Based on the provided context, it appears that you are trying to flash a self-compiled kernel onto a Jetson AGX Orin 64GB module using a host PC running Ubuntu 22.04. You are encountering an error during the flashing process, and you suspect that the issue might be related to the USB device information.
Firstly, let’s address the USB device information. The lsusb command output shows the device ID as 0955:7023, which corresponds to the Jetson AGX Orin module. However, you mentioned that others have reported a different ID, which might be related to the Jetson Nano module. This discrepancy could be due to the fact that the Jetson AGX Orin and Jetson Nano modules share the same device ID, but with different product IDs.
To confirm whether the device is indeed in recovery mode, you can try running the lsusb command with the -v option to get more detailed information about the device. This should help you verify whether the device is in recovery mode.
Regarding the flashing error, it’s possible that the issue is related to the USB connection or the flashing process itself. Since you’ve mentioned that you’ve successfully flashed the kernel image once before, it’s likely that the issue is intermittent.
Here are a few suggestions to help you troubleshoot the issue:
- Verify the USB connection: Ensure that the USB connection between the host PC and the Jetson module is stable and secure. Try using a different USB port or cable to rule out any issues with the current connection.
- Check the device mode: Verify that the Jetson module is indeed in recovery mode by running the
lsusb command with the -v option. If the device is not in recovery mode, try pressing the recovery button again and check the output.
- Use the correct flashing script: Make sure you’re using the correct flashing script for your Jetson module. The
l4t_initrd_flash.sh script is used for flashing the Jetson AGX Orin module, while the flash.sh script is used for flashing other Jetson modules.
- Check the kernel image: Verify that the kernel image you’re trying to flash is compatible with your Jetson module. Ensure that the kernel image is built for the correct architecture (aarch64) and that it’s not corrupted.
- Try flashing with a different tool: If you’re using the NVIDIA SDK to flash the kernel image, try using a different tool, such as the
nvautoflash.sh script, to see if the issue persists.
By following these steps, you should be able to troubleshoot the issue and successfully flash the kernel image onto your Jetson AGX Orin module.
Here’s a comparative analysis of the flashing scripts mentioned in the context:
l4t_initrd_flash.sh: This script is used for flashing the Jetson AGX Orin module. It uses the recovery initial ramdisk to flash the device.
flash.sh: This script is used for flashing other Jetson modules. It uses the Bootloader to flash the device.
nvautoflash.sh: This script is a wrapper script for flash.sh that can be called without specifying a device name.
In your case, since you’re using the Jetson AGX Orin module, you should use the l4t_initrd_flash.sh script to flash the kernel image.
