Using linux BSP: Jetson_Linux_R38.2.1_aarch64.tbz2
Running scipt:
sudo ./l4t_initrd_flash.sh --flash-only jetson-agx-thor-devkit internal
return : No devices to flash
I check my Thor USB info:
~/workspace/robot/Linux_for_Tegra$ lsusb
Bus 001 Device 011: ID 0955:7045 NVIDIA Corp. Tegra On-Platform Operator
I check l4t_initrd_flash.sh. It’s seem AGX Thor idProduct is 7026.
When I use sdkmanager , It show: “Could not detect a board”
Please refer to below official documentation
And refer to this section Quick Start — NVIDIA Jetson Linux Developer Guide to check device whether in recovery mode.
In my case:
But 7045 not in the list:
Hi
Your device is not currently in recovery mode.
When your device enters recovery mode, it will display as Nvidia Corp. rather than NVIDIA Corp. Tegra On-Platform Operator.
You should see:
Bus <bbb> Device <ddd>: ID 0955:<nnnn> Nvidia Corp.
Please verify that your flashing cable is connected to the J81 port.
Please mark the solution so we can close topics.
