Hi NV_Team,
I’m using Xavier to driver GMSL1 cameras using MAX9296, but there is an error when preview the cameras. Can you help to check my csi log, and give me some advice about how to fix the problems? what about the CSIMUX_FRAME/CHANSEL_SHORT_FRAME/CHANSEL_FAULT means in the csi log and how to fix them by modifying the source code?
HW:
Xavier + MAX9296 + MAX96705/AR0147 (4Lanes, 1280x720@30fps)
SW:
JetPack4.5
DMESG Log
[ 74.946063] ar0147yuv 30-001b: ar0147yuv_set_mode: mode index:0
[ 74.946077] ar0147yuv 30-001b: ar0147yuv_start_streaming: start streaming
[ 74.950552] [RCE] Configuring VI GoS.
[ 74.950565] [RCE] VM GOS[#0] addr=0xc2100000
[ 74.950590] [RCE] VM GOS[#1] addr=0xc2101000
[ 74.950605] [RCE] VM GOS[#2] addr=0xc2102000
[ 74.950612] [RCE] VM GOS[#3] addr=0xc2103000
[ 74.950620] [RCE] VM GOS[#4] addr=0xc2104000
[ 74.950627] [RCE] VM GOS[#5] addr=0xc2105000
[ 74.950635] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 74.950646] [RCE] VI GOS[#0] set to VM GOS[4] base 0xc2104000
[ 74.977013] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 74.996468] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 64
[ 77.658610] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 77.658752] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 77.658907] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 77.660708] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x39
[ 77.660900] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x41
[ 77.661037] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x37
[ 77.661206] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 77.698742] [RCE] Configuring VI GoS.
[ 77.698759] [RCE] VM GOS[#0] addr=0xc2100000
[ 77.698765] [RCE] VM GOS[#1] addr=0xc2101000
[ 77.698771] [RCE] VM GOS[#2] addr=0xc2102000
[ 77.698778] [RCE] VM GOS[#3] addr=0xc2103000
[ 77.698784] [RCE] VM GOS[#4] addr=0xc2104000
[ 77.698790] [RCE] VM GOS[#5] addr=0xc2105000
kworker/0:2-1173 [000] .... 74.950641: rtcpu_string: tstamp:2913417487 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:2-1173 [000] .... 74.950649: rtcpu_vinotify_event: tstamp:2913794625 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3035086336 data:0x10000000
kworker/0:2-1173 [000] .... 74.950650: rtcpu_vinotify_event: tstamp:2913794920 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3035090144 data:0x31000001
kworker/0:2-1173 [000] .... 74.950651: rtcpu_vinotify_event: tstamp:2913795272 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3035091136 data:0x07020001
kworker/0:2-1173 [000] .... 74.950651: rtcpu_vinotify_event: tstamp:2913795556 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3035146624 data:0x10000000
kworker/0:2-1173 [000] .... 74.950652: rtcpu_vinotify_event: tstamp:2913795909 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3035150496 data:0x31000002
kworker/0:2-1173 [000] .... 74.950652: rtos_queue_send_from_isr_failed: tstamp:2914212881 queue:0x0bcb41f8
kworker/0:2-1173 [000] .... 74.950653: rtos_queue_send_from_isr_failed: tstamp:2914213020 queue:0x0bcb8a60
kworker/0:2-1173 [000] .... 74.950669: rtos_queue_send_from_isr_failed: tstamp:2914213157 queue:0x0bcba5e0
kworker/0:2-1173 [000] .... 74.950670: rtos_queue_send_from_isr_failed: tstamp:2914213294 queue:0x0bcbb3a0
kworker/0:2-1173 [000] .... 74.950671: rtos_queue_send_from_isr_failed: tstamp:2914213427 queue:0x0bcbc160
kworker/0:2-1173 [000] .... 75.010499: rtcpu_vinotify_error: tstamp:2915177225 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:2915171756 data:0x000000a0
kworker/0:2-1173 [000] .... 75.010504: rtos_queue_send_from_isr_failed: tstamp:2915186801 queue:0x0bcb41f8
kworker/0:2-1173 [000] .... 75.010506: rtos_queue_send_from_isr_failed: tstamp:2915186940 queue:0x0bcb8a60
kworker/0:2-1173 [000] .... 75.010506: rtos_queue_send_from_isr_failed: tstamp:2915187080 queue:0x0bcba5e0
kworker/0:2-1173 [000] .... 75.010507: rtos_queue_send_from_isr_failed: tstamp:2915187212 queue:0x0bcbb3a0
kworker/0:2-1173 [000] .... 75.010508: rtos_queue_send_from_isr_failed: tstamp:2915187344 queue:0x0bcbc160
kworker/0:2-1173 [000] .... 75.010509: rtcpu_vinotify_event: tstamp:2915259863 tag:FS channel:0x00 frame:0 vi_tstamp:2915171356 data:0x00000010
kworker/0:2-1173 [000] .... 75.010510: rtcpu_vinotify_event: tstamp:2915260013 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:2915171358 data:0x00000000
kworker/0:2-1173 [000] .... 75.010511: rtcpu_vinotify_event: tstamp:2915260140 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:2915171756 data:0x000000a0
kworker/0:2-1173 [000] .... 75.010511: rtcpu_vinotify_event: tstamp:2915260281 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:2915171756 data:0x01000000
kworker/0:2-1173 [000] .... 75.010512: rtcpu_vinotify_event: tstamp:2915260408 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3091204384 data:0x01020001
kworker/0:2-1173 [000] .... 75.010513: rtcpu_vinotify_event: tstamp:2915260548 tag:FS channel:0x00 frame:0 vi_tstamp:2915171756 data:0x00000010
kworker/0:2-1173 [000] .... 75.010513: rtcpu_vinotify_event: tstamp:2915260677 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:2915171759 data:0x00000000
kworker/0:2-1173 [000] .... 75.010514: rtcpu_vinotify_event: tstamp:2915260818 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:2915171759 data:0x00000000
kworker/0:2-1173 [000] .... 75.010514: rtcpu_vinotify_event: tstamp:2915260944 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:2915172497 data:0x00000001
kworker/0:2-1173 [000] .... 75.010515: rtcpu_vinotify_event: tstamp:2915261085 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3091247040 data:0x08020001
kworker/0:2-1173 [000] .... 75.010516: rtcpu_vinotify_event: tstamp:2915784519 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:2915779732 data:0x02cf0002
kworker/0:2-1173 [000] .... 75.010516: rtos_queue_send_from_isr_failed: tstamp:2915795499 queue:0x0bcb41f8
kworker/0:2-1173 [000] .... 75.010517: rtos_queue_send_from_isr_failed: tstamp:2915795638 queue:0x0bcb8a60
kworker/0:2-1173 [000] .... 75.010517: rtos_queue_send_from_isr_failed: tstamp:2915795778 queue:0x0bcba5e0
kworker/0:2-1173 [000] .... 75.010518: rtos_queue_send_from_isr_failed: tstamp:2915795910 queue:0x0bcbb3a0
kworker/0:2-1173 [000] .... 75.010519: rtos_queue_send_from_isr_failed: tstamp:2915796044 queue:0x0bcbc160
kworker/0:2-1173 [000] .... 75.010520: rtos_queue_peek_from_isr_failed: tstamp:2916095163 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 75.066520: rtcpu_vinotify_event: tstamp:2916236482 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3110649344 data:0x07020002
kworker/0:2-1173 [000] .... 75.066524: rtcpu_vinotify_event: tstamp:2916236613 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:2915779755 data:0x00000000
kworker/0:2-1173 [000] .... 75.066524: rtcpu_vinotify_event: tstamp:2916236758 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3110655104 data:0x02020002
kworker/0:2-1173 [000] .... 75.066525: rtcpu_vinotify_event: tstamp:2916236880 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:2915780187 data:0x02d00040
kworker/0:2-1173 [000] .... 75.066526: rtcpu_vinotify_event: tstamp:2916237022 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3110671872 data:0x01020002
kworker/0:2-1173 [000] .... 75.066526: rtcpu_vinotify_event: tstamp:2916237145 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3110828832 data:0x10000000
kworker/0:2-1173 [000] .... 75.066527: rtcpu_vinotify_event: tstamp:2916237286 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3110871840 data:0x31000003
kworker/0:2-1173 [000] .... 75.178547: rtos_queue_peek_from_isr_failed: tstamp:2921095161 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 75.346505: rtos_queue_peek_from_isr_failed: tstamp:2926095159 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 75.514552: rtos_queue_peek_from_isr_failed: tstamp:2931095159 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 75.682570: rtos_queue_peek_from_isr_failed: tstamp:2936095158 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 75.850531: rtos_queue_peek_from_isr_failed: tstamp:2941095162 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 76.018530: rtos_queue_peek_from_isr_failed: tstamp:2946095163 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 76.130544: rtos_queue_peek_from_isr_failed: tstamp:2951095161 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 76.298527: rtos_queue_peek_from_isr_failed: tstamp:2956095159 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 76.466586: rtos_queue_peek_from_isr_failed: tstamp:2961095162 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 76.634560: rtos_queue_peek_from_isr_failed: tstamp:2966095162 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 76.802585: rtos_queue_peek_from_isr_failed: tstamp:2971095159 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 76.970592: rtos_queue_peek_from_isr_failed: tstamp:2976095162 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 77.138597: rtos_queue_peek_from_isr_failed: tstamp:2981095162 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 77.250576: rtos_queue_peek_from_isr_failed: tstamp:2986095159 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 77.418591: rtos_queue_peek_from_isr_failed: tstamp:2991095162 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 77.586643: rtos_queue_peek_from_isr_failed: tstamp:2996095158 queue:0x0bcbcf78
kworker/0:2-1173 [000] .... 77.698647: rtos_queue_send_from_isr_failed: tstamp:2998994184 queue:0x0bcb41f8
kworker/0:2-1173 [000] .... 77.698650: rtos_queue_send_from_isr_failed: tstamp:2998994327 queue:0x0bcb8a60
kworker/0:2-1173 [000] .... 77.698651: rtos_queue_send_from_isr_failed: tstamp:2998994467 queue:0x0bcba5e0
kworker/0:2-1173 [000] .... 77.698652: rtos_queue_send_from_isr_failed: tstamp:2998994602 queue:0x0bcbb3a0
kworker/0:2-1173 [000] .... 77.698653: rtos_queue_send_from_isr_failed: tstamp:2998994734 queue:0x0bcbc160
kworker/0:2-1173 [000] .... 77.698653: rtos_queue_send_from_isr_failed: tstamp:2999034665 queue:0x0bcb41f8
kworker/0:2-1173 [000] .... 77.698654: rtos_queue_send_from_isr_failed: tstamp:2999034804 queue:0x0bcb8a60
kworker/0:2-1173 [000] .... 77.698654: rtos_queue_send_from_isr_failed: tstamp:2999034942 queue:0x0bcba5e0
kworker/0:2-1173 [000] .... 77.698655: rtos_queue_send_from_isr_failed: tstamp:2999035075 queue:0x0bcbb3a0
kworker/0:2-1173 [000] .... 77.698656: rtos_queue_send_from_isr_failed: tstamp:2999035209 queue:0x0bcbc160
kworker/0:2-1173 [000] .... 77.698657: rtcpu_nvcsi_intr: tstamp:2999041791 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1173 [000] .... 77.698658: rtcpu_nvcsi_intr: tstamp:2999041791 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1173 [000] .... 77.698658: rtcpu_nvcsi_intr: tstamp:2999042583 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1173 [000] .... 77.698722: rtcpu_nvcsi_intr: tstamp:2999042583 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1173 [000] .... 77.698723: rtcpu_nvcsi_intr: tstamp:2999043095 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:2-1173 [000] .... 77.698724: rtcpu_nvcsi_intr: tstamp:2999043095 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1173 [000] .... 77.698724: rtcpu_nvcsi_intr: tstamp:2999043095 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:2-1173 [000] .... 77.698725: rtcpu_nvcsi_intr: tstamp:2999043095 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
log.csidump.ar0147.log (40.5 KB)
