GMSL camera preview lost frames,The preview screen refreshes every few seconds
Hi.
I am now porting the driver for an infrared GMSL camera, and now I can preview it, but the screen freezes, and the screen only refreshes every few seconds. Can you help me analyze what is wrong. thanks.
The sensor device: 640x512 25Hz, ser : MAX96705, deser :MAX96712.
The preview command:
gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw, format=UYVY, width=640, height=512, framerate=25/1’ ! xvimagesink -ev
Get the trace log if any clue.
https://elinux.org/Jetson/l4t/Camera_BringUp
Hi
First I ran this command below:
“v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=3”
Then I ran these commands below:
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
trace.log (797.9 KB)
can you see something wrong in trace.log ?
Looks like the embedded_data_height in device tree incorrect.
Have a check the bring up link for the detail information.
Hi
I had tried change embedded_data_height to 0 or 1,it didn’t work.
below is my dts:
	host1x {
		vi@15c10000 {
			num-channels = <4>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					ar0233_vi_in0: endpoint {
						vc-id = <0>;
						port-index = <0>;
						bus-width = <2>;
						remote-endpoint = <&ar0233_csi_out0>;
				port@1 {
					reg = <1>;
					ar0233_vi_in1: endpoint {
						vc-id = <0>;
						port-index = <1>;
						bus-width = <2>;
						remote-endpoint = <&ar0233_csi_out1>;
				port@2 {
					reg = <2>;
					ar0233_vi_in2: endpoint {
						vc-id = <0>;
						port-index = <2>;
						bus-width = <2>;
						remote-endpoint = <&ar0233_csi_out2>;
				port@3 {
					reg = <3>;
					ar0233_vi_in3: endpoint {
						vc-id = <0>;
						port-index = <3>;
						bus-width = <2>;
						remote-endpoint = <&ar0233_csi_out3>;
				port@4 {
					reg = <4>;
					ar0233_vi_in4: endpoint {
						vc-id = <0>;
						port-index = <4>;
						bus-width = <2>;
						remote-endpoint = <&ar0233_csi_out4>;
				port@5 {
					reg = <5>;
					ar0233_vi_in5: endpoint {
						vc-id = <0>;
						port-index = <5>;
						bus-width = <2>;
						remote-endpoint = <&ar0233_csi_out5>;
		nvcsi@15a00000 {
			num-channels = <4>;
			#size-cells = <0>;
			channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						ar0233_csi_in0: endpoint@0 {
							port-index = <0>;
							bus-width = <2>;
							remote-endpoint = <&ar0233_ar0233_out0>;
					port@1 {
						reg = <1>;
						ar0233_csi_out0: endpoint@1 {
							remote-endpoint = <&ar0233_vi_in0>;
			channel@1 {
				reg = <1>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						ar0233_csi_in1: endpoint@2 {
							port-index = <1>;
							bus-width = <2>;
							remote-endpoint = <&ar0233_ar0233_out1>;
					port@1 {
						reg = <1>;
						ar0233_csi_out1: endpoint@3 {
							remote-endpoint = <&ar0233_vi_in1>;
			channel@2 {
				reg = <2>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						ar0233_csi_in2: endpoint@4 {
							port-index = <2>;
							bus-width = <2>;
							remote-endpoint = <&ar0233_ar0233_out2>;
					port@1 {
						reg = <1>;
						ar0233_csi_out2: endpoint@5 {
							remote-endpoint = <&ar0233_vi_in2>;
			channel@3 {
				reg = <3>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						ar0233_csi_in3: endpoint@6 {
							port-index = <3>;
							bus-width = <2>;
							remote-endpoint = <&ar0233_ar0233_out3>;
					port@1 {
						reg = <1>;
						ar0233_csi_out3: endpoint@7 {
							remote-endpoint = <&ar0233_vi_in3>;
	i2c@3180000 {
		imx390_a@1b {
				compatible = "nvidia,imx390";
				reg = <0x1b>;
				/* Physical dimensions of sensor */
				physical_w = "15.0";
				physical_h = "12.5";
				sensor_model ="imx390";
				/* Defines number of frames to be dropped by driver internally after applying */
				/* sensor crop settings. Some sensors send corrupt frames after applying */
				/* crop co-ordinates */
				post_crop_frame_drop = "0";
				/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
				use_decibel_gain = "true";
				/* enable CID_SENSOR_MODE_ID for sensor modes selection */
				use_sensor_mode_id = "true";
				* A modeX node is required to support v4l2 driver
				* implementation with NVIDIA camera software stack
				* mclk_khz = "";
				* Standard MIPI driving clock, typically 24MHz
				* num_lanes = "";
				* Number of lane channels sensor is programmed to output
				* tegra_sinterface = "";
				* The base tegra serial interface lanes are connected to
				* vc_id = "";
				* The virtual channel id of the sensor.
				* discontinuous_clk = "";
				* The sensor is programmed to use a discontinuous clock on MIPI lanes
				* dpcm_enable = "true";
				* The sensor is programmed to use a DPCM modes
				* cil_settletime = "";
				* MIPI lane settle time value.
				* A "0" value attempts to autocalibrate based on mclk_khz and pix_clk_hz
				* active_w = "";
				* Pixel active region width
				* active_h = "";
				* Pixel active region height
				* dynamic_pixel_bit_depth = "";
				* sensor dynamic bit depth for sensor mode
				* csi_pixel_bit_depth = "";
				* sensor output bit depth for sensor mode
				* mode_type="";
				* Sensor mode type, For eg: yuv, Rgb, bayer, bayer_wdr_pwl
				* pixel_phase="";
				* Pixel phase for sensor mode, For eg: rggb, vyuy, rgb888
				* readout_orientation = "0";
				* Based on camera module orientation.
				* Only change readout_orientation if you specifically
				* Program a different readout order for this mode
				* line_length = "";
				* Pixel line length (width) for sensor mode.
				* This is used to calibrate features in our camera stack.
				* pix_clk_hz = "";
				* Sensor pixel clock used for calculations like exposure and framerate
				* inherent_gain = "";
				* Gain obtained inherently from mode (ie. pixel binning)
				* min_gain_val = ""; (floor to 6 decimal places)
				* max_gain_val = ""; (floor to 6 decimal places)
				* Gain limits for mode
				* if use_decibel_gain = "true", please set the gain as decibel
				* min_exp_time = ""; (ceil to integer)
				* max_exp_time = ""; (ceil to integer)
				* Exposure Time limits for mode (us)
				* min_hdr_ratio = "";
				* max_hdr_ratio = "";
				* HDR Ratio limits for mode
				* min_framerate = "";
				* max_framerate = "";
				* Framerate limits for mode (fps)
				* embedded_metadata_height = "";
				* Sensor embedded metadata height in units of rows.
				* If sensor does not support embedded metadata value should be 0.
				mode0 {/*mode IMX390_MODE_1920X1080_CROP_30FPS*/
					mclk_khz = "24000";
					num_lanes = "2";
					//vc_id = "0";
					discontinuous_clk = "no";
					//dpcm_enable = "false";
					cil_settletime = "0";
					dynamic_pixel_bit_depth = "16";
					csi_pixel_bit_depth = "16";
					mode_type = "yuv";
					pixel_phase = "uyvy";
					active_w = "640";
					active_h = "512";
					//readout_orientation = "0";
					line_length = "640";
					//inherent_gain = "1";
					pix_clk_hz = "200000000";
					serdes_pix_clk_hz = "800000000";
					gain_factor = "10";
					min_gain_val = "0"; /* dB */
					max_gain_val = "300"; /* dB */
					step_gain_val = "3"; /* 0.3 */
					default_gain = "0";
					min_hdr_ratio = "1";
					max_hdr_ratio = "1";
					framerate_factor = "1";
					min_framerate = "1";
					max_framerate = "25";
					step_framerate = "1";
					default_framerate = "25";
					exposure_factor = "1000000";
					min_exp_time = "59"; /*us, 2 lines*/
					max_exp_time = "40000";
					step_exp_time = "1";
					default_exp_time = "40000";/* us */
					embedded_metadata_height = "2";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						ar0233_ar0233_out0: endpoint {
							vc-id = <0>;
							port-index = <0>;
							bus-width = <2>;
							remote-endpoint = <&ar0233_csi_in0>;
				gmsl-link {
					src-csi-port = "b";
					dst-csi-port = "a";
					serdes-csi-link = "a";
					csi-mode = "4x2";
					st-vc = <0>;
					vc-id = <0>;
					num-lanes = <2>;
					streams = "ued-u1", "raw12";
	tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		* Physical settings to calculate max ISO BW
		* num_csi_lanes = <>;
		* Total number of CSI lanes when all cameras are active
		* max_lane_speed = <>;
		* Max lane speed in Kbit/s
		* min_bits_per_pixel = <>;
		* Min bits per pixel
		* vi_peak_byte_per_pixel = <>;
		* Max byte per pixel for the VI ISO case
		* vi_bw_margin_pct = <>;
		* Vi bandwidth margin in percentage
		* max_pixel_rate = <>;
		* Max pixel rate in Kpixel/s for the ISP ISO case
		* isp_peak_byte_per_pixel = <>;
		* Max byte per pixel for the ISP ISO case
		* isp_bw_margin_pct = <>;
		* Isp bandwidth margin in percentage
		num_csi_lanes = <2>;
		max_lane_speed = <4000000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		 * The general guideline for naming badge_info contains 3 parts, and is as follows,
		 * The first part is the camera_board_id for the module; if the module is in a FFD
		 * platform, then use the platform name for this part.
		 * The second part contains the position of the module, ex. "rear" or "front".
		 * The third part contains the last 6 characters of a part number which is found
		 * in the module's specsheet from the vender.
		modules {
			module0 {
				badge = "imx390_rear";
				position = "rear";
				orientation = "1";
				drivernode0 {
					/* Declare PCL support driver (classically known as guid)  */
					pcl_id = "v4l2_sensor";
					/* Driver v4l2 device name */
					devname = "imx390 30-001b";
					/* Declare the device-tree hierarchy to driver instance */
					proc-device-tree = "/proc/device-tree/i2c@3180000/imx390_a@1b";
			module1 {
				badge = "imx390_front";
				position = "front";
				orientation = "1";
				drivernode0 {
					devname = "imx390 30-001c";
					proc-device-tree = "/proc/device-tree/i2c@3180000/imx390_b@1c";
			module2 {
				badge = "imx390_left";
				position = "left";
				orientation = "1";
				drivernode0 {
					devname = "imx390 30-001d";
					proc-device-tree = "/proc/device-tree/i2c@3180000/imx390_c@1d";
			module3 {
				badge = "imx390_right";
				position = "right";
				orientation = "1";
				drivernode0 {
					devname = "imx390 30-001e";
					proc-device-tree = "/proc/device-tree/i2c@3180000/imx390_d@1e";
command:
llt@llt:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw, format=UYVY, width=640, height=512, framerate=25/1' ! xvimagesink  -ev
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, format=(string)UYVY, width=(int)640, height=(int)512, framerate=(fraction)25/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)UYVY, width=(int)640, height=(int)512, framerate=(fraction)25/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstXvImageSink:xvimagesink0.GstPad:sink: caps = video/x-raw, format=(string)UYVY, width=(int)640, height=(int)512, framerate=(fraction)25/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)UYVY, width=(int)640, height=(int)512, framerate=(fraction)25/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
dmesg:
[  291.586073] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[  291.643963] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  294.245852] tegra194-vi5 15c10000.vi: no reply from camera processor
[  294.246025] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  294.246170] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  294.249871] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x39
[  294.250062] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x41
[  294.250208] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x37
[  294.250380] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  294.323899] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  297.061836] tegra194-vi5 15c10000.vi: no reply from camera processor
[  297.062024] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  297.062180] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  297.065968] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  297.163821] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  299.877842] tegra194-vi5 15c10000.vi: no reply from camera processor
[  299.878029] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  299.878175] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  299.883535] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  299.963720] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  302.693833] tegra194-vi5 15c10000.vi: no reply from camera processor
[  302.693992] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  302.694152] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  302.696907] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  302.763658] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  305.509842] tegra194-vi5 15c10000.vi: no reply from camera processor
[  305.509995] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  305.510145] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  305.516891] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  305.603640] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  308.325834] tegra194-vi5 15c10000.vi: no reply from camera processor
[  308.325991] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  308.326149] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  308.333871] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  308.403511] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  311.141835] tegra194-vi5 15c10000.vi: no reply from camera processor
[  311.142016] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  311.142161] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  311.152808] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  311.243407] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  313.957838] tegra194-vi5 15c10000.vi: no reply from camera processor
[  313.957993] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  313.958172] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  313.965814] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  314.043339] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  316.774118] tegra194-vi5 15c10000.vi: no reply from camera processor
[  316.774276] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  316.774423] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  316.788839] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  316.797859] [RCE] WARNING: t194/vi5.c:459 [vi5_channel_disable] "ch 35 ABORT trial# 2/5 unsuccessful"
[  316.883308] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  319.589843] tegra194-vi5 15c10000.vi: no reply from camera processor
[  319.589999] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  319.590145] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  319.592870] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  319.643175] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  322.149832] tegra194-vi5 15c10000.vi: no reply from camera processor
[  322.149988] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  322.150156] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  322.156864] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  322.243104] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  324.965829] tegra194-vi5 15c10000.vi: no reply from camera processor
[  324.965987] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  324.966128] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  324.973892] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  325.043020] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  327.781836] tegra194-vi5 15c10000.vi: no reply from camera processor
[  327.782022] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  327.782171] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  327.789896] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  327.882947] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  330.597833] tegra194-vi5 15c10000.vi: no reply from camera processor
[  330.598019] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  330.598167] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  330.605786] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  330.682893] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  333.413838] tegra194-vi5 15c10000.vi: no reply from camera processor
[  333.413992] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  333.414139] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  333.421780] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  333.482792] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 64
[  336.229839] tegra194-vi5 15c10000.vi: no reply from camera processor
[  336.229992] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  336.230156] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  336.233884] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  336.322715] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  339.045833] tegra194-vi5 15c10000.vi: no reply from camera processor
[  339.046014] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  339.046159] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  339.049882] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  339.122675] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  341.861837] tegra194-vi5 15c10000.vi: no reply from camera processor
[  341.861996] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  341.862174] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  341.868830] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  341.962555] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  344.677844] tegra194-vi5 15c10000.vi: no reply from camera processor
[  344.678027] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  344.678172] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  344.687778] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  344.762539] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  347.493830] tegra194-vi5 15c10000.vi: no reply from camera processor
[  347.494013] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  347.494161] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  347.499835] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  347.562395] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  350.309838] tegra194-vi5 15c10000.vi: no reply from camera processor
[  350.309997] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  350.310138] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  350.316820] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  350.402318] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  353.125848] tegra194-vi5 15c10000.vi: no reply from camera processor
[  353.126034] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  353.126189] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  353.133876] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  353.202243] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  355.941855] tegra194-vi5 15c10000.vi: no reply from camera processor
[  355.942013] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  355.942189] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  355.949881] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  356.042162] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  358.757839] tegra194-vi5 15c10000.vi: no reply from camera processor
[  358.757996] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  358.758143] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  358.760842] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  358.842093] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  361.573841] tegra194-vi5 15c10000.vi: no reply from camera processor
[  361.574007] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  361.574157] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  361.580817] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  361.641999] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  364.389854] tegra194-vi5 15c10000.vi: no reply from camera processor
[  364.390038] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  364.390179] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  364.396783] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  364.441913] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  366.949833] tegra194-vi5 15c10000.vi: no reply from camera processor
[  366.950022] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  366.950176] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  366.953927] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  367.001872] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  369.509837] tegra194-vi5 15c10000.vi: no reply from camera processor
[  369.509994] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  369.510163] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  369.517940] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  369.561793] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  372.069843] tegra194-vi5 15c10000.vi: no reply from camera processor
[  372.070016] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  372.070187] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  372.080877] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  372.161710] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  374.885828] tegra194-vi5 15c10000.vi: no reply from camera processor
[  374.885989] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  374.886134] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  374.892824] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  374.961653] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  377.701838] tegra194-vi5 15c10000.vi: no reply from camera processor
[  377.702014] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  377.702161] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  377.704900] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  377.761555] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  380.261940] tegra194-vi5 15c10000.vi: no reply from camera processor
[  380.262346] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  380.262520] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  380.266861] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  380.321577] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  383.077864] tegra194-vi5 15c10000.vi: no reply from camera processor
[  383.078023] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  383.078165] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  383.084845] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  383.161387] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  385.893895] tegra194-vi5 15c10000.vi: no reply from camera processor
[  385.894051] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  385.894192] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  385.898946] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  385.961372] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  388.709837] tegra194-vi5 15c10000.vi: no reply from camera processor
[  388.709995] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  388.710169] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  388.718813] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  388.801238] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  391.525830] tegra194-vi5 15c10000.vi: no reply from camera processor
[  391.525991] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  391.526160] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  391.533867] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  391.601167] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  394.341836] tegra194-vi5 15c10000.vi: no reply from camera processor
[  394.341996] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  394.342143] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  394.350852] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  394.401086] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  396.901836] tegra194-vi5 15c10000.vi: no reply from camera processor
[  396.902021] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  396.902171] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  396.909907] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  397.001017] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  399.717837] tegra194-vi5 15c10000.vi: no reply from camera processor
[  399.717995] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  399.718138] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  399.725882] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  399.800956] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  402.533829] tegra194-vi5 15c10000.vi: no reply from camera processor
[  402.533988] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  402.534137] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  402.541875] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  402.640846] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  405.349832] tegra194-vi5 15c10000.vi: no reply from camera processor
[  405.349989] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  405.350135] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  405.356824] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  405.400760] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  407.909850] tegra194-vi5 15c10000.vi: no reply from camera processor
[  407.910016] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  407.910175] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  407.912935] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  407.960701] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  410.469852] tegra194-vi5 15c10000.vi: no reply from camera processor
[  410.470014] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  410.470156] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  410.473943] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  410.560630] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  413.285834] tegra194-vi5 15c10000.vi: no reply from camera processor
[  413.286000] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  413.286160] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  413.289868] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  413.360549] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  416.101836] tegra194-vi5 15c10000.vi: no reply from camera processor
[  416.101994] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  416.102159] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  416.108838] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  416.200456] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  418.917844] tegra194-vi5 15c10000.vi: no reply from camera processor
[  418.918003] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  418.918171] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  418.924843] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  419.000381] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  421.733835] tegra194-vi5 15c10000.vi: no reply from camera processor
[  421.734017] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  421.734167] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  421.738431] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  421.800299] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  424.549833] tegra194-vi5 15c10000.vi: no reply from camera processor
[  424.549998] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  424.550157] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  424.554077] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  424.640253] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  425.858060] usb 2-3.4: new SuperSpeed USB device number 3 using tegra-xusb
[  425.946292] usb 2-3.4: New USB device found, idVendor=13fe, idProduct=6300
[  425.946302] usb 2-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  425.946308] usb 2-3.4: Product: Miniking
[  425.946312] usb 2-3.4: Manufacturer: aigo
[  425.946316] usb 2-3.4: SerialNumber: 07009CFE01428614
[  425.950940] usb-storage 2-3.4:1.0: USB Mass Storage device detected
[  425.951369] scsi host1: usb-storage 2-3.4:1.0
[  425.955418] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[  425.955586] tegra-asoc: sound: snd_soc_register_card failed (-517)
[  427.365848] tegra194-vi5 15c10000.vi: no reply from camera processor
[  427.366010] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  427.366187] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  427.370836] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  427.440151] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  427.453478] scsi 1:0:0:0: Direct-Access     aigo     U330             PMAP PQ: 0 ANSI: 6
[  427.455462] sd 1:0:0:0: [sda] 122880000 512-byte logical blocks: (62.9 GB/58.6 GiB)
[  427.457282] sd 1:0:0:0: [sda] Write Protect is off
[  427.457398] sd 1:0:0:0: [sda] Mode Sense: 23 00 00 00
[  427.457562] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[  427.457735] tegra-asoc: sound: snd_soc_register_card failed (-517)
[  427.457752] sd 1:0:0:0: [sda] No Caching mode page found
[  427.457756] sd 1:0:0:0: [sda] Assuming drive cache: write through
[  427.466102]  sda: sda1
[  427.468319] sd 1:0:0:0: [sda] Attached SCSI removable disk
[  429.725981] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  430.185876] tegra194-vi5 15c10000.vi: no reply from camera processor
[  430.186019] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  430.186159] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  430.193860] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  430.240067] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  432.741839] tegra194-vi5 15c10000.vi: no reply from camera processor
[  432.741986] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  432.742154] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  432.744814] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  432.799986] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  435.301833] tegra194-vi5 15c10000.vi: no reply from camera processor
[  435.301978] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  435.302119] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  435.309912] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  435.359916] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  437.861835] tegra194-vi5 15c10000.vi: no reply from camera processor
[  437.862019] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  437.862160] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  437.864930] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  437.919857] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  440.421841] tegra194-vi5 15c10000.vi: no reply from camera processor
[  440.421999] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  440.422145] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  440.425882] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  440.479801] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  442.981837] tegra194-vi5 15c10000.vi: no reply from camera processor
[  442.981984] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  442.982149] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  442.986899] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  443.039700] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  445.541837] tegra194-vi5 15c10000.vi: no reply from camera processor
[  445.541996] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  445.542161] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  445.544892] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  445.599630] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  448.101850] tegra194-vi5 15c10000.vi: no reply from camera processor
[  448.102002] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  448.102166] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  448.104797] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  448.159553] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  450.661836] tegra194-vi5 15c10000.vi: no reply from camera processor
[  450.662012] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  450.662156] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  450.664858] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  450.759522] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  453.477846] tegra194-vi5 15c10000.vi: no reply from camera processor
[  453.477993] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  453.478129] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  453.480881] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  453.599402] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  456.293845] tegra194-vi5 15c10000.vi: no reply from camera processor
[  456.294002] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  456.294168] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  456.297884] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  456.359322] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  459.109839] tegra194-vi5 15c10000.vi: no reply from camera processor
[  459.110024] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  459.110173] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  459.113891] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  459.199273] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  461.925874] tegra194-vi5 15c10000.vi: no reply from camera processor
[  461.926028] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  461.926178] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  461.929892] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  461.999169] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  464.741844] tegra194-vi5 15c10000.vi: no reply from camera processor
[  464.741999] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  464.742167] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  464.744877] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  464.799120] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  467.301875] tegra194-vi5 15c10000.vi: no reply from camera processor
[  467.302022] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  467.302190] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  467.309881] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  467.359019] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  469.861849] tegra194-vi5 15c10000.vi: no reply from camera processor
[  469.862002] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  469.862171] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  469.865886] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x39
[  469.866056] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x41
[  469.866196] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x37
[  469.869753] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  469.918949] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  472.421856] tegra194-vi5 15c10000.vi: no reply from camera processor
[  472.422041] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  472.422190] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  472.425055] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  472.478874] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  474.981861] tegra194-vi5 15c10000.vi: no reply from camera processor
[  474.982015] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  474.982189] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  474.984862] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  475.038792] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  477.541871] tegra194-vi5 15c10000.vi: no reply from camera processor
[  477.542045] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  477.542199] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  477.544926] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  477.598718] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  480.101848] tegra194-vi5 15c10000.vi: no reply from camera processor
[  480.102002] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  480.102172] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  480.107728] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  480.158679] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  482.661857] tegra194-vi5 15c10000.vi: no reply from camera processor
[  482.662011] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  482.662177] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  482.665883] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  482.718564] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  485.221845] tegra194-vi5 15c10000.vi: no reply from camera processor
[  485.222036] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  485.222182] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  485.225902] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  485.278498] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  487.781861] tegra194-vi5 15c10000.vi: no reply from camera processor
[  487.782029] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  487.782167] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  487.784883] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  487.838419] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  490.341864] tegra194-vi5 15c10000.vi: no reply from camera processor
[  490.342018] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  490.342158] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  490.345912] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  490.398366] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  492.901846] tegra194-vi5 15c10000.vi: no reply from camera processor
[  492.902007] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  492.902175] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  492.905932] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  492.958292] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  495.461847] tegra194-vi5 15c10000.vi: no reply from camera processor
[  495.462001] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  495.462165] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  495.467554] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  495.558222] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  498.277838] tegra194-vi5 15c10000.vi: no reply from camera processor
[  498.278007] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  498.278149] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  498.284891] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  498.358120] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  501.093851] tegra194-vi5 15c10000.vi: no reply from camera processor
[  501.094005] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  501.094170] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  501.098438] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  501.198049] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  503.909890] tegra194-vi5 15c10000.vi: no reply from camera processor
[  503.910044] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  503.910183] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  503.913922] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  503.957988] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  506.469862] tegra194-vi5 15c10000.vi: no reply from camera processor
[  506.470020] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  506.470192] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  506.475867] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  506.517879] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  509.029854] tegra194-vi5 15c10000.vi: no reply from camera processor
[  509.030047] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  509.030194] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  509.032837] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  509.077877] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  511.589853] tegra194-vi5 15c10000.vi: no reply from camera processor
[  511.590012] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  511.590181] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  511.592833] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  511.637732] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  514.149861] tegra194-vi5 15c10000.vi: no reply from camera processor
[  514.150020] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  514.150165] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  514.152858] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  514.197655] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  516.709847] tegra194-vi5 15c10000.vi: no reply from camera processor
[  516.710035] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  516.710206] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  516.713920] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  516.757596] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  519.269859] tegra194-vi5 15c10000.vi: no reply from camera processor
[  519.270018] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  519.270160] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  519.274244] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  519.317524] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 64
[  521.829855] tegra194-vi5 15c10000.vi: no reply from camera processor
[  521.830014] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  521.830158] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  521.833906] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  521.877437] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  524.389877] tegra194-vi5 15c10000.vi: no reply from camera processor
[  524.390037] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  524.390189] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  524.393961] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  524.437379] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  526.949854] tegra194-vi5 15c10000.vi: no reply from camera processor
[  526.950019] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  526.950162] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  526.952826] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  526.997331] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  529.509848] tegra194-vi5 15c10000.vi: no reply from camera processor
[  529.510007] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  529.510186] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  529.514352] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  529.557225] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  532.069853] tegra194-vi5 15c10000.vi: no reply from camera processor
[  532.070006] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  532.070166] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  532.072869] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  532.117149] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  534.629869] tegra194-vi5 15c10000.vi: no reply from camera processor
[  534.630025] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  534.630168] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  534.635879] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  534.677077] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  537.189897] tegra194-vi5 15c10000.vi: no reply from camera processor
[  537.190050] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  537.190197] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  537.193848] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  537.276986] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  540.005848] tegra194-vi5 15c10000.vi: no reply from camera processor
[  540.006031] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  540.006188] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  540.009900] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  540.076912] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  542.821848] tegra194-vi5 15c10000.vi: no reply from camera processor
[  542.822027] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  542.822169] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  542.824871] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  542.876831] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  545.381850] tegra194-vi5 15c10000.vi: no reply from camera processor
[  545.382009] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  545.382150] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  545.384853] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  545.436772] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  547.941846] tegra194-vi5 15c10000.vi: no reply from camera processor
[  547.942002] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  547.942162] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  547.944982] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  547.996695] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  550.501858] tegra194-vi5 15c10000.vi: no reply from camera processor
[  550.502015] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  550.502156] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  550.507905] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  550.556623] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  553.061862] tegra194-vi5 15c10000.vi: no reply from camera processor
[  553.062040] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  553.062180] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  553.065925] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  553.116548] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  555.621833] tegra194-vi5 15c10000.vi: no reply from camera processor
[  555.621995] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  555.622141] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  555.624915] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  555.676500] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  558.181859] tegra194-vi5 15c10000.vi: no reply from camera processor
[  558.182015] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  558.182179] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  558.185987] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  558.236416] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  560.741835] tegra194-vi5 15c10000.vi: no reply from camera processor
[  560.741994] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  560.742166] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  560.745880] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  560.765855] [RCE] WARNING: t194/vi5.c:459 [vi5_channel_disable] "ch 35 ABORT trial# 2/5 unsuccessful"
[  560.796316] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  563.301839] tegra194-vi5 15c10000.vi: no reply from camera processor
[  563.302001] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  563.302146] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  563.305865] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  563.356240] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  565.861857] tegra194-vi5 15c10000.vi: no reply from camera processor
[  565.862008] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  565.862186] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  565.868890] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  565.916168] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  568.421847] tegra194-vi5 15c10000.vi: no reply from camera processor
[  568.422008] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  568.422155] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  568.426838] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  568.476095] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  570.981879] tegra194-vi5 15c10000.vi: no reply from camera processor
[  570.982036] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  570.982179] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  570.984858] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  571.076004] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  573.797860] tegra194-vi5 15c10000.vi: no reply from camera processor
[  573.798019] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  573.798195] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  573.806796] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  573.875947] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  576.613849] tegra194-vi5 15c10000.vi: no reply from camera processor
[  576.614010] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  576.614156] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  576.616870] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  576.675852] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  579.429841] tegra194-vi5 15c10000.vi: no reply from camera processor
[  579.430000] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  579.430168] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  579.433873] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  579.475769] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  581.989843] tegra194-vi5 15c10000.vi: no reply from camera processor
[  581.990028] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  581.990171] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  581.995431] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  582.035706] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  584.549854] tegra194-vi5 15c10000.vi: no reply from camera processor
[  584.550012] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  584.550158] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  584.555456] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  584.595632] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  587.109846] tegra194-vi5 15c10000.vi: no reply from camera processor
[  587.110002] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  587.110151] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  587.115420] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  587.195546] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  589.925837] tegra194-vi5 15c10000.vi: no reply from camera processor
[  589.926023] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  589.926175] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  589.929889] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  589.995478] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  592.741858] tegra194-vi5 15c10000.vi: no reply from camera processor
[  592.742017] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  592.742190] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  592.744849] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  592.795397] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  595.301843] tegra194-vi5 15c10000.vi: no reply from camera processor
[  595.302009] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  595.302152] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  595.304910] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  595.329960] [RCE] Configuring VI GoS.
[  595.329981] [RCE] VM GOS[#0] addr=0xfbd00000
[  595.329997] [RCE] VM GOS[#1] addr=0xfbd01000
[  595.330012] [RCE] VM GOS[#2] addr=0xfbd02000
[  595.330026] [RCE] VM GOS[#3] addr=0xfbd03000
[  595.330040] [RCE] VM GOS[#4] addr=0xfbd04000
[  595.330054] [RCE] VM GOS[#5] addr=0xfbd05000
[  595.355311] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  597.861885] tegra194-vi5 15c10000.vi: no reply from camera processor
[  597.862067] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  597.862211] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  597.866016] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  597.913945] [RCE] Configuring VI GoS.
[  597.913960] [RCE] VM GOS[#0] addr=0xfbd00000
[  597.913969] [RCE] VM GOS[#1] addr=0xfbd01000
[  597.913984] [RCE] VM GOS[#2] addr=0xfbd02000
[  597.913993] [RCE] VM GOS[#3] addr=0xfbd03000
[  597.914001] [RCE] VM GOS[#4] addr=0xfbd04000
[  597.914037] [RCE] VM GOS[#5] addr=0xfbd05000
[  597.915264] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  600.421886] tegra194-vi5 15c10000.vi: no reply from camera processor
[  600.422042] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  600.422225] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  600.425904] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  600.433927] [RCE] Configuring VI GoS.
[  600.433940] [RCE] VM GOS[#0] addr=0xfbd00000
[  600.433962] [RCE] VM GOS[#1] addr=0xfbd01000
[  600.433977] [RCE] VM GOS[#2] addr=0xfbd02000
[  600.433982] [RCE] VM GOS[#3] addr=0xfbd03000
[  600.433987] [RCE] VM GOS[#4] addr=0xfbd04000
[  600.433992] [RCE] VM GOS[#5] addr=0xfbd05000
[  600.475159] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  602.981847] tegra194-vi5 15c10000.vi: no reply from camera processor
[  602.982028] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  602.982178] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  602.984892] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  603.009934] [RCE] Configuring VI GoS.
[  603.009945] [RCE] VM GOS[#0] addr=0xfbd00000
[  603.009950] [RCE] VM GOS[#1] addr=0xfbd01000
[  603.009956] [RCE] VM GOS[#2] addr=0xfbd02000
[  603.009961] [RCE] VM GOS[#3] addr=0xfbd03000
[  603.009966] [RCE] VM GOS[#4] addr=0xfbd04000
[  603.009994] [RCE] VM GOS[#5] addr=0xfbd05000
[  603.035081] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  605.541843] tegra194-vi5 15c10000.vi: no reply from camera processor
[  605.542000] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  605.542170] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  605.546968] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  605.585924] [RCE] Configuring VI GoS.
[  605.585935] [RCE] VM GOS[#0] addr=0xfbd00000
[  605.585940] [RCE] VM GOS[#1] addr=0xfbd01000
[  605.585945] [RCE] VM GOS[#2] addr=0xfbd02000
[  605.585949] [RCE] VM GOS[#3] addr=0xfbd03000
[  605.585954] [RCE] VM GOS[#4] addr=0xfbd04000
[  605.585959] [RCE] VM GOS[#5] addr=0xfbd05000
[  605.595060] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  608.101836] tegra194-vi5 15c10000.vi: no reply from camera processor
[  608.101993] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  608.102135] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  608.104939] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  608.105969] [RCE] Configuring VI GoS.
[  608.105989] [RCE] VM GOS[#0] addr=0xfbd00000
[  608.105997] [RCE] VM GOS[#1] addr=0xfbd01000
[  608.106006] [RCE] VM GOS[#2] addr=0xfbd02000
[  608.106010] [RCE] VM GOS[#3] addr=0xfbd03000
[  608.106014] [RCE] VM GOS[#4] addr=0xfbd04000
[  608.106019] [RCE] VM GOS[#5] addr=0xfbd05000
[  608.154942] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  610.661833] tegra194-vi5 15c10000.vi: no reply from camera processor
[  610.661993] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  610.662133] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  610.664911] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  610.681924] [RCE] Configuring VI GoS.
[  610.681934] [RCE] VM GOS[#0] addr=0xfbd00000
[  610.681938] [RCE] VM GOS[#1] addr=0xfbd01000
[  610.681943] [RCE] VM GOS[#2] addr=0xfbd02000
[  610.681947] [RCE] VM GOS[#3] addr=0xfbd03000
[  610.681951] [RCE] VM GOS[#4] addr=0xfbd04000
[  610.681955] [RCE] VM GOS[#5] addr=0xfbd05000
[  610.714854] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  613.221837] tegra194-vi5 15c10000.vi: no reply from camera processor
[  613.221992] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  613.222138] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  613.224947] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  613.257862] [RCE] Configuring VI GoS.
[  613.257872] [RCE] VM GOS[#0] addr=0xfbd00000
[  613.257878] [RCE] VM GOS[#1] addr=0xfbd01000
[  613.257883] [RCE] VM GOS[#2] addr=0xfbd02000
[  613.257888] [RCE] VM GOS[#3] addr=0xfbd03000
[  613.257892] [RCE] VM GOS[#4] addr=0xfbd04000
[  613.257897] [RCE] VM GOS[#5] addr=0xfbd05000
[  613.274788] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  615.781864] tegra194-vi5 15c10000.vi: no reply from camera processor
[  615.782021] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  615.782162] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  615.785969] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  615.833896] [RCE] Configuring VI GoS.
[  615.833906] [RCE] VM GOS[#0] addr=0xfbd00000
[  615.833911] [RCE] VM GOS[#1] addr=0xfbd01000
[  615.833915] [RCE] VM GOS[#2] addr=0xfbd02000
[  615.833920] [RCE] VM GOS[#3] addr=0xfbd03000
[  615.833925] [RCE] VM GOS[#4] addr=0xfbd04000
[  615.833929] [RCE] VM GOS[#5] addr=0xfbd05000
[  615.834695] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  618.341850] tegra194-vi5 15c10000.vi: no reply from camera processor
[  618.342041] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  618.342193] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  618.346018] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  618.353917] [RCE] Configuring VI GoS.
[  618.353927] [RCE] VM GOS[#0] addr=0xfbd00000
[  618.353932] [RCE] VM GOS[#1] addr=0xfbd01000
[  618.353937] [RCE] VM GOS[#2] addr=0xfbd02000
[  618.353942] [RCE] VM GOS[#3] addr=0xfbd03000
[  618.353946] [RCE] VM GOS[#4] addr=0xfbd04000
[  618.353951] [RCE] VM GOS[#5] addr=0xfbd05000
[  618.394690] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  620.901878] tegra194-vi5 15c10000.vi: no reply from camera processor
[  620.902031] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  620.902179] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  620.905888] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  620.929882] [RCE] Configuring VI GoS.
[  620.929892] [RCE] VM GOS[#0] addr=0xfbd00000
[  620.929897] [RCE] VM GOS[#1] addr=0xfbd01000
[  620.929902] [RCE] VM GOS[#2] addr=0xfbd02000
[  620.929906] [RCE] VM GOS[#3] addr=0xfbd03000
[  620.929912] [RCE] VM GOS[#4] addr=0xfbd04000
[  620.929917] [RCE] VM GOS[#5] addr=0xfbd05000
[  620.954554] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  623.461847] tegra194-vi5 15c10000.vi: no reply from camera processor
[  623.462007] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  623.462172] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  623.465882] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  623.505909] [RCE] Configuring VI GoS.
[  623.505921] [RCE] VM GOS[#0] addr=0xfbd00000
[  623.505926] [RCE] VM GOS[#1] addr=0xfbd01000
[  623.505954] [RCE] VM GOS[#2] addr=0xfbd02000
[  623.505959] [RCE] VM GOS[#3] addr=0xfbd03000
[  623.505963] [RCE] VM GOS[#4] addr=0xfbd04000
[  623.505968] [RCE] VM GOS[#5] addr=0xfbd05000
[  623.514542] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  626.021866] tegra194-vi5 15c10000.vi: no reply from camera processor
[  626.022027] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  626.022175] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  626.025986] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  626.074435] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  626.081921] [RCE] Configuring VI GoS.
[  626.081932] [RCE] VM GOS[#0] addr=0xfbd00000
[  626.081968] [RCE] VM GOS[#1] addr=0xfbd01000
[  626.081973] [RCE] VM GOS[#2] addr=0xfbd02000
[  626.081978] [RCE] VM GOS[#3] addr=0xfbd03000
[  626.081983] [RCE] VM GOS[#4] addr=0xfbd04000
[  626.082139] [RCE] VM GOS[#5] addr=0xfbd05000
[  628.581857] tegra194-vi5 15c10000.vi: no reply from camera processor
[  628.582002] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  628.582143] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  628.587716] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  628.601890] [RCE] Configuring VI GoS.
[  628.601900] [RCE] VM GOS[#0] addr=0xfbd00000
[  628.601905] [RCE] VM GOS[#1] addr=0xfbd01000
[  628.601910] [RCE] VM GOS[#2] addr=0xfbd02000
[  628.601915] [RCE] VM GOS[#3] addr=0xfbd03000
[  628.601919] [RCE] VM GOS[#4] addr=0xfbd04000
[  628.601924] [RCE] VM GOS[#5] addr=0xfbd05000
[  628.634336] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  631.141831] tegra194-vi5 15c10000.vi: no reply from camera processor
[  631.141990] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  631.142141] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  631.144909] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  631.181937] [RCE] Configuring VI GoS.
[  631.181947] [RCE] VM GOS[#0] addr=0xfbd00000
[  631.181952] [RCE] VM GOS[#1] addr=0xfbd01000
[  631.181957] [RCE] VM GOS[#2] addr=0xfbd02000
[  631.181962] [RCE] VM GOS[#3] addr=0xfbd03000
[  631.181966] [RCE] VM GOS[#4] addr=0xfbd04000
[  631.181972] [RCE] VM GOS[#5] addr=0xfbd05000
[  631.234287] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  633.957843] tegra194-vi5 15c10000.vi: no reply from camera processor
[  633.957987] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  633.958118] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  633.966919] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  633.981904] [RCE] Configuring VI GoS.
[  633.981952] [RCE] VM GOS[#0] addr=0xfbd00000
[  633.981957] [RCE] VM GOS[#1] addr=0xfbd01000
[  633.982012] [RCE] VM GOS[#2] addr=0xfbd02000
[  633.982017] [RCE] VM GOS[#3] addr=0xfbd03000
[  633.982021] [RCE] VM GOS[#4] addr=0xfbd04000
[  633.982025] [RCE] VM GOS[#5] addr=0xfbd05000
[  634.034179] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  636.773880] tegra194-vi5 15c10000.vi: no reply from camera processor
[  636.774036] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  636.774182] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  636.776833] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x39
[  636.777031] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x41
[  636.777171] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x37
[  636.777338] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  636.781910] [RCE] Configuring VI GoS.
[  636.781919] [RCE] VM GOS[#0] addr=0xfbd00000
[  636.781924] [RCE] VM GOS[#1] addr=0xfbd01000
[  636.781929] [RCE] VM GOS[#2] addr=0xfbd02000
[  636.781975] [RCE] VM GOS[#3] addr=0xfbd03000
[  636.781980] [RCE] VM GOS[#4] addr=0xfbd04000
[  636.781984] [RCE] VM GOS[#5] addr=0xfbd05000
[  636.834134] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  639.589841] tegra194-vi5 15c10000.vi: no reply from camera processor
[  639.590001] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  639.590164] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  639.593911] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  639.637880] [RCE] Configuring VI GoS.
[  639.637890] [RCE] VM GOS[#0] addr=0xfbd00000
[  639.637895] [RCE] VM GOS[#1] addr=0xfbd01000
[  639.637899] [RCE] VM GOS[#2] addr=0xfbd02000
[  639.637904] [RCE] VM GOS[#3] addr=0xfbd03000
[  639.637909] [RCE] VM GOS[#4] addr=0xfbd04000
[  639.637913] [RCE] VM GOS[#5] addr=0xfbd05000
[  639.674062] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  642.405848] tegra194-vi5 15c10000.vi: no reply from camera processor
[  642.406005] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  642.406156] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  642.410931] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  642.437882] [RCE] Configuring VI GoS.
[  642.437892] [RCE] VM GOS[#0] addr=0xfbd00000
[  642.437897] [RCE] VM GOS[#1] addr=0xfbd01000
[  642.437902] [RCE] VM GOS[#2] addr=0xfbd02000
[  642.437907] [RCE] VM GOS[#3] addr=0xfbd03000
[  642.437911] [RCE] VM GOS[#4] addr=0xfbd04000
[  642.437916] [RCE] VM GOS[#5] addr=0xfbd05000
[  642.473923] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  645.221853] tegra194-vi5 15c10000.vi: no reply from camera processor
[  645.222033] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  645.222181] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  645.225946] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  645.237891] [RCE] Configuring VI GoS.
[  645.237900] [RCE] VM GOS[#0] addr=0xfbd00000
[  645.237906] [RCE] VM GOS[#1] addr=0xfbd01000
[  645.237911] [RCE] VM GOS[#2] addr=0xfbd02000
[  645.237915] [RCE] VM GOS[#3] addr=0xfbd03000
[  645.237920] [RCE] VM GOS[#4] addr=0xfbd04000
[  645.237925] [RCE] VM GOS[#5] addr=0xfbd05000
[  645.313871] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  648.037847] tegra194-vi5 15c10000.vi: no reply from camera processor
[  648.037996] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  648.038134] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  648.040950] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  648.093902] [RCE] Configuring VI GoS.
[  648.093914] [RCE] VM GOS[#0] addr=0xfbd00000
[  648.093919] [RCE] VM GOS[#1] addr=0xfbd01000
[  648.093924] [RCE] VM GOS[#2] addr=0xfbd02000
[  648.093928] [RCE] VM GOS[#3] addr=0xfbd03000
[  648.093933] [RCE] VM GOS[#4] addr=0xfbd04000
[  648.093938] [RCE] VM GOS[#5] addr=0xfbd05000
[  648.113765] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  650.853841] tegra194-vi5 15c10000.vi: no reply from camera processor
[  650.854031] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  650.854176] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  650.857909] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  650.901872] [RCE] Configuring VI GoS.
[  650.901883] [RCE] VM GOS[#0] addr=0xfbd00000
[  650.901888] [RCE] VM GOS[#1] addr=0xfbd01000
[  650.901893] [RCE] VM GOS[#2] addr=0xfbd02000
[  650.901898] [RCE] VM GOS[#3] addr=0xfbd03000
[  650.901902] [RCE] VM GOS[#4] addr=0xfbd04000
[  650.901907] [RCE] VM GOS[#5] addr=0xfbd05000
[  650.913693] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  653.669842] tegra194-vi5 15c10000.vi: no reply from camera processor
[  653.670000] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  653.670141] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  653.672902] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  653.701880] [RCE] Configuring VI GoS.
[  653.701890] [RCE] VM GOS[#0] addr=0xfbd00000
[  653.701895] [RCE] VM GOS[#1] addr=0xfbd01000
[  653.701900] [RCE] VM GOS[#2] addr=0xfbd02000
[  653.701904] [RCE] VM GOS[#3] addr=0xfbd03000
[  653.701908] [RCE] VM GOS[#4] addr=0xfbd04000
[  653.701912] [RCE] VM GOS[#5] addr=0xfbd05000
[  653.753602] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  656.485875] tegra194-vi5 15c10000.vi: no reply from camera processor
[  656.486054] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  656.486199] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  656.492903] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  656.509913] [RCE] Configuring VI GoS.
[  656.509923] [RCE] VM GOS[#0] addr=0xfbd00000
[  656.509928] [RCE] VM GOS[#1] addr=0xfbd01000
[  656.509933] [RCE] VM GOS[#2] addr=0xfbd02000
[  656.509939] [RCE] VM GOS[#3] addr=0xfbd03000
[  656.509943] [RCE] VM GOS[#4] addr=0xfbd04000
[  656.509948] [RCE] VM GOS[#5] addr=0xfbd05000
[  656.553522] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  659.301894] tegra194-vi5 15c10000.vi: no reply from camera processor
[  659.302044] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  659.302185] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  659.304893] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  659.313945] [RCE] Configuring VI GoS.
[  659.313956] [RCE] VM GOS[#0] addr=0xfbd00000
[  659.313961] [RCE] VM GOS[#1] addr=0xfbd01000
[  659.313966] [RCE] VM GOS[#2] addr=0xfbd02000
[  659.313971] [RCE] VM GOS[#3] addr=0xfbd03000
[  659.313975] [RCE] VM GOS[#4] addr=0xfbd04000
[  659.313980] [RCE] VM GOS[#5] addr=0xfbd05000
[  659.353483] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  661.861850] tegra194-vi5 15c10000.vi: no reply from camera processor
[  661.862007] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  661.862174] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  661.864881] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  661.893927] [RCE] Configuring VI GoS.
[  661.893937] [RCE] VM GOS[#0] addr=0xfbd00000
[  661.893942] [RCE] VM GOS[#1] addr=0xfbd01000
[  661.893947] [RCE] VM GOS[#2] addr=0xfbd02000
[  661.893951] [RCE] VM GOS[#3] addr=0xfbd03000
[  661.893955] [RCE] VM GOS[#4] addr=0xfbd04000
[  661.893960] [RCE] VM GOS[#5] addr=0xfbd05000
[  661.913356] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  664.421839] tegra194-vi5 15c10000.vi: no reply from camera processor
[  664.422000] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  664.422164] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  664.424924] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  664.469891] [RCE] Configuring VI GoS.
[  664.469901] [RCE] VM GOS[#0] addr=0xfbd00000
[  664.469907] [RCE] VM GOS[#1] addr=0xfbd01000
[  664.469913] [RCE] VM GOS[#2] addr=0xfbd02000
[  664.469917] [RCE] VM GOS[#3] addr=0xfbd03000
[  664.469922] [RCE] VM GOS[#4] addr=0xfbd04000
[  664.469926] [RCE] VM GOS[#5] addr=0xfbd05000
[  664.473288] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 64
[  666.981867] tegra194-vi5 15c10000.vi: no reply from camera processor
[  666.982049] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  666.982207] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  666.984927] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  667.001937] [RCE] Configuring VI GoS.
[  667.001944] [RCE] VM GOS[#0] addr=0xfbd00000
[  667.001949] [RCE] VM GOS[#1] addr=0xfbd01000
[  667.001952] [RCE] VM GOS[#2] addr=0xfbd02000
[  667.001956] [RCE] VM GOS[#3] addr=0xfbd03000
[  667.001960] [RCE] VM GOS[#4] addr=0xfbd04000
[  667.001964] [RCE] VM GOS[#5] addr=0xfbd05000
[  667.033209] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 64
[  669.541849] tegra194-vi5 15c10000.vi: no reply from camera processor
[  669.542023] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  669.542164] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  669.550919] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  669.585905] [RCE] Configuring VI GoS.
[  669.585915] [RCE] VM GOS[#0] addr=0xfbd00000
[  669.585919] [RCE] VM GOS[#1] addr=0xfbd01000
[  669.585923] [RCE] VM GOS[#2] addr=0xfbd02000
[  669.585948] [RCE] VM GOS[#3] addr=0xfbd03000
[  669.585952] [RCE] VM GOS[#4] addr=0xfbd04000
[  669.585956] [RCE] VM GOS[#5] addr=0xfbd05000
[  669.593132] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  672.101851] tegra194-vi5 15c10000.vi: no reply from camera processor
[  672.102004] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  672.102178] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  672.105010] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  672.105901] [RCE] Configuring VI GoS.
[  672.105920] [RCE] VM GOS[#0] addr=0xfbd00000
[  672.105925] [RCE] VM GOS[#1] addr=0xfbd01000
[  672.105930] [RCE] VM GOS[#2] addr=0xfbd02000
[  672.105935] [RCE] VM GOS[#3] addr=0xfbd03000
[  672.105939] [RCE] VM GOS[#4] addr=0xfbd04000
[  672.105944] [RCE] VM GOS[#5] addr=0xfbd05000
[  672.153116] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  674.661853] tegra194-vi5 15c10000.vi: no reply from camera processor
[  674.662006] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  674.662173] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  674.667515] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  674.681926] [RCE] Configuring VI GoS.
[  674.681938] [RCE] VM GOS[#0] addr=0xfbd00000
[  674.681943] [RCE] VM GOS[#1] addr=0xfbd01000
[  674.681948] [RCE] VM GOS[#2] addr=0xfbd02000
[  674.681952] [RCE] VM GOS[#3] addr=0xfbd03000
[  674.681957] [RCE] VM GOS[#4] addr=0xfbd04000
[  674.681962] [RCE] VM GOS[#5] addr=0xfbd05000
[  674.752989] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  677.477850] tegra194-vi5 15c10000.vi: no reply from camera processor
[  677.478003] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  677.478150] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  677.480916] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  677.481917] [RCE] Configuring VI GoS.
[  677.481928] [RCE] VM GOS[#0] addr=0xfbd00000
[  677.481933] [RCE] VM GOS[#1] addr=0xfbd01000
[  677.481938] [RCE] VM GOS[#2] addr=0xfbd02000
[  677.481943] [RCE] VM GOS[#3] addr=0xfbd03000
[  677.481947] [RCE] VM GOS[#4] addr=0xfbd04000
[  677.481952] [RCE] VM GOS[#5] addr=0xfbd05000
[  677.552943] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  680.293848] tegra194-vi5 15c10000.vi: no reply from camera processor
[  680.294027] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  680.294170] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  680.298295] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  680.337880] [RCE] Configuring VI GoS.
[  680.337892] [RCE] VM GOS[#0] addr=0xfbd00000
[  680.337897] [RCE] VM GOS[#1] addr=0xfbd01000
[  680.337902] [RCE] VM GOS[#2] addr=0xfbd02000
[  680.337907] [RCE] VM GOS[#3] addr=0xfbd03000
[  680.337912] [RCE] VM GOS[#4] addr=0xfbd04000
[  680.337916] [RCE] VM GOS[#5] addr=0xfbd05000
[  680.352827] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  682.853850] tegra194-vi5 15c10000.vi: no reply from camera processor
[  682.854005] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  682.854148] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  682.857008] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  682.857928] [RCE] Configuring VI GoS.
[  682.857940] [RCE] VM GOS[#0] addr=0xfbd00000
[  682.857945] [RCE] VM GOS[#1] addr=0xfbd01000
[  682.857949] [RCE] VM GOS[#2] addr=0xfbd02000
[  682.857954] [RCE] VM GOS[#3] addr=0xfbd03000
[  682.857959] [RCE] VM GOS[#4] addr=0xfbd04000
[  682.857963] [RCE] VM GOS[#5] addr=0xfbd05000
[  682.912784] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  685.413845] tegra194-vi5 15c10000.vi: no reply from camera processor
[  685.414001] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  685.414169] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  685.416921] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  685.433882] [RCE] Configuring VI GoS.
[  685.433894] [RCE] VM GOS[#0] addr=0xfbd00000
[  685.433899] [RCE] VM GOS[#1] addr=0xfbd01000
[  685.433904] [RCE] VM GOS[#2] addr=0xfbd02000
[  685.433908] [RCE] VM GOS[#3] addr=0xfbd03000
[  685.433913] [RCE] VM GOS[#4] addr=0xfbd04000
[  685.433918] [RCE] VM GOS[#5] addr=0xfbd05000
[  685.472661] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  687.973851] tegra194-vi5 15c10000.vi: no reply from camera processor
[  687.974005] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  687.974176] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  687.978067] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  688.009911] [RCE] Configuring VI GoS.
[  688.009922] [RCE] VM GOS[#0] addr=0xfbd00000
[  688.009928] [RCE] VM GOS[#1] addr=0xfbd01000
[  688.009933] [RCE] VM GOS[#2] addr=0xfbd02000
[  688.009938] [RCE] VM GOS[#3] addr=0xfbd03000
[  688.009942] [RCE] VM GOS[#4] addr=0xfbd04000
[  688.009947] [RCE] VM GOS[#5] addr=0xfbd05000
[  688.032591] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  690.533852] tegra194-vi5 15c10000.vi: no reply from camera processor
[  690.534005] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  690.534167] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  690.536973] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  690.589922] [RCE] Configuring VI GoS.
[  690.589933] [RCE] VM GOS[#0] addr=0xfbd00000
[  690.589938] [RCE] VM GOS[#1] addr=0xfbd01000
[  690.589942] [RCE] VM GOS[#2] addr=0xfbd02000
[  690.589962] [RCE] VM GOS[#3] addr=0xfbd03000
[  690.589967] [RCE] VM GOS[#4] addr=0xfbd04000
[  690.589971] [RCE] VM GOS[#5] addr=0xfbd05000
[  690.592515] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  693.093853] tegra194-vi5 15c10000.vi: no reply from camera processor
[  693.094009] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  693.094150] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  693.097950] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  693.113914] [RCE] Configuring VI GoS.
[  693.113926] [RCE] VM GOS[#0] addr=0xfbd00000
[  693.113932] [RCE] VM GOS[#1] addr=0xfbd01000
[  693.113937] [RCE] VM GOS[#2] addr=0xfbd02000
[  693.113941] [RCE] VM GOS[#3] addr=0xfbd03000
[  693.113946] [RCE] VM GOS[#4] addr=0xfbd04000
[  693.113951] [RCE] VM GOS[#5] addr=0xfbd05000
[  693.192432] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  695.909892] tegra194-vi5 15c10000.vi: no reply from camera processor
[  695.910044] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  695.910190] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  695.912918] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  695.913883] [RCE] Configuring VI GoS.
[  695.913895] [RCE] VM GOS[#0] addr=0xfbd00000
[  695.913900] [RCE] VM GOS[#1] addr=0xfbd01000
[  695.913905] [RCE] VM GOS[#2] addr=0xfbd02000
[  695.913910] [RCE] VM GOS[#3] addr=0xfbd03000
[  695.913914] [RCE] VM GOS[#4] addr=0xfbd04000
[  695.913919] [RCE] VM GOS[#5] addr=0xfbd05000
[  695.992366] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  698.725855] tegra194-vi5 15c10000.vi: no reply from camera processor
[  698.726012] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  698.726156] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  698.729909] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  698.769874] [RCE] WARNING: t194/vi5.c:459 [vi5_channel_disable] "ch 35 ABORT trial# 2/5 unsuccessful"
[  698.769897] [RCE] Configuring VI GoS.
[  698.769902] [RCE] VM GOS[#0] addr=0xfbd00000
[  698.769906] [RCE] VM GOS[#1] addr=0xfbd01000
[  698.769911] [RCE] VM GOS[#2] addr=0xfbd02000
[  698.769915] [RCE] VM GOS[#3] addr=0xfbd03000
[  698.769920] [RCE] VM GOS[#4] addr=0xfbd04000
[  698.769925] [RCE] VM GOS[#5] addr=0xfbd05000
[  698.792268] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  701.541847] tegra194-vi5 15c10000.vi: no reply from camera processor
[  701.541999] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  701.542167] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  701.545971] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  701.569951] [RCE] Configuring VI GoS.
[  701.569963] [RCE] VM GOS[#0] addr=0xfbd00000
[  701.569968] [RCE] VM GOS[#1] addr=0xfbd01000
[  701.569973] [RCE] VM GOS[#2] addr=0xfbd02000
[  701.569977] [RCE] VM GOS[#3] addr=0xfbd03000
[  701.569982] [RCE] VM GOS[#4] addr=0xfbd04000
[  701.569987] [RCE] VM GOS[#5] addr=0xfbd05000
[  701.592197] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  704.101892] tegra194-vi5 15c10000.vi: no reply from camera processor
[  704.102047] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  704.102197] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  704.104936] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  704.145911] [RCE] Configuring VI GoS.
[  704.145923] [RCE] VM GOS[#0] addr=0xfbd00000
[  704.145928] [RCE] VM GOS[#1] addr=0xfbd01000
[  704.145933] [RCE] VM GOS[#2] addr=0xfbd02000
[  704.145938] [RCE] VM GOS[#3] addr=0xfbd03000
[  704.145943] [RCE] VM GOS[#4] addr=0xfbd04000
[  704.145947] [RCE] VM GOS[#5] addr=0xfbd05000
[  704.152123] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  706.661853] tegra194-vi5 15c10000.vi: no reply from camera processor
[  706.662008] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  706.662185] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  706.665873] [RCE] WARNING: t194/vi5.c:459 [vi5_channel_disable] "ch 35 ABORT trial# 2/5 unsuccessful"
[  706.665878] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  706.666092] [RCE] Configuring VI GoS.
[  706.666097] [RCE] VM GOS[#0] addr=0xfbd00000
[  706.666102] [RCE] VM GOS[#1] addr=0xfbd01000
[  706.666107] [RCE] VM GOS[#2] addr=0xfbd02000
[  706.666112] [RCE] VM GOS[#3] addr=0xfbd03000
[  706.666117] [RCE] VM GOS[#4] addr=0xfbd04000
[  706.666122] [RCE] VM GOS[#5] addr=0xfbd05000
[  706.712051] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
[  709.221864] tegra194-vi5 15c10000.vi: no reply from camera processor
[  709.222022] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  709.222194] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  709.226518] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  709.241955] [RCE] Configuring VI GoS.
[  709.241966] [RCE] VM GOS[#0] addr=0xfbd00000
[  709.241971] [RCE] VM GOS[#1] addr=0xfbd01000
[  709.241976] [RCE] VM GOS[#2] addr=0xfbd02000
[  709.241995] [RCE] VM GOS[#3] addr=0xfbd03000
[  709.242000] [RCE] VM GOS[#4] addr=0xfbd04000
[  709.242004] [RCE] VM GOS[#5] addr=0xfbd05000
[  709.271967] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 64
the trace.log
trace.log (394.8 KB)
Looking forward to reply soon,thanks.
Still a lot of CHANSEL_NOMATCH that could be the sensor output embedded data line but device define incorrect. Make sure how many embedded line to define the value.
As shown in the diagram, the embedded_data_height should set to “2”. I had set embedded_data_height = “2”,but still same errs.
@admi537
Looks like the embedded data at footer. Current only support embedded data at header.
Please consult with vendor to disable it to try.
