Hi, everyone,
Does Xavier have a sleep function and how to enter sleep mode ?
Looking forward to your help.
thanks
it looks you’re initial this as TX2 threads, I’m moving this topic to appropriate category.
hello donny.xie,
you can initiate deep sleep from the user space with this command if the systemd init system is in use,
for example, $ sudo systemctl suspend
hi, JerryChang
Thank you for your reply.
How to wake up when xavier enters sleep mode?
hello donny.xie,
there’s several common wake sources available.
please check Chipset Power States session, and you may refer to [Wake Source] for details.
thanks
