I started getting low disk space issue and installation stopped in the middle. I tried several times but it did not work may be due to low space or no space. I then restarted Xavier and since then my Xavier is not booting.
Every time i get below error message and then my monitor goes blank and nothing happens.
I just tried again by ctrl+alt+F3 and i was able to enter login id, password through tty3… But now how do i get back my desktop. Any help would be highly appreciated.
Yes you can solve this issue. Your disk is full. So that, you can uninstall some packages. If you have unimportant applications or libraries, you can delete some of them.
For example, if you don’t use thunderbird you can remove it like that: sudo apt-get remove thunderbird*
Then if your filesystem have some space (Available space of mounted on /) you can reboot or switch to desktop mode.
It sounds like building this Docker container is what took up all your disk space, so you may just want to delete that container. You can check which Docker images you have installed with sudo docker images and remove them with sudo docker rmi <image-name>
If you are unable to run the docker commands due to low disk space, then you can manually delete your docker root data dir. By default this is /var/lib/docker
In the future, you may want to add NVME drive to your Xavier devkit for additional disk space. You can then change the docker default root dir to the NVME drive so that the containers are all stored on NVME instead of eMMC.
