We have an omnivision sensor, for which we wrote a camera driver that works just fine over MIPI.
When we plug the same camera into the serdes pair (MAX9295 ↔ MAX9296), it stops working with the following error
kworker/1:3-1781 [001] .... 154.537183: rtcpu_vinotify_event: tstamp:4983168766 tag:FE channel:0x00 frame:0 vi_tstamp:4982877829 data:0x00000020
kworker/1:3-1781 [001] .... 154.537185: rtcpu_vinotify_event: tstamp:4983168924 tag:FS channel:0x00 frame:0 vi_tstamp:4982917174 data:0x00000010
kworker/1:3-1781 [001] .... 154.537187: rtcpu_vinotify_event: tstamp:4983169063 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4982919096 data:0x00000589
kworker/1:3-1781 [001] .... 154.588149: rtcpu_vinotify_error: tstamp:4983961199 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4983960358 data:0x00000589
kworker/1:3-1781 [001] .... 154.588152: rtcpu_vinotify_event: tstamp:4984185954 tag:FE channel:0x00 frame:0 vi_tstamp:4983919092 data:0x00000020
kworker/1:3-1781 [001] .... 154.588154: rtcpu_vinotify_event: tstamp:4984186092 tag:FS channel:0x00 frame:0 vi_tstamp:4983958436 data:0x00000010
kworker/1:3-1781 [001] .... 154.588156: rtcpu_vinotify_event: tstamp:4984186254 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4983960358 data:0x00000589
kworker/1:3-1781 [001] .... 154.588159: rtcpu_vinotify_error: tstamp:4985002482 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4985001621 data:0x00000589
kworker/1:3-1781 [001] .... 154.588160: rtcpu_vinotify_event: tstamp:4985002804 tag:FE channel:0x00 frame:0 vi_tstamp:4984960354 data:0x00000020
kworker/1:3-1781 [001] .... 154.588162: rtcpu_vinotify_event: tstamp:4985002962 tag:FS channel:0x00 frame:0 vi_tstamp:4984999699 data:0x00000010
kworker/1:3-1781 [001] .... 154.588164: rtcpu_vinotify_event: tstamp:4985003098 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4985001621 data:0x00000589
kworker/1:3-1781 [001] .... 154.639146: rtcpu_vinotify_event: tstamp:4986017131 tag:FE channel:0x00 frame:0 vi_tstamp:4986001617 data:0x00000020
kworker/1:3-1781 [001] .... 154.639149: rtcpu_vinotify_error: tstamp:4986043727 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4986042884 data:0x00000589
kworker/1:3-1781 [001] .... 154.639151: rtcpu_vinotify_event: tstamp:4986356166 tag:FS channel:0x00 frame:0 vi_tstamp:4986040961 data:0x00000010
kworker/1:3-1781 [001] .... 154.639153: rtcpu_vinotify_event: tstamp:4986356325 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4986042884 data:0x00000589
kworker/1:3-1781 [001] .... 154.690145: rtcpu_vinotify_error: tstamp:4987084988 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4987084146 data:0x00000589
kworker/1:3-1781 [001] .... 154.690148: rtcpu_vinotify_event: tstamp:4987373354 tag:FE channel:0x00 frame:0 vi_tstamp:4987042880 data:0x00000020
kworker/1:3-1781 [001] .... 154.690150: rtcpu_vinotify_event: tstamp:4987373511 tag:FS channel:0x00 frame:0 vi_tstamp:4987082223 data:0x00000010
We’ve tried all the debugging tips here: Jetson/l4t/Camera BringUp - eLinux.org
We’ve also set the embedded_data_height correctly because it works on the other board
I’m also not configuring any virtual channel to data type remapping on the MAX929* chips
I would appreciate any tips on what could be wrong here? Thanks!
Update
The embedded data was somehow getting dropped over the GMSL link (the driver is exactly the same in the two setups, we configure GMSL through a userspace program), not really sure how thats happening. Setting embedded_data_height to zero allows me to get a couple frames through
34 kworker/1:1-620 [001] .... 350.371593: rtcpu_vinotify_event: tstamp:10822169549 tag:FS channel:0x00 frame:0 vi_tstamp:10821840302 data:0x00000010
33 kworker/1:1-620 [001] .... 350.371594: rtcpu_vinotify_event: tstamp:10822169715 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:10821840303 data:0x00000000
32 kworker/1:1-620 [001] .... 350.371594: rtcpu_vinotify_event: tstamp:10822169860 tag:CHANSEL_PXL_SOF channel:0x22 frame:0 vi_tstamp:10821842225 data:0x00000001
31 kworker/1:1-620 [001] .... 350.371594: rtcpu_vinotify_event: tstamp:10822170026 tag:RESERVED_19 channel:0x22 frame:0 vi_tstamp:11291503200 data:0x08020033
30 kworker/1:1-620 [001] .... 350.371596: rtcpu_vinotify_event: tstamp:10822847734 tag:CHANSEL_PXL_EOF channel:0x22 frame:0 vi_tstamp:10822840580 data:0x086f0002
29 kworker/1:1-620 [001] .... 350.371596: rtcpu_vinotify_event: tstamp:10822847897 tag:ATOMP_FRAME_DONE channel:0x22 frame:0 vi_tstamp:10822840596 data:0x00000000
28 kworker/1:1-620 [001] .... 350.371596: rtcpu_vinotify_event: tstamp:10822848035 tag:RESERVED_19 channel:0x22 frame:0 vi_tstamp:11323451424 data:0x02020033
27 kworker/1:1-620 [001] .... 350.371597: rtcpu_vinotify_event: tstamp:10822848194 tag:FE channel:0x00 frame:0 vi_tstamp:10822842225 data:0x00000020
26 kworker/1:1-620 [001] .... 350.371597: rtcpu_vinotify_event: tstamp:10822848334 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:10822842226 data:0x00000000
25 kworker/1:1-620 [001] .... 350.371597: rtcpu_vinotify_event: tstamp:10822848491 tag:RESERVED_19 channel:0x22 frame:0 vi_tstamp:11323505792 data:0x00020033
24 kworker/1:1-620 [001] .... 350.371597: rtcpu_vinotify_event: tstamp:10822848627 tag:RESERVED_19 channel:0x22 frame:0 vi_tstamp:11323511104 data:0x07020034
23 kworker/1:1-620 [001] .... 350.371598: rtcpu_vinotify_event: tstamp:10822884768 tag:FS channel:0x00 frame:0 vi_tstamp:10822881569 data:0x00000010
22 kworker/1:1-620 [001] .... 350.371598: rtcpu_vinotify_event: tstamp:10822884911 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:10822881570 data:0x00000000
21 kworker/1:1-620 [001] .... 350.371598: rtcpu_vinotify_event: tstamp:10822885069 tag:CHANSEL_PXL_SOF channel:0x22 frame:0 vi_tstamp:10822883493 data:0x00000001
20 kworker/1:1-620 [001] .... 350.371599: rtcpu_vinotify_event: tstamp:10822885204 tag:RESERVED_19 channel:0x22 frame:0 vi_tstamp:11324823776 data:0x08020034
But it eventually falls back to the same problem
11 kworker/1:3-1640 [001] .... 258.423567: rtcpu_vinotify_error: tstamp:8225677731 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8225676280 data:0x00000589
12 kworker/1:3-1640 [001] .... 258.423568: rtcpu_vinotify_event: tstamp:8225788702 tag:FE channel:0x00 frame:0 vi_tstamp:8225635013 data:0x00000020
13 kworker/1:3-1640 [001] .... 258.423569: rtcpu_vinotify_event: tstamp:8225788861 tag:FS channel:0x00 frame:0 vi_tstamp:8225674357 data:0x00000010
14 kworker/1:3-1640 [001] .... 258.423570: rtcpu_vinotify_event: tstamp:8225789000 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8225676280 data:0x00000589
15 kworker/1:3-1640 [001] .... 258.423571: rtcpu_vinotify_event: tstamp:8226716831 tag:FE channel:0x00 frame:0 vi_tstamp:8226676278 data:0x00000020
16 kworker/1:3-1640 [001] .... 258.423572: rtcpu_vinotify_event: tstamp:8226716969 tag:FS channel:0x00 frame:0 vi_tstamp:8226715622 data:0x00000010
17 kworker/1:3-1640 [001] .... 258.423573: rtcpu_vinotify_error: tstamp:8226718675 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8226717544 data:0x00000589
18 kworker/1:3-1640 [001] .... 258.423574: rtcpu_vinotify_event: tstamp:8227020163 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8226717544 data:0x00000589
19 kworker/1:3-1640 [001] .... 258.423575: rtcpu_vinotify_error: tstamp:8227760259 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8227758809 data:0x00000589
20 kworker/1:3-1640 [001] .... 258.423576: rtcpu_vinotify_event: tstamp:8228019372 tag:FE channel:0x00 frame:0 vi_tstamp:8227717542 data:0x00000020
21 kworker/1:3-1640 [001] .... 258.423577: rtcpu_vinotify_event: tstamp:8228019530 tag:FS channel:0x00 frame:0 vi_tstamp:8227756886 data:0x00000010
22 kworker/1:3-1640 [001] .... 258.423578: rtcpu_vinotify_event: tstamp:8228019669 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8227758809 data:0x00000589
23 kworker/1:3-1640 [001] .... 258.525470: rtcpu_vinotify_event: tstamp:8230016731 tag:FE channel:0x00 frame:0 vi_tstamp:8229800073 data:0x00000020
24 kworker/1:3-1640 [001] .... 258.525474: rtcpu_vinotify_event: tstamp:8230016892 tag:FS channel:0x00 frame:0 vi_tstamp:8229839417 data:0x00000010
25 kworker/1:3-1640 [001] .... 258.525475: rtcpu_vinotify_event: tstamp:8230017032 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8229841339 data:0x00000589
26 kworker/1:3-1640 [001] .... 258.525478: rtcpu_vinotify_error: tstamp:8230884053 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8230882604 data:0x00000589
27 kworker/1:3-1640 [001] .... 258.525484: rtcpu_vinotify_event: tstamp:8231015617 tag:FE channel:0x00 frame:0 vi_tstamp:8230841337 data:0x00000020
28 kworker/1:3-1640 [001] .... 258.525485: rtcpu_vinotify_event: tstamp:8231015756 tag:FS channel:0x00 frame:0 vi_tstamp:8230880681 data:0x00000010
29 kworker/1:3-1640 [001] .... 258.525486: rtcpu_vinotify_event: tstamp:8231015915 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8230882604 data:0x00000589
30 kworker/1:3-1640 [001] .... 258.576467: rtcpu_vinotify_error: tstamp:8231925380 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8231923868 data:0x00000589
31 kworker/1:3-1640 [001] .... 258.576471: rtcpu_vinotify_event: tstamp:8231925692 tag:FE channel:0x00 frame:0 vi_tstamp:8231882602 data:0x00000020
32 kworker/1:3-1640 [001] .... 258.576473: rtcpu_vinotify_event: tstamp:8231925853 tag:FS channel:0x00 frame:0 vi_tstamp:8231921946 data:0x00000010
33 kworker/1:3-1640 [001] .... 258.576474: rtcpu_vinotify_event: tstamp:8231925989 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8231923868 data:0x00000589
34 kworker/1:3-1640 [001] .... 258.576475: rtcpu_vinotify_event: tstamp:8232946282 tag:FE channel:0x00 frame:0 vi_tstamp:8232923867 data:0x00000020
35 kworker/1:3-1640 [001] .... 258.576476: rtcpu_vinotify_error: tstamp:8232966220 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8232965133 data:0x00000589
36 kworker/1:3-1640 [001] .... 258.627478: rtcpu_vinotify_event: tstamp:8233279617 tag:FS channel:0x00 frame:0 vi_tstamp:8232963211 data:0x00000010
37 kworker/1:3-1640 [001] .... 258.627480: rtcpu_vinotify_event: tstamp:8233279782 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8232965133 data:0x00000589
38 kworker/1:3-1640 [001] .... 258.627481: rtcpu_vinotify_error: tstamp:8234007847 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8234006399 data:0x00000589
39 kworker/1:3-1640 [001] .... 258.627482: rtcpu_vinotify_event: tstamp:8234278462 tag:FE channel:0x00 frame:0 vi_tstamp:8233965131 data:0x00000020
40 kworker/1:3-1640 [001] .... 258.627483: rtcpu_vinotify_event: tstamp:8234278620 tag:FS channel:0x00 frame:0 vi_tstamp:8234004475 data:0x00000010
41 kworker/1:3-1640 [001] .... 258.627484: rtcpu_vinotify_event: tstamp:8234278758 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:8234006399 data:0x00000589
the frame number doesn’t seem to increment at all, would that be an issue as well? With just one camera, I can get a consistent “stream” of just frame 0. Its always the same data though
Thanks in advance!
