We have a similar developed condition with this article:
We need to use Jetson AGX Xavier receive MIPI CSI-2 without I2C from MIPI Image generator, this Image generator is configed by externel device.
I just follow this article’s Step1 to Step10, I think it should be work, but it doesn’t work…
When I use gstreamer to show stream, there has some error message in log.
gstreamer_log (9.8 KB)
So, I traced the nvarguscamera plugin’s source code, but I notice that I can only trace down till acquireFrame() function, this function is an API provided by libargus, I have some question…
1.Why do I have this error message? Is it occurred by can’t read frame end or frame start before the time threshold?
But I just follow up on this article’s Step 1 to Step 10…
2.Do libargus have public source code?
Because I can’t trace down what did it do, what’s nvarguscamerasrc plugin’s workflow…
I am confused, Could you give me any advice?
Thanks a lot!
Josh
