Hi,everyone. I encountered some problems when I installed Jetson Xavier JetPack 4.2.2, the errors are as followed:
7:10:36 ERROR : Drivers for Jetson AGX : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/main/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:00:45 ERROR : NVIDIA Nsight Graphics : download error: checksum is wrong
18:14:58 ERROR : TensorRT on Target : download error: checksum is wrong
18:27:29 ERROR : NVIDIA Nsight Systems : update-alternatives: error: alternative path is not absolute as it should be:
18:35:27 ERROR : CUDA on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/main/dep11/Components-amd64.yml.gz Hash Sum mismatch
18:35:27 ERROR : CUDA on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-security/main/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:35:41 ERROR : CUDA on Host : Extracting templates from packages: 40%
18:35:41 ERROR : CUDA on Host : Extracting templates from packages: 80%
18:35:41 ERROR : CUDA on Host : Extracting templates from packages: 100%
18:37:01 ERROR : OpenCV on Host : dpkg: dependency problems prevent configuration of libopencv:
18:37:01 ERROR : OpenCV on Host : Errors were encountered while processing:
18:37:02 ERROR : OpenCV on Host : E: Unmet dependencies. Try using -f.
18:37:05 ERROR : OpenCV on Host : dpkg: considering removing python-opencv in favour of libopencv-python ...
18:37:15 ERROR : CUDA Cross Compile Package on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/universe/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:37:15 ERROR : CUDA Cross Compile Package on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-security/main/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:37:25 ERROR : CUDA Cross Compile Package on Host : Extracting templates from packages: 85%
18:37:25 ERROR : CUDA Cross Compile Package on Host : Extracting templates from packages: 100%
18:37:58 ERROR : VisionWorks on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/main/dep11/Components-amd64.yml.gz
18:37:58 ERROR : VisionWorks on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-security/multiverse/dep11/Components-amd64.yml.xz 404 Not Found
18:38:12 ERROR : VisionWorks on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/universe/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:38:12 ERROR : VisionWorks on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-security/main/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:38:21 ERROR : VisionWorks on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/universe/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:38:21 ERROR : VisionWorks on Host : E: Some index files failed to download. They have been ignored, or old ones used instead.
18:38:25 ERROR : command terminated with error
18:38:25 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:38:00 ERROR : command terminated with error
08:38:00 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:38:12 ERROR : command terminated with error
08:38:12 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:38:24 ERROR : command terminated with error
08:38:24 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:38:36 ERROR : command terminated with error
08:38:36 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:38:48 ERROR : command terminated with error
08:38:48 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:39:00 ERROR : command terminated with error
08:39:00 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:39:12 ERROR : command terminated with error
08:39:12 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:39:24 ERROR : command terminated with error
08:39:24 ERROR : Failed to use 'Automatic setup'. Please try again or change to 'Manual setup' to continue.
08:39:36 ERROR : command terminated with error
08:39:36 ERROR : Failed to use 'Automatic setup'. Please try again or change to 'Manual setup' to continue.
08:39:48 ERROR : command terminated with error
08:39:48 ERROR : Failed to use 'Automatic setup'. Please try again or change to 'Manual setup' to continue.
08:45:12 ERROR : command terminated with error
08:45:34 ERROR : Flash Jetson AGX Xavier : Board ID(2888) version(400) sku(0001) revision(J.0)
08:45:35 ERROR : Flash Jetson AGX Xavier : 1+0 records in
08:48:00 ERROR : Flash Jetson AGX Xavier :
Hope you can help me solve the problems, looking forwards to your reply.
