Hello.
Currently, I can’t solve the error in the “apt-get update” part of the docker build at Jetson AGX xavier, so I leave this question.
My jetpack and other specifications are as follows.
NVIDIA Jetson AGX Xavier [16GB]
L4T 32.5.1 [ JetPack 4.5.1 ]
Ubuntu 18.04.5 LTS
Kernel Version: 4.9.201-tegra
Xlib: extension “NV-GLX” missing on display “localhost:10.0”.
CUDA 10.2.89
CUDA Architecture: 7.2
OpenCV version: 4.1.1
OpenCV Cuda: NO
CUDNN: 8.0.0.180
TensorRT: 7.1.3.0
Vision Works: 1.6.0.501
VPI: ii libnvvpi1 1.0.15 arm64 NVIDIA Vision Programming Interface library
Vulcan: 1.2.70
Also, the content you want to build is yolactedge.
“yolact_edge/Dockerfile.xavier at master · haotian-liu/yolact_edge · GitHub”
Build modifications l4t-pytorch:r32.5.0
The following build was carried out.
docker build --build-arg USER_ID=$UID -t yolact_edge_image -f Dockerfile.xavier .
The error contents are as follows:
Step 1/19 : ARG L4T_IMAGE=nvcr.io/nvidia/l4t-pytorch:r32.5.0-pth1.6-py3
Step 2/19 : ARG JETSON_PLATFORM=t194
Step 3/19 : FROM ${L4T_IMAGE}
—> ed3ca4e9cf86
Step 4/19 : ARG L4T_IMAGE
—> Using cache
—> f5340ee7aedd
Step 5/19 : ARG JETSON_PLATFORM
—> Using cache
—> 24d088850cf4
Step 6/19 : ENV DEBIAN_FRONTEND=noninteractive
—> Using cache
—> 412710989762
Step 7/19 : RUN apt-get update && apt-get install --no-install-recommends -y gnupg2 curl ca-certificates && apt-get autoremove -y && apt-get clean && rm -rf /var/lib/apt/lists/*
—> Running in bb25aa8d9198
Err:1 Index of /ubuntu-ports bionic InRelease
Temporary failure resolving ‘ports.ubuntu.com’
Err:2 Index of /ubuntu-ports bionic-updates InRelease
Err:3 Index of /ubuntu-ports bionic-backports InRelease
Err:4 Index of /ubuntu-ports bionic-security InRelease
Reading package lists…
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic/InRelease Temporary failure resolving ‘ports.ubuntu.com’
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease Temporary failure resolving ‘ports.ubuntu.com’
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease Temporary failure resolving ‘ports.ubuntu.com’
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease Temporary failure resolving ‘ports.ubuntu.com’
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree…
Reading state information…
Package gnupg2 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
gpgv
Package curl is not available, but is referred to by another package.
E: Package ‘gnupg2’ has no installation candidate
E: Package ‘curl’ has no installation candidate
The command ‘/bin/sh -c apt-get update && apt-get install --no-install-recommends -y gnupg2 curl ca-certificates && apt-get autoremove -y && apt-get clean && rm -rf /var/lib/apt/lists/*’ returned a non-zero code: 100
How can we solve this?
