Jetson AGX Xavier with no space can't boot
My Jetson AGX Xavier have low disk space and can’t boot anymore, it shows the load prompt normally but when finishes doesn’t show anything and doesn’t connect in the internet either to access from SSH. I have already tried to restart, access with uart console using minicom, that recognizes the entry but doesn’t show any output log, use the bind keys (ESC, Ctrl + Alt + F1 ~ F6, F11), but couldn’t have access to any terminal or anything, force format the system with SDK Manager and none of them worked. What else can I do?
The log bellow is showing that is missing files or may be corrupted on SDK but i already installed and reinstalled it several times and is still not working
20:10:19 ERROR: File System and OS - target_image: Download ‘File System and OS’ failure
20:10:19 ERROR: File System and OS - target_image: file is missing from offline download folder
20:10:19 ERROR: CUDA Runtime - target: Download ‘CUDA Runtime’ failure
20:10:19 ERROR: CUDA Runtime - target: file is missing from offline download folder
20:10:19 ERROR: CuDNN Runtime - target: Download ‘CuDNN Runtime’ failure
20:10:19 ERROR: CuDNN Runtime - target: file is missing from offline download folder
20:10:19 ERROR: TensorRT Runtime - target: Download ‘TensorRT Runtime’ failure
20:10:19 ERROR: TensorRT Runtime - target: file is missing from offline download folder
20:10:19 ERROR: NVIDIA Container Runtime with Docker integration (Beta) - target: Download ‘NVIDIA Container Runtime with Docker integration (Beta)’ failure
20:10:19 ERROR: NVIDIA Container Runtime with Docker integration (Beta) - target: file is missing from offline download folder
20:10:19 ERROR: Multimedia API - target: Download ‘Multimedia API’ failure
20:10:19 ERROR: Multimedia API - target: file is missing from offline download folder
20:10:19 ERROR: CUDA Toolkit for L4T - target: Download ‘CUDA Toolkit for L4T’ failure
20:10:19 ERROR: CUDA Toolkit for L4T - target: file is missing from offline download folder
20:10:19 ERROR: cuDNN on Target - target: Download ‘cuDNN on Target’ failure
20:10:19 ERROR: cuDNN on Target - target: file is missing from offline download folder
20:10:19 ERROR: TensorRT on Target - target: Download ‘TensorRT on Target’ failure
20:10:19 ERROR: TensorRT on Target - target: file is missing from offline download folder
20:10:19 ERROR: OpenCV Runtime - target: Download ‘OpenCV Runtime’ failure
20:10:19 ERROR: OpenCV Runtime - target: file is missing from offline download folder
20:10:19 ERROR: OpenCV - target: Download ‘OpenCV’ failure
20:10:19 ERROR: OpenCV - target: file is missing from offline download folder
20:10:19 ERROR: CuPVA Runtime - target: Download ‘CuPVA Runtime’ failure
20:10:19 ERROR: CuPVA Runtime - target: file is missing from offline download folder
20:10:19 ERROR: VPI Runtime - target: Download ‘VPI Runtime’ failure
20:10:19 ERROR: VPI Runtime - target: file is missing from offline download folder
20:10:19 ERROR: VPI on Target - target: Download ‘VPI on Target’ failure
20:10:19 ERROR: VPI on Target - target: file is missing from offline download folder
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Are you using VM or a native host Ubuntu OS to install the SDKM?
Which Ubuntu OS you used?
Which JetPack SW version you flash to device?
I’m using a native Ubuntu 18.04 with JetPack 5.1.1
can you delete the BSP folder on your host PC and try again?
Or manually flash with scripts in our BSP:
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/index.html
