcpu_vinotify_event: tstamp:112544538315 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601417490048 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.835172: rtcpu_vinotify_error: tstamp:112545329595 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601450523840 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.835172: rtcpu_vinotify_event: tstamp:112545330032 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601447565632 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.835173: rtcpu_vinotify_event: tstamp:112545330190 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601449890592 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.835173: rtcpu_vinotify_event: tstamp:112545330323 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601450523840 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.891309: rtcpu_vinotify_event: tstamp:112546295827 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601480599616 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.891314: rtcpu_vinotify_error: tstamp:112546361918 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601483557600 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.891314: rtcpu_vinotify_event: tstamp:112546633957 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601482924384 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.891315: rtcpu_vinotify_event: tstamp:112546634115 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601483557600 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.891316: rtcpu_vinotify_event: tstamp:112547309954 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601513633088 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.891316: rtcpu_vinotify_error: tstamp:112547394223 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601516591360 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.891317: rtcpu_vinotify_event: tstamp:112547648091 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601515958144 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.891318: rtcpu_vinotify_event: tstamp:112547648224 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601516591360 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.947310: rtcpu_vinotify_error: tstamp:112548426523 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601549624992 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.947314: rtcpu_vinotify_event: tstamp:112548662230 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601546666848 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.947315: rtcpu_vinotify_event: tstamp:112548662362 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601548991904 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.947315: rtcpu_vinotify_event: tstamp:112548662515 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601549624992 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.947316: rtcpu_vinotify_error: tstamp:112549458823 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601582658720 data:0x00000000000003c9
kworker/4:3-137 [004] … 3576.947316: rtcpu_vinotify_event: tstamp:112549676369 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601579700672 data:0x0000000000000020
kworker/4:3-137 [004] … 3576.947317: rtcpu_vinotify_event: tstamp:112549676529 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601582025536 data:0x0000000000000010
kworker/4:3-137 [004] … 3576.947317: rtcpu_vinotify_event: tstamp:112549676663 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601582658720 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.003309: rtcpu_vinotify_error: tstamp:112550491134 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601615692512 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.003313: rtcpu_vinotify_event: tstamp:112550690509 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601612734464 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.003313: rtcpu_vinotify_event: tstamp:112550690641 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601615059264 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.003314: rtcpu_vinotify_event: tstamp:112550690797 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601615692512 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.003315: rtcpu_vinotify_event: tstamp:112551430830 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601645767936 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.003315: rtcpu_vinotify_error: tstamp:112551523438 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601648726240 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.059309: rtcpu_vinotify_event: tstamp:112551738445 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601648093024 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.059313: rtcpu_vinotify_event: tstamp:112551738582 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601648726240 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.059315: rtcpu_vinotify_error: tstamp:112552555777 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601681760032 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.059315: rtcpu_vinotify_event: tstamp:112552752565 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601678802048 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.059316: rtcpu_vinotify_event: tstamp:112552752698 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601681126816 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.059318: rtcpu_vinotify_event: tstamp:112552752852 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601681760032 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.115308: rtcpu_vinotify_error: tstamp:112553588053 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601714793824 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.115312: rtcpu_vinotify_event: tstamp:112553766710 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601711835584 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.115313: rtcpu_vinotify_event: tstamp:112553766864 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601714160576 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.115313: rtcpu_vinotify_event: tstamp:112553766995 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601714793824 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.115314: rtcpu_vinotify_error: tstamp:112554620348 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601747827456 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.115315: rtcpu_vinotify_event: tstamp:112554780847 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601744869344 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.115315: rtcpu_vinotify_event: tstamp:112554780982 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601747194368 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.115316: rtcpu_vinotify_event: tstamp:112554781139 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601747827456 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.171307: rtcpu_vinotify_error: tstamp:112555652654 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601780861152 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.171311: rtcpu_vinotify_event: tstamp:112555794832 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601777902624 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.171312: rtcpu_vinotify_event: tstamp:112555794989 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601780227968 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.171312: rtcpu_vinotify_event: tstamp:112555795122 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601780861152 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.171313: rtcpu_vinotify_event: tstamp:112556664990 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601810936928 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.171314: rtcpu_vinotify_event: tstamp:112556665126 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601813261696 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.171315: rtcpu_vinotify_error: tstamp:112556684959 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601813894912 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.227178: rtcpu_vinotify_event: tstamp:112556978010 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601813894912 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.227181: rtcpu_vinotify_event: tstamp:112557654160 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601843970496 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.227183: rtcpu_vinotify_error: tstamp:112557717262 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601846928704 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.227183: rtcpu_vinotify_event: tstamp:112557992153 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601846295488 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.227184: rtcpu_vinotify_event: tstamp:112557992288 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601846928704 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.283306: rtcpu_vinotify_event: tstamp:112558668305 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601877004512 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.283310: rtcpu_vinotify_error: tstamp:112558749569 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601879962464 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.283310: rtcpu_vinotify_event: tstamp:112559006284 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601879329248 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.283311: rtcpu_vinotify_event: tstamp:112559006441 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601879962464 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.283312: rtcpu_vinotify_error: tstamp:112559781872 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601912996256 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.283313: rtcpu_vinotify_event: tstamp:112560020426 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601910037984 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.283313: rtcpu_vinotify_event: tstamp:112560020584 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601912363008 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.283314: rtcpu_vinotify_event: tstamp:112560020716 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601912996256 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.339307: rtcpu_vinotify_error: tstamp:112560814176 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601946029888 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.339311: rtcpu_vinotify_event: tstamp:112561034565 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601943072096 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.339311: rtcpu_vinotify_event: tstamp:112561034698 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601945396800 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.339312: rtcpu_vinotify_event: tstamp:112561034853 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601946029888 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.339313: rtcpu_vinotify_error: tstamp:112561846462 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601979063584 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.339313: rtcpu_vinotify_event: tstamp:112561846896 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3601976105280 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.339314: rtcpu_vinotify_event: tstamp:112561847052 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3601978430432 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.339314: rtcpu_vinotify_event: tstamp:112561847187 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3601979063584 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.395326: rtcpu_vinotify_event: tstamp:112562792361 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602009139360 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.395329: rtcpu_vinotify_error: tstamp:112562878796 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602012097344 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.395330: rtcpu_vinotify_event: tstamp:112563130495 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602011464128 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.395330: rtcpu_vinotify_event: tstamp:112563130646 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602012097344 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.451158: rtcpu_vinotify_error: tstamp:112563911089 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602045131136 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.451163: rtcpu_vinotify_event: tstamp:112564144640 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602042172928 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.451163: rtcpu_vinotify_event: tstamp:112564144796 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602044497888 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.451164: rtcpu_vinotify_event: tstamp:112564144931 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602045131136 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.451165: rtcpu_vinotify_error: tstamp:112564943391 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602078164928 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.451165: rtcpu_vinotify_event: tstamp:112565158775 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602075206944 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.451166: rtcpu_vinotify_event: tstamp:112565158910 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602077531680 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.451167: rtcpu_vinotify_event: tstamp:112565159063 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602078164928 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.507303: rtcpu_vinotify_error: tstamp:112565975698 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602111198688 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.507307: rtcpu_vinotify_event: tstamp:112566172913 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602108240416 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.507308: rtcpu_vinotify_event: tstamp:112566173067 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602110565440 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.507308: rtcpu_vinotify_event: tstamp:112566173202 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602111198688 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.507309: rtcpu_vinotify_error: tstamp:112567008004 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602144232320 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.507310: rtcpu_vinotify_event: tstamp:112567187060 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602141274336 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.507310: rtcpu_vinotify_event: tstamp:112567187193 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602143599232 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.507311: rtcpu_vinotify_event: tstamp:112567187349 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602144232320 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.563171: rtcpu_vinotify_event: tstamp:112567947683 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602174308000 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.563176: rtcpu_vinotify_error: tstamp:112568040313 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602177266272 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.563177: rtcpu_vinotify_event: tstamp:112568268761 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602176632832 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.563177: rtcpu_vinotify_event: tstamp:112568268892 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602177266272 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.619306: rtcpu_vinotify_error: tstamp:112569072611 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602210299808 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.619311: rtcpu_vinotify_event: tstamp:112569282894 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602207342048 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.619311: rtcpu_vinotify_event: tstamp:112569283026 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602209666560 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.619312: rtcpu_vinotify_event: tstamp:112569283176 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602210299808 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.619313: rtcpu_vinotify_error: tstamp:112570104914 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602243333568 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.619313: rtcpu_vinotify_event: tstamp:112570297026 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602240375232 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.619314: rtcpu_vinotify_event: tstamp:112570297175 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602242700352 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.619314: rtcpu_vinotify_event: tstamp:112570297306 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602243333568 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.675300: rtcpu_vinotify_error: tstamp:112571137219 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602276367360 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.675305: rtcpu_vinotify_event: tstamp:112571311173 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602273409088 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.675305: rtcpu_vinotify_event: tstamp:112571311301 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602275734080 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.675305: rtcpu_vinotify_event: tstamp:112571311450 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602276367360 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.675306: rtcpu_vinotify_error: tstamp:112572169527 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602309401120 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.675306: rtcpu_vinotify_event: tstamp:112572325308 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602306442848 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.675307: rtcpu_vinotify_event: tstamp:112572325462 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602308767872 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.675308: rtcpu_vinotify_event: tstamp:112572325596 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602309401120 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.731157: rtcpu_vinotify_event: tstamp:112573181860 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602339476640 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.731160: rtcpu_vinotify_event: tstamp:112573181996 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602341801664 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.731161: rtcpu_vinotify_error: tstamp:112573201828 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602342434752 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.731161: rtcpu_vinotify_event: tstamp:112573508480 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602342434752 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.731162: rtcpu_vinotify_event: tstamp:112574184492 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602372510400 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.731162: rtcpu_vinotify_error: tstamp:112574234133 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602375468448 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.787166: rtcpu_vinotify_event: tstamp:112574522621 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602374835296 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.787170: rtcpu_vinotify_event: tstamp:112574522755 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602375468448 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.787170: rtcpu_vinotify_event: tstamp:112575198625 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602405543936 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.787172: rtcpu_vinotify_error: tstamp:112575266435 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602408502208 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.787173: rtcpu_vinotify_event: tstamp:112575536764 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602407868992 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.787173: rtcpu_vinotify_event: tstamp:112575536920 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602408502208 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.843160: rtcpu_vinotify_event: tstamp:112576212765 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602438577664 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.843164: rtcpu_vinotify_error: tstamp:112576298740 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602441536000 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.843165: rtcpu_vinotify_event: tstamp:112576550904 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602440902752 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.843165: rtcpu_vinotify_event: tstamp:112576551038 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602441536000 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.843166: rtcpu_vinotify_error: tstamp:112577331046 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602474569760 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.843166: rtcpu_vinotify_event: tstamp:112577564893 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602471612096 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.843167: rtcpu_vinotify_event: tstamp:112577565024 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602473936544 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.843167: rtcpu_vinotify_event: tstamp:112577565174 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602474569760 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.899300: rtcpu_vinotify_error: tstamp:112578363334 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602507603552 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.899304: rtcpu_vinotify_event: tstamp:112578363771 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602504645280 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.899304: rtcpu_vinotify_event: tstamp:112578363924 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602506970304 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.899305: rtcpu_vinotify_event: tstamp:112578364054 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602507603552 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.899305: rtcpu_vinotify_event: tstamp:112579322866 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602537679200 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.899306: rtcpu_vinotify_error: tstamp:112579395652 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602540637184 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.955299: rtcpu_vinotify_event: tstamp:112579660846 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602540004096 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.955302: rtcpu_vinotify_event: tstamp:112579660995 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602540637184 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.955303: rtcpu_vinotify_event: tstamp:112580337023 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602570712864 data:0x0000000000000020
kworker/4:3-137 [004] … 3577.955305: rtcpu_vinotify_error: tstamp:112580427953 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602573670880 data:0x00000000000003c9
kworker/4:3-137 [004] … 3577.955305: rtcpu_vinotify_event: tstamp:112580674988 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602573037728 data:0x0000000000000010
kworker/4:3-137 [004] … 3577.955306: rtcpu_vinotify_event: tstamp:112580675124 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602573670880 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.011298: rtcpu_vinotify_error: tstamp:112581460264 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602606704672 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.011302: rtcpu_vinotify_event: tstamp:112581689131 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602603746656 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.011303: rtcpu_vinotify_event: tstamp:112581689265 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602606071424 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.011303: rtcpu_vinotify_event: tstamp:112581689421 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602606704672 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.011304: rtcpu_vinotify_error: tstamp:112582492568 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602639738432 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.011304: rtcpu_vinotify_event: tstamp:112582703263 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602636780128 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.011305: rtcpu_vinotify_event: tstamp:112582703412 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602639105184 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.011306: rtcpu_vinotify_event: tstamp:112582703543 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602639738432 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.067296: rtcpu_vinotify_error: tstamp:112583524902 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602672772224 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.067300: rtcpu_vinotify_event: tstamp:112583717415 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602669814208 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.067301: rtcpu_vinotify_event: tstamp:112583717546 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602672138976 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.067302: rtcpu_vinotify_event: tstamp:112583717699 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602672772224 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.067302: rtcpu_vinotify_event: tstamp:112584464547 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602702847744 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.067303: rtcpu_vinotify_error: tstamp:112584557176 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602705805984 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.123294: rtcpu_vinotify_event: tstamp:112584799108 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602705172768 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.123297: rtcpu_vinotify_event: tstamp:112584799246 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602705805984 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.123299: rtcpu_vinotify_error: tstamp:112585589478 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602738839616 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.123299: rtcpu_vinotify_event: tstamp:112585813250 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602735881632 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.123300: rtcpu_vinotify_event: tstamp:112585813384 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602738206528 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.123300: rtcpu_vinotify_event: tstamp:112585813538 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602738839616 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.179294: rtcpu_vinotify_error: tstamp:112586621781 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602771873312 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.179298: rtcpu_vinotify_event: tstamp:112586827385 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602768915008 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.179299: rtcpu_vinotify_event: tstamp:112586827538 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602771240160 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.179299: rtcpu_vinotify_event: tstamp:112586827669 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602771873312 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.179300: rtcpu_vinotify_error: tstamp:112587654086 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602804907072 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.179300: rtcpu_vinotify_event: tstamp:112587841526 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602801948800 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.179301: rtcpu_vinotify_event: tstamp:112587841662 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602804273856 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.179301: rtcpu_vinotify_event: tstamp:112587841819 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602804907072 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.235170: rtcpu_vinotify_error: tstamp:112588686410 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602837940864 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.235174: rtcpu_vinotify_event: tstamp:112588855666 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602834982560 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.235175: rtcpu_vinotify_event: tstamp:112588855820 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602837307648 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.235176: rtcpu_vinotify_event: tstamp:112588855951 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602837940864 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.235176: rtcpu_vinotify_event: tstamp:112589698725 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602868016352 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.235176: rtcpu_vinotify_event: tstamp:112589698857 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602870341408 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.235177: rtcpu_vinotify_error: tstamp:112589718696 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602870974624 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.235177: rtcpu_vinotify_event: tstamp:112590005067 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602870974624 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.291294: rtcpu_vinotify_event: tstamp:112590681105 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602901050144 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.291298: rtcpu_vinotify_error: tstamp:112590751004 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602904008416 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.291298: rtcpu_vinotify_event: tstamp:112591019214 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602903375200 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.291299: rtcpu_vinotify_event: tstamp:112591019347 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602904008416 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.291299: rtcpu_vinotify_event: tstamp:112591695221 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602934083968 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.291300: rtcpu_vinotify_error: tstamp:112591783303 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602937042048 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.347294: rtcpu_vinotify_event: tstamp:112592033202 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602936408960 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.347297: rtcpu_vinotify_event: tstamp:112592033351 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602937042048 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.347299: rtcpu_vinotify_error: tstamp:112592815609 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602970075744 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.347300: rtcpu_vinotify_event: tstamp:112593047346 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3602967117536 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.347301: rtcpu_vinotify_event: tstamp:112593047501 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3602969442592 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.347303: rtcpu_vinotify_event: tstamp:112593047634 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3602970075744 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.403351: rtcpu_vinotify_error: tstamp:112593847916 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603003109536 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.403355: rtcpu_vinotify_event: tstamp:112594061479 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3603000151520 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.403356: rtcpu_vinotify_event: tstamp:112594061612 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3603002476320 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.403356: rtcpu_vinotify_event: tstamp:112594061768 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603003109536 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.403357: rtcpu_vinotify_error: tstamp:112594880208 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603036143296 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.403357: rtcpu_vinotify_event: tstamp:112594880645 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3603033184992 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.403358: rtcpu_vinotify_event: tstamp:112594880797 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3603035510048 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.403359: rtcpu_vinotify_event: tstamp:112594880928 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603036143296 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.459282: rtcpu_vinotify_event: tstamp:112595853198 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3603066219104 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.459286: rtcpu_vinotify_error: tstamp:112595912525 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603069177088 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.459287: rtcpu_vinotify_event: tstamp:112596191174 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3603068543840 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.459287: rtcpu_vinotify_event: tstamp:112596191327 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603069177088 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.459288: rtcpu_vinotify_event: tstamp:112596867367 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3603099252576 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.459289: rtcpu_vinotify_error: tstamp:112596944832 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603102210848 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.515164: rtcpu_vinotify_event: tstamp:112597205322 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3603101577600 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.515167: rtcpu_vinotify_event: tstamp:112597205457 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603102210848 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.515169: rtcpu_vinotify_error: tstamp:112597977130 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603135244480 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.515170: rtcpu_vinotify_event: tstamp:112598219459 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3603132286400 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.515170: rtcpu_vinotify_event: tstamp:112598219591 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3603134611392 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.515171: rtcpu_vinotify_event: tstamp:112598219743 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603135244480 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.571156: rtcpu_vinotify_error: tstamp:112599009431 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603168278176 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.571160: rtcpu_vinotify_event: tstamp:112599233601 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3603165319968 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.571161: rtcpu_vinotify_event: tstamp:112599233756 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3603167645024 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.571162: rtcpu_vinotify_event: tstamp:112599233888 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603168278176 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.571163: rtcpu_vinotify_error: tstamp:112600041739 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603201311968 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.571163: rtcpu_vinotify_event: tstamp:112600247737 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3603198353664 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.571164: rtcpu_vinotify_event: tstamp:112600247866 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3603200678720 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.571164: rtcpu_vinotify_event: tstamp:112600248017 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603201311968 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.627289: rtcpu_vinotify_event: tstamp:112600981417 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3603231387552 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.627293: rtcpu_vinotify_error: tstamp:112601074044 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603234345760 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.627294: rtcpu_vinotify_event: tstamp:112601295662 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3603233712512 data:0x0000000000000010
kworker/4:3-137 [004] … 3578.627295: rtcpu_vinotify_event: tstamp:112601295794 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603234345760 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.627295: rtcpu_vinotify_error: tstamp:112602106357 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:3603267379520 data:0x00000000000003c9
kworker/4:3-137 [004] … 3578.683280: rtcpu_vinotify_event: tstamp:112602309801 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:3603264421248 data:0x0000000000000020
kworker/4:3-137 [004] … 3578.683283: rtcpu_vinotify_event: tstamp:112602309937 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:3603266746272 data:0x0000000000000010
It has been resolved. Disabled sensor Embedded line.
