Hello Developers,
Thanks for your reply. I have a continuing the discussion from [Jetson AGX Xavier receive MIPI CSI-2 without I2C from MIPI Image generator):
my camera source is Introspect SV4E to port image data to Xavier
Introspect SV4E is porting 1948x1096 RAW12 30FPS C-PHY
I use the below command to show the frame from gstreamer:
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width(int)1948, height=(int)1096, format=NV12, framerate=(fraction)30/1’ ! nvvidconv ! xvimagesink -e
but the image is not correct.
Original image:
Receive image:
device tree is
tegra194-camera-e3326-a00.dtsi (9.1 KB)
could you give me some advice?
