CHANSEL_NOMATCH err
I cann’t capture the data from my gmsl camera , camera sensor resolution:1902x1300. deserilizer is max96712 ,this is the debug
 kworker/1:1-57      [001] .......   502.581536: rtcpu_dbg_set_loglevel: tstamp:16450185123 old:0 new:2
 kworker/1:1-57      [001] .......   508.629547: rtcpu_string: tstamp:16640446053 id:0x04010000 str:"VM0 deactivating."
 grab_camera-3272    [003] .......   550.721074: tegra_channel_open: vi-output, max96712 9-0029
 grab_camera-3272    [003] .......   550.727213: tegra_channel_set_power: max96712 9-0029 : 0x1
 grab_camera-3272    [003] .......   550.727224: camera_common_s_power: status : 0x1
 grab_camera-3272    [003] .......   550.727430: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
 grab_camera-3272    [003] .......   550.727432: csi_s_power: enable : 0x1
 grab_camera-3272    [003] .......   550.727919: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1300 fmt 10
vi-output, max9-3273 [000] … 550.736324: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:0 pid:3273 tid:3273
vi-output, max9-3273 [000] … 550.736334: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:0 pid:3273 tid:3273
vi-output, max9-3273 [000] … 550.736335: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:0 pid:3273 tid:3273
grab_camera-3272 [003] … 550.736352: tegra_channel_set_stream: enable : 0x1
grab_camera-3272 [003] … 550.738851: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
grab_camera-3272 [003] … 550.738854: csi_s_stream: enable : 0x1
grab_camera-3272 [003] … 550.739184: tegra_channel_set_stream: max96712 9-0029 : 0x1
kworker/1:1-57 [001] … 550.765551: rtcpu_string: tstamp:17956491980 id:0x04010000 str:“VM0 activating.”
kworker/1:1-57 [001] … 550.765556: rtcpu_vinotify_event: tstamp:17957200703 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:574613243808 data:0x799e300010000000
kworker/1:1-57 [001] … 550.765557: rtcpu_vinotify_event: tstamp:17957200843 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:574613285888 data:0x0000000031000001
 kworker/1:1-57      [001] .......   550.765558: rtcpu_vinotify_event: tstamp:17957201000 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:574613304032 data:0x799e2d0010000000
 kworker/1:1-57      [001] .......   550.765558: rtcpu_vinotify_event: tstamp:17957201137 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:574613324352 data:0x0000000007020001
 kworker/1:1-57      [001] .......   550.765559: rtcpu_vinotify_event: tstamp:17957201293 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:574613366720 data:0x0000000031000002
 kworker/1:1-57      [001] .......   550.765560: rtcpu_vinotify_error: tstamp:17957391936 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574636407264 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.821532: rtcpu_vinotify_event: tstamp:17957743606 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574634123808 data:0x0000000000000012
 kworker/1:1-57      [001] .......   550.821533: rtcpu_vinotify_event: tstamp:17957743768 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574636407264 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.821534: rtcpu_vinotify_event: tstamp:17958285680 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574661156288 data:0x0000000000000022
 kworker/1:1-57      [001] .......   550.821535: rtcpu_vinotify_error: tstamp:17958433592 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574669739456 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.821536: rtcpu_vinotify_event: tstamp:17958828586 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574667456000 data:0x0000000000000012
 kworker/1:1-57      [001] .......   550.821537: rtcpu_vinotify_event: tstamp:17958828723 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574669739456 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.877543: rtcpu_vinotify_event: tstamp:17959370700 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574694488640 data:0x0000000000000022
 kworker/1:1-57      [001] .......   550.877545: rtcpu_vinotify_error: tstamp:17959475205 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574703071872 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.877545: rtcpu_vinotify_event: tstamp:17959913584 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574700788416 data:0x0000000000000012
 kworker/1:1-57      [001] .......   550.877546: rtcpu_vinotify_event: tstamp:17959913736 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574703071872 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.877547: rtcpu_vinotify_event: tstamp:17960455948 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574727820864 data:0x0000000000000022
 kworker/1:1-57      [001] .......   550.877548: rtcpu_vinotify_event: tstamp:17960456097 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574734120608 data:0x0000000000000012
 kworker/1:1-57      [001] .......   550.877549: rtcpu_vinotify_error: tstamp:17960517115 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574736404064 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.877549: rtcpu_vinotify_event: tstamp:17960517749 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574736404064 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.933531: rtcpu_vinotify_event: tstamp:17961324462 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574761153152 data:0x0000000000000022
 kworker/1:1-57      [001] .......   550.933533: rtcpu_vinotify_error: tstamp:17961558497 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574769736416 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.933533: rtcpu_vinotify_event: tstamp:17961866274 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574767452960 data:0x0000000000000012
 kworker/1:1-57      [001] .......   550.933534: rtcpu_vinotify_event: tstamp:17961866427 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574769736416 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.933535: rtcpu_vinotify_event: tstamp:17962409447 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574794485472 data:0x0000000000000022
 kworker/1:1-57      [001] .......   550.933536: rtcpu_vinotify_error: tstamp:17962600100 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574803068672 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.989545: rtcpu_vinotify_event: tstamp:17962951280 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574800785216 data:0x0000000000000012
 kworker/1:1-57      [001] .......   550.989546: rtcpu_vinotify_event: tstamp:17962951414 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574803068672 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.989547: rtcpu_vinotify_event: tstamp:17963494461 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574827817696 data:0x0000000000000022
 kworker/1:1-57      [001] .......   550.989548: rtcpu_vinotify_error: tstamp:17963641734 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574836400896 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   550.989549: rtcpu_vinotify_event: tstamp:17964037341 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574834117440 data:0x0000000000000012
 kworker/1:1-57      [001] .......   550.989549: rtcpu_vinotify_event: tstamp:17964037491 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574836400896 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.045724: rtcpu_vinotify_event: tstamp:17964579431 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574861150080 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.045728: rtcpu_vinotify_error: tstamp:17964683399 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574869733280 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.045729: rtcpu_vinotify_event: tstamp:17965122347 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574867449824 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.045729: rtcpu_vinotify_event: tstamp:17965122481 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574869733280 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.045730: rtcpu_vinotify_event: tstamp:17965664716 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574894482304 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.045731: rtcpu_vinotify_event: tstamp:17965664851 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574900782048 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.045732: rtcpu_vinotify_error: tstamp:17965725000 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574903065472 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.045732: rtcpu_vinotify_event: tstamp:17966207343 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574903065472 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.101553: rtcpu_vinotify_event: tstamp:17966497273 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574927814688 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.101555: rtcpu_vinotify_error: tstamp:17966766643 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574936397888 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.101556: rtcpu_vinotify_event: tstamp:17967021144 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574934114432 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.101557: rtcpu_vinotify_event: tstamp:17967021279 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574936397888 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.101557: rtcpu_vinotify_event: tstamp:17967563229 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574961146880 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.101558: rtcpu_vinotify_error: tstamp:17967808299 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574969730080 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.157549: rtcpu_vinotify_event: tstamp:17968106140 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:574967446656 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.157551: rtcpu_vinotify_event: tstamp:17968106298 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:574969730080 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.157551: rtcpu_vinotify_event: tstamp:17968648220 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:574994479264 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.157552: rtcpu_vinotify_error: tstamp:17968849908 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575003062496 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.157553: rtcpu_vinotify_event: tstamp:17969191131 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575000779008 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.157554: rtcpu_vinotify_event: tstamp:17969191267 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575003062496 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.157555: rtcpu_vinotify_event: tstamp:17969733219 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575027811488 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.213539: rtcpu_vinotify_error: tstamp:17969891545 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575036394720 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.213541: rtcpu_vinotify_event: tstamp:17970276153 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575034111232 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.213542: rtcpu_vinotify_event: tstamp:17970276306 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575036394720 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.213542: rtcpu_vinotify_event: tstamp:17970818212 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575061143776 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.213543: rtcpu_vinotify_error: tstamp:17970933203 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575069727072 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.213544: rtcpu_vinotify_event: tstamp:17971361114 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575067443616 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.213545: rtcpu_vinotify_event: tstamp:17971361246 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575069727072 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.269756: rtcpu_vinotify_event: tstamp:17971902325 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575094476096 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.269759: rtcpu_vinotify_event: tstamp:17971902460 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575100775840 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.269761: rtcpu_vinotify_error: tstamp:17971974812 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575103059296 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.269762: rtcpu_vinotify_event: tstamp:17972392290 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575103059296 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.269764: rtcpu_vinotify_event: tstamp:17972934377 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575127808320 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.269765: rtcpu_vinotify_error: tstamp:17973016441 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575136391520 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.325559: rtcpu_vinotify_event: tstamp:17973477284 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575134108064 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.325563: rtcpu_vinotify_event: tstamp:17973477419 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575136391520 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.325564: rtcpu_vinotify_event: tstamp:17974019646 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575161140704 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.325565: rtcpu_vinotify_event: tstamp:17974019781 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575167440448 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.325567: rtcpu_vinotify_error: tstamp:17974058107 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575169723904 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.325569: rtcpu_vinotify_event: tstamp:17974562276 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575169723904 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.381558: rtcpu_vinotify_error: tstamp:17975099710 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575203056128 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.381561: rtcpu_vinotify_event: tstamp:17975104366 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575194472928 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.381562: rtcpu_vinotify_event: tstamp:17975104518 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575200772672 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.381562: rtcpu_vinotify_event: tstamp:17975104650 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575203056128 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.381563: rtcpu_vinotify_error: tstamp:17976141346 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575236388512 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.381563: rtcpu_vinotify_event: tstamp:17976189361 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575227805312 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.381564: rtcpu_vinotify_event: tstamp:17976189495 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575234105056 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.381565: rtcpu_vinotify_event: tstamp:17976189646 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575236388512 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.437726: rtcpu_vinotify_error: tstamp:17977183260 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575269720736 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.437731: rtcpu_vinotify_event: tstamp:17977183871 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575261137536 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.437732: rtcpu_vinotify_event: tstamp:17977184020 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575267437248 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.437732: rtcpu_vinotify_event: tstamp:17977184151 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575269720736 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.437733: rtcpu_vinotify_event: tstamp:17977980077 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575294469888 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.437734: rtcpu_vinotify_error: tstamp:17978224615 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575303053152 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.437735: rtcpu_vinotify_event: tstamp:17978522992 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575300769664 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.437735: rtcpu_vinotify_event: tstamp:17978523142 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575303053152 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.493743: rtcpu_vinotify_event: tstamp:17979065077 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575327802144 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.493748: rtcpu_vinotify_error: tstamp:17979266249 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575336385344 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.493749: rtcpu_vinotify_event: tstamp:17979607989 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575334101888 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.493750: rtcpu_vinotify_event: tstamp:17979608121 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575336385344 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.493750: rtcpu_vinotify_event: tstamp:17980150077 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575361134400 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.493751: rtcpu_vinotify_error: tstamp:17980307919 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575369717696 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.549559: rtcpu_vinotify_event: tstamp:17980693019 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575367434240 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.549563: rtcpu_vinotify_event: tstamp:17980693173 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575369717696 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.549564: rtcpu_vinotify_event: tstamp:17981235103 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575394466752 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.549566: rtcpu_vinotify_error: tstamp:17981349517 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575403049920 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.549567: rtcpu_vinotify_event: tstamp:17981778011 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575400766464 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.549568: rtcpu_vinotify_event: tstamp:17981778156 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575403049920 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.605542: rtcpu_vinotify_event: tstamp:17982320376 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575427798976 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.605543: rtcpu_vinotify_event: tstamp:17982320514 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575434098720 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.605544: rtcpu_vinotify_error: tstamp:17982391149 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575436382176 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.605545: rtcpu_vinotify_event: tstamp:17982863003 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575436382176 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.605545: rtcpu_vinotify_event: tstamp:17983163435 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575461131360 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.605546: rtcpu_vinotify_error: tstamp:17983432823 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575469714528 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.605546: rtcpu_vinotify_event: tstamp:17983676834 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575467431104 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.605547: rtcpu_vinotify_event: tstamp:17983676966 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575469714528 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.661555: rtcpu_vinotify_event: tstamp:17984218923 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575494463552 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.661557: rtcpu_vinotify_error: tstamp:17984474417 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575503046752 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.661558: rtcpu_vinotify_event: tstamp:17984761826 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575500763296 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.661559: rtcpu_vinotify_event: tstamp:17984761976 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575503046752 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.661560: rtcpu_vinotify_event: tstamp:17985303911 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575527795968 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.661560: rtcpu_vinotify_error: tstamp:17985516054 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575536379136 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.717764: rtcpu_vinotify_event: tstamp:17985846818 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575534095680 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.717767: rtcpu_vinotify_event: tstamp:17985846950 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575536379136 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.717767: rtcpu_vinotify_event: tstamp:17986389996 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575561128160 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.717770: rtcpu_vinotify_error: tstamp:17986557718 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575569711360 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.717770: rtcpu_vinotify_event: tstamp:17986931870 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575567427904 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.717771: rtcpu_vinotify_event: tstamp:17986932032 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575569711360 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.773556: rtcpu_vinotify_event: tstamp:17987475022 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575594460512 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.773558: rtcpu_vinotify_error: tstamp:17987599325 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575603043776 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.773558: rtcpu_vinotify_event: tstamp:17988016834 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575600760288 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.773559: rtcpu_vinotify_event: tstamp:17988016970 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575603043776 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.773560: rtcpu_vinotify_event: tstamp:17988560012 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575627792768 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.773561: rtcpu_vinotify_event: tstamp:17988568471 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575634092512 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.773561: rtcpu_vinotify_error: tstamp:17988640955 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575636375968 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.829563: rtcpu_vinotify_event: tstamp:17989102827 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575636375968 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.829567: rtcpu_vinotify_event: tstamp:17989644816 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575661125024 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.829568: rtcpu_vinotify_event: tstamp:17989644968 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575667424864 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.829570: rtcpu_vinotify_error: tstamp:17989682626 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575669708320 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.829571: rtcpu_vinotify_event: tstamp:17990187474 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575669708320 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.829574: rtcpu_vinotify_error: tstamp:17990724248 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575703040576 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.829575: rtcpu_vinotify_event: tstamp:17990729572 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575694457376 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.829575: rtcpu_vinotify_event: tstamp:17990729707 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575700757120 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.829576: rtcpu_vinotify_event: tstamp:17990729859 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575703040576 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.885549: rtcpu_vinotify_error: tstamp:17991765857 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575736372800 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.885553: rtcpu_vinotify_event: tstamp:17991814572 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575727789600 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.885554: rtcpu_vinotify_event: tstrtcamp:17991814724ptuh:-1 vvi i:1 tag:FS channel:0x02 frame:0 vi_tcapstamp:575734089344 data:tur000000000000012
 kworker/1:1-57  i:     [001] .......   551.885555: rtcpu_vinotify_event: tstamp:17991814867 cch:-1 vi:1 tag:CHANer _NOMATCH channel:0x84 frame:0 vi_tstamp:575736372800 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.94173-cartcpu_vinvi otify_error: tstamp:1teg7992807530 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575769705152 datc: x00000000000003c9
 kworktin1:1-57      [001] .......  t t 55he 41735: rtcpu_vinotify_evnel: tstamp:17992899597 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575761121984 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.941736: rtcpu_vinotify_event: tstamp:17992899733 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575767421728 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.941736: rtcpu_vinotify_event: tstamp:17992899886 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575769705152 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.941737: rtcpu_vinotify_error: tstamp:17993849409 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575803037376 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.941738: rtcpu_vinotify_event: tstamp:17993850040 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575794454208 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.941738: rtcpu_vinotify_event: tstamp:17993850203 cch:-1 vi:1 tag:FS crtchannel:0x02 frame:0 vi_tstavi mp:575800753920 data:0x0000000tur000000012
 kworker/1:1-57      [001] .......   551.941739: rtcpu_vinotify_event: tstamp:17993850336 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575803037376 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.997547: rtcpu_vinotify_event: tstamp:17994636516 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575827786592 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.997548: rtcpu_vinotify_error: tstamp:17994890760 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575836369792 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.997549: rtcpu_vinotify_event: tstamp:17995178335 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575834086336 data:0x0000000000000012
 kworker/1:1-57      [001] .......   551.997550: rtcpu_vinotify_event: tstamp:17995178487 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575836369792 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   551.997551: rtcpu_vinotify_event: tstamp:17995721517 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575861118816 data:0x0000000000000022
 kworker/1:1-57      [001] .......   551.997552: rtcpu_vinotify_error: tstamp:17995932425 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575869702016 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.053558: rtcpu_vinotify_event: tstamp:17996263357 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575867418560 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.053562: rtcpu_vinotify_event: tstamp:17996263491 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575869702016 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.053564: rtcpu_vinotify_event: tstamp:17996806537 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575894451168 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.053566: rtcpu_vinotify_error: tstamp:17996974030 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575903034400 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.053567: rtcpu_vinotify_event: tstamp:17997348347 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575900750944 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.053567: rtcpu_vinotify_event: tstamp:17997348505 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575903034400 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.109540: rtcpu_vinotify_event: tstamp:17997891533 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575927783424 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.109542: rtcpu_vinotify_error: tstamp:17998015663 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575936366592 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.109543: rtcpu_vinotify_event: tstamp:17998434437 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575934083136 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.109543: rtcpu_vinotify_event: tstamp:17998434572 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575936366592 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.109544: rtcpu_vinotify_event: tstamp:17998976516 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575961115648 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.109545: rtcpu_vinotify_error: tstamp:17999057364 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575969698944 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.109546: rtcpu_vinotify_event: tstamp:17999519456 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:575967415520 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.109547: rtcpu_vinotify_event: tstamp:17999519610 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:575969698944 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.165746: rtcpu_vinotify_event: tstamp:17999829575 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:575994448000 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.165751: rtcpu_vinotify_error: tstamp:18000098932 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576003031232 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.165752: rtcpu_vinotify_event: tstamp:18000333269 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576000747776 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.165752: rtcpu_vinotify_event: tstamp:18000333403 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576003031232 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.165753: rtcpu_vinotify_event: tstamp:18000875348 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576027780256 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.165754: rtcpu_vinotify_error: tstamp:18001140564 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576036363424 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.221764: rtcpu_vinotify_event: tstamp:18001418255 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576034079968 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.221767: rtcpu_vinotify_event: tstamp:18001418405 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576036363424 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.221769: rtcpu_vinotify_event: tstamp:18001960340 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576061112640 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.221770: rtcpu_vinotify_error: tstamp:18002182229 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576069695808 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.221771: rtcpu_vinotify_event: tstamp:18002503277 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576067412352 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.221772: rtcpu_vinotify_event: tstamp:18002503413 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576069695808 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.221773: rtcpu_vinotify_event: tstamp:18003045366 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576094444832 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.277757: rtcpu_vinotify_error: tstamp:18003223831 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576103028032 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.277762: rtcpu_vinotify_event: tstamp:18003588296 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576100744576 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.277763: rtcpu_vinotify_event: tstamp:18003588448 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576103028032 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.277764: rtcpu_vinotify_event: tstamp:18004130354 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576127777216 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.277765: rtcpu_vinotify_error: tstamp:18004265505 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576136360416 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.277765: rtcpu_vinotify_event: tstamp:18004673260 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576134076960 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.277766: rtcpu_vinotify_event: tstamp:18004673394 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576136360416 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.333558: rtcpu_vinotify_event: tstamp:18005215349 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576161109440 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.333562: rtcpu_vinotify_event: tstamp:18005234616 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576167409184 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.333564: rtcpu_vinotify_error: tstamp:18005307131 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576169692608 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.333565: rtcpu_vinotify_event: tstamp:18005757740 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576169692608 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.333566: rtcpu_vinotify_event: tstamp:18006301197 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576194441824 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.333567: rtcpu_vinotify_event: tstamp:18006301348 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576200741568 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.333568: rtcpu_vinotify_error: tstamp:18006348740 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576203025024 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.389739: rtcpu_vinotify_event: tstamp:18006843825 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576203025024 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.389742: rtcpu_vinotify_event: tstamp:18007386189 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576227774016 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.389743: rtcpu_vinotify_event: tstamp:18007386324 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576234073792 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.389745: rtcpu_vinotify_error: tstamp:18007390370 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576236357248 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.389746: rtcpu_vinotify_event: tstamp:18007928815 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576236357248 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.445730: rtcpu_vinotify_error: tstamp:18008432033 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576269689600 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.445734: rtcpu_vinotify_event: tstamp:18008470940 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576261106272 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.445735: rtcpu_vinotify_event: tstamp:18008471089 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576267406144 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.445736: rtcpu_vinotify_event: tstamp:18008471224 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576269689600 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.445737: rtcpu_vinotify_error: tstamp:18009473672 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576303021824 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.445737: rtcpu_vinotify_event: tstamp:18009555931 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576294438656 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.445738: rtcpu_vinotify_event: tstamp:18009556064 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576300738400 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.445739: rtcpu_vinotify_event: tstamp:18009556214 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576303021824 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.501548: rtcpu_vinotify_error: tstamp:18010515554 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576336354080 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.501553: rtcpu_vinotify_event: tstamp:18010516188 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576327770848 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.501554: rtcpu_vinotify_event: tstamp:18010516337 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576334070624 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.501554: rtcpu_vinotify_event: tstamp:18010516468 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576336354080 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.501555: rtcpu_vinotify_event: tstamp:18011291769 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576361103264 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.501556: rtcpu_vinotify_error: tstamp:18011556940 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576369686432 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.557533: rtcpu_vinotify_event: tstamp:18011834707 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576367402976 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.557534: rtcpu_vinotify_event: tstamp:18011834864 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576369686432 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.557535: rtcpu_vinotify_event: tstamp:18012376788 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576394435488 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.557535: rtcpu_vinotify_error: tstamp:18012598541 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576403018656 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.557537: rtcpu_vinotify_event: tstamp:18012919699 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576400735200 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.557537: rtcpu_vinotify_event: tstamp:18012919836 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576403018656 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.557538: rtcpu_vinotify_event: tstamp:18013461783 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576427767840 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.613528: rtcpu_vinotify_error: tstamp:18013640179 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576436351072 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.613529: rtcpu_vinotify_event: tstamp:18014004690 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576434067584 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.613530: rtcpu_vinotify_event: tstamp:18014004849 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576436351072 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.613531: rtcpu_vinotify_event: tstamp:18014547869 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576461100064 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.613531: rtcpu_vinotify_error: tstamp:18014681867 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576469683264 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.613532: rtcpu_vinotify_event: tstamp:18015089710 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576467399808 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.613532: rtcpu_vinotify_event: tstamp:18015089842 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576469683264 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.669556: rtcpu_vinotify_event: tstamp:18015632865 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576494432416 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.669557: rtcpu_vinotify_error: tstamp:18015723447 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576503015648 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.669558: rtcpu_vinotify_event: tstamp:18016174677 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576500732192 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.669559: rtcpu_vinotify_event: tstamp:18016174829 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576503015648 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.669560: rtcpu_vinotify_event: tstamp:18016495717 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576527764672 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.669561: rtcpu_vinotify_error: tstamp:18016765079 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576536347872 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.669562: rtcpu_vinotify_event: tstamp:18016988482 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576534064416 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.669563: rtcpu_vinotify_event: tstamp:18016988614 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576536347872 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.725546: rtcpu_vinotify_error: tstamp:18017806743 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576569680224 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.725547: rtcpu_vinotify_event: tstamp:18018073474 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576561096928 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.725548: rtcpu_vinotify_event: tstamp:18018073621 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576567396768 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.725548: rtcpu_vinotify_event: tstamp:18018073774 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576569680224 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.725549: rtcpu_vinotify_event: tstamp:18018616650 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576594429280 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.781541: rtcpu_vinotify_error: tstamp:18018848348 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576603012480 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.781546: rtcpu_vinotify_event: tstamp:18019158466 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576600729024 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.781547: rtcpu_vinotify_event: tstamp:18019158605 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576603012480 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.781548: rtcpu_vinotify_event: tstamp:18019701643 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576627761504 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.781548: rtcpu_vinotify_error: tstamp:18019890012 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576636344704 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.781549: rtcpu_vinotify_event: tstamp:18020244550 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576634061248 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.781550: rtcpu_vinotify_event: tstamp:18020244703 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576636344704 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.837532: rtcpu_vinotify_event: tstamp:18020786639 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576661093888 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.837533: rtcpu_vinotify_error: tstamp:18020931643 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576669677088 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.837534: rtcpu_vinotify_event: tstamp:18021329543 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576667393632 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.837535: rtcpu_vinotify_event: tstamp:18021329680 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576669677088 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.837536: rtcpu_vinotify_event: tstamp:18021871620 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576694426112 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.837537: rtcpu_vinotify_event: tstamp:18021900781 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576700725856 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.837537: rtcpu_vinotify_error: tstamp:18021973245 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576703009280 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.893532: rtcpu_vinotify_event: tstamp:18022413975 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576703009280 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.893533: rtcpu_vinotify_event: tstamp:18022956341 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576727758496 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.893534: rtcpu_vinotify_event: tstamp:18022956497 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576734058208 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.893534: rtcpu_vinotify_error: tstamp:18023014885 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576736341696 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.893535: rtcpu_vinotify_event: tstamp:18023498978 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576736341696 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.893535: rtcpu_vinotify_event: tstamp:18024041345 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576761090720 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.893536: rtcpu_vinotify_event: tstamp:18024041477 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576767390464 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.893536: rtcpu_vinotify_error: tstamp:18024056506 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576769673888 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.949541: rtcpu_vinotify_event: tstamp:18024583975 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576769673888 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.949544: rtcpu_vinotify_error: tstamp:18025098185 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576803006272 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   552.949544: rtcpu_vinotify_event: tstamp:18025127163 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576794423072 data:0x0000000000000022
 kworker/1:1-57      [001] .......   552.949545: rtcpu_vinotify_event: tstamp:18025127314 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576800722848 data:0x0000000000000012
 kworker/1:1-57      [001] .......   552.949545: rtcpu_vinotify_event: tstamp:18025127448 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576803006272 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.005657: rtcpu_vinotify_error: tstamp:18026139784 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576836338496 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.005661: rtcpu_vinotify_event: tstamp:18026212151 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576827755328 data:0x0000000000000022
 kworker/1:1-57      [001] .......   553.005662: rtcpu_vinotify_event: tstamp:18026212285 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576834055072 data:0x0000000000000012
 kworker/1:1-57      [001] .......   553.005662: rtcpu_vinotify_event: tstamp:18026212435 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576836338496 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.005663: rtcpu_vinotify_error: tstamp:18027181730 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576869670880 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.005664: rtcpu_vinotify_event: tstamp:18027182356 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576861087552 data:0x0000000000000022
 kworker/1:1-57      [001] .......   553.005665: rtcpu_vinotify_event: tstamp:18027182509 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576867387392 data:0x0000000000000012
 kworker/1:1-57      [001] .......   553.005665: rtcpu_vinotify_event: tstamp:18027182644 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576869670880 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.061728: rtcpu_vinotify_event: tstamp:18028002901 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576894419904 data:0x0000000000000022
 kworker/1:1-57      [001] .......   553.061732: rtcpu_vinotify_error: tstamp:18028223054 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576903003104 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.061732: rtcpu_vinotify_event: tstamp:18028544711 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576900719648 data:0x0000000000000012
 kworker/1:1-57      [001] .......   553.061733: rtcpu_vinotify_event: tstamp:18028544860 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576903003104 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.061733: rtcpu_vinotify_event: tstamp:18029087911 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576927752128 data:0x0000000000000022
 kworker/1:1-57      [001] .......   553.061734: rtcpu_vinotify_error: tstamp:18029264686 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576936335360 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.117725: rtcpu_vinotify_event: tstamp:18029629699 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576934051872 data:0x0000000000000012
 kworker/1:1-57      [001] .......   553.117727: rtcpu_vinotify_event: tstamp:18029629836 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576936335360 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.117728: rtcpu_vinotify_event: tstamp:18030172878 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576961084544 data:0x0000000000000022
 kworker/1:1-57      [001] .......   553.117730: rtcpu_vinotify_error: tstamp:18030306354 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576969667712 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.117731: rtcpu_vinotify_event: tstamp:18030714721 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:576967384256 data:0x0000000000000012
 kworker/1:1-57      [001] .......   553.117731: rtcpu_vinotify_event: tstamp:18030714873 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:576969667712 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.173758: rtcpu_vinotify_event: tstamp:18031257878 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:576994416768 data:0x0000000000000022
 kworker/1:1-57      [001] .......   553.173763: rtcpu_vinotify_error: tstamp:18031347955 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:577002999936 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.173764: rtcpu_vinotify_event: tstamp:18031799693 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:577000716480 data:0x0000000000000012
 kworker/1:1-57      [001] .......   553.173765: rtcpu_vinotify_event: tstamp:18031799858 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:577002999936 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.173766: rtcpu_vinotify_event: tstamp:18032343151 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:577027749120 data:0x0000000000000022
 kworker/1:1-57      [001] .......   553.173767: rtcpu_vinotify_event: tstamp:18032343286 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:577034048864 data:0x0000000000000012
 kworker/1:1-57      [001] .......   553.173767: rtcpu_vinotify_error: tstamp:18032389592 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:577036332320 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.229545: rtcpu_vinotify_event: tstamp:18032884690 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:577036332320 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.229547: rtcpu_vinotify_event: tstamp:18033161874 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:577061081376 data:0x0000000000000022
 kworker/1:1-57      [001] .......   553.229548: rtcpu_vinotify_error: tstamp:18033431223 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:577069664544 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.229549: rtcpu_vinotify_event: tstamp:18033699581 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:577067381088 data:0x0000000000000012
 kworker/1:1-57      [001] .......   553.229550: rtcpu_vinotify_event: tstamp:18033699716 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:577069664544 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.229551: rtcpu_vinotify_event: tstamp:18034241669 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:577094413696 data:0x0000000000000022
 kworker/1:1-57      [001] .......   553.229552: rtcpu_vinotify_error: tstamp:18034472859 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:577102996928 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.285745: rtcpu_vinotify_event: tstamp:18034784579 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:577100713472 data:0x0000000000000012
 kworker/1:1-57      [001] .......   553.285748: rtcpu_vinotify_event: tstamp:18034784731 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:577102996928 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.285749: rtcpu_vinotify_event: tstamp:18035326665 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:577127745952 data:0x0000000000000022
 kworker/1:1-57      [001] .......   553.285752: rtcpu_vinotify_error: tstamp:18035514524 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:577136329152 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.285752: rtcpu_vinotify_event: tstamp:18035869563 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:577134045696 data:0x0000000000000012
 kworker/1:1-57      [001] .......   553.285753: rtcpu_vinotify_event: tstamp:18035869697 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:577136329152 data:0x00000000000003c9
 kworker/1:1-57      [001] .......   553.341551: rtcpu_vinotify_event: tstamp:18036411647 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:577161078176 data:0x0000000000000022
kworker/1:1-57 [001] … 555.129523: rtcpu_vinotify_event: tstamp:18092889677 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:578961021952 data:0x0000000000000022
kworker/1:1-57 [001] … 555.129524: rtcpu_vinotify_event: tstamp:18092889811 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:578967321824 data:0x0000000000000012
kworker/1:1-57 [001] … 555.129524: rtcpu_vinotify_event: tstamp:18092889961 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:578969605280 data:0x00000000000003c9
kworker/1:1-57 [001] … 555.129524: rtcpu_vinotify_error: tstamp:18093846289 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:579002937536 data:0x00000000000003c9
kworker/1:1-57 [001] … 555.129525: rtcpu_vinotify_event: tstamp:18093846918 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:578994354368 data:0x0000000000000022
grab_camera-3272 [003] … 555.758855: tegra_channel_close: vi-output, max96712 9-0029
vi-output, max9-3274 [001] … 555.880219: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1300 fmt 10
grab_camera-3272 [002] … 555.880801: tegra_channel_set_stream: enable : 0x0
grab_camera-3272 [002] … 555.880803: tegra_channel_set_stream: max96712 9-0029 : 0x0
grab_camera-3272 [002] … 555.881224: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
grab_camera-3272 [002] … 555.881228: csi_s_stream: enable : 0x0
grab_camera-3272 [001] … 555.884192: tegra_channel_set_power: max96712 9-0029 : 0x0
grab_camera-3272 [001] … 555.884207: camera_common_s_power: status : 0x0
grab_camera-3272 [001] … 555.884218: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
grab_camera-3272 [001] … 555.884220: csi_s_power: enable : 0x0
Preformatted kworker/3:1-4252 [003] ....... 6675.989538: rtcpu_vinotify_event: tstamp:209080343858 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:6690570701632 data:0x0000000000000012 kworker/3:1-4252 [003] ....... 6675.989540: rtcpu_vinotify_error: tstamp:209080410015 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:6690572985088 data:0x00000000000003c9 kworker/3:1-4252 [003] ....... 6675.989540: rtcpu_vinotify_event: tstamp:209080885729 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:6690572985088 data:0x00000000000003c9 kworker/3:1-4252 [003] ....... 6675.989541: rtcpu_vinotify_event: tstamp:209081428058 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:6690597734240 data:0x0000000000000022 kworker/3:1-4252 [003] ....... 6675.989542: rtcpu_vinotify_event: tstamp:209081428242 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:6690604033984 data:0x0000000000000012 kworker/3:1-4252 [003] ....... 6676.045530: rtcpu_vinotify_error: tstamp:209081451627 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:6690606317440 data:0x00000000000003c9 kworker/3:1-4252 [003] ....... 6676.045532: rtcpu_vinotify_event: tstamp:209081970715 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:6690606317440 data:0x00000000000003c9 kworker/3:1-4252 [003] ....... 6676.045533: rtcpu_vinotify_error: tstamp:209082493282 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0x84 frame:0 vi_tstamp:6690639649632 data:0x00000000000003c9 kworker/3:1-4252 [003] ....... 6676.045533: rtcpu_vinotify_event: tstamp:209082512812 cch:-1 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:6690631066432 data:0x0000000000000022 kworker/3:1-4252 [003] ....... 6676.045534: rtcpu_vinotify_event: tstamp:209082512948 cch:-1 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:6690637366176 data:0x0000000000000012 text
CHANSEL_NOMATCH could be the embedded_data_height incorrect in device tree of incorrect virtual channel ID.
our sensor vendor said the embeded_data_height = 0,and vc_id is the default
You also need confirm with MAX.
should confirm MAX what?
The deserilizer may send embedded data and virtual channel id.
I confirmed the max96712 don’t send embedded data and pipe2 is map to vitual channel 2, but that’s configures of max96712, the soc’s device-tree should config vc=2 too?
Please confirm the vc-id to 0 by max96712 to try.
OK, thank you very much for your help, when I modified the vc-id to 0, the vi can capture the image from camera correctly。
