I got a new Thor devkit, and I following the guide(Quick Start Guide — Jetson AGX Thor Developer Kit - User Guide) to install the Jetson BSP. However, the device reboot immediately after I select Flash Jetson Thor AGX Developer Kit on NVMe 0.2.0-r38 (step 4). It doesn’t start the installation process. I want to know if any incorrect setup that may cause this problem.
Besides, when I select “Check Disc for Defects", it shows the following messages. I wonder if it is related to the problem I met.
BR,
Justin
