Help me.
Suddenly the screen disappeared.
I use Jetson AGX Xavier.
I installed deepstream 5.1 via hostPC a few months ago.
I tried some deepstream samples and trt-pose samples.
Since docker was required, when I entered the following command from ngc, there were many errors that Jetson’s capacity was insufficient, so I deleted the data each time.
docker pull nvcr.io/nvidia/k8s/container-toolkit:1.4.7-ubi8
distribution=$(. /etc/os-release;echo $ID$VERSION_ID) \ && curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey | sudo apt-key add - \ && curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list
(I referred to the following site:
Installation Guide — NVIDIA Cloud Native Technologies documentation)
The deleted data is below home directory, and I do not intend to delete important directory. And I restarted once.
After turning on the power, the nvidia log will be displayed, and then the following will be displayed.
cp: not writing through dangling sylink'etc / resolv.conf
cgroup: cgroup2: unknown option "nsdelegate"
random: crng init done
random: 7 urandom warning (s) missed due to rate limiting
using random self ethernet address
using random host ethernet address
After that, a black screen is displayed.
I entered the command ctrl + alt + F1-F6, but the screen remained black.
After about 5 minutes, these was displayed again as shown:
However this time, the screen did not go black and continued to be displayed. And then, when I entered ctrl + alt + F2, the TeleTypewriter was displayed.
Is there a way to flash and start over?
If you have the information you need to solve this problem please let me know how to get that information.
Thank you.
