I would like to know the mechanism of Deep Sleep(SC7) for hardware when we use the command below on the AGX Xavier:
$ sudo systemctl suspend
How can the command control the hardware for entering SC7?
thanks
thanks
hello H_Y,
please refer to Jetson AGX Xavier Series OEM Product Design Guide, you may check [Chapter-5. Power] for the details.
thanks
It says:
This can be entered under software control, and exited using various mechanisms, including wake capable pins that are listed in Table 5-8.
This means that the way of entering for Deep sleep(SC7) is only under software control, right?
However, STANDBY_REQ_N pin is that “Requests module enter standby(SC7 state)” in the Product design Guide.
hello H_Y,
are you asking hardware keyevents for putting device to deep sleep(SC7) mode?
Hello Jerry,
“are you asking hardware keyevents for putting device to deep sleep(SC7) mode?”
->Yes
We plan to make custom carrier board/Jetson AGX Xavier.
If we would like to enter for Deep sleep(SC7), we just only need to use the command below:
Is this understanding right?
hello H_Y,
that’s correct, it only support software command into deep sleep(SC7) mode.
hello Jerry,
Thank you for the answer.
However, I checked the datasheet, Product Design Guide and Jetson_AGX_Xavier_Series_Pin_Descriptions sheet.
I thought that STANDBY_REQ_N pin and POWER_BTN_N one can control for entering for Deep sleep(SC7)
I would like to confirm that we cannot control for putting device to deep sleep(SC7) mode with the hardware keyevents like STANDBY_REQ_N pin and POWER_BTN_N one.
Is this true?
thanks
hello H_Y,
that’s correct, it’s an optional signal for putting device enter SC7.
you’ll also need to monitor STANDBY_ACK_N, the level should be changed when enter or exit deep sleep.
please also have device tree update, you may modify gpio-keys with… linux,code = <KEY_SUSPEND> .
this should put device enter deep sleep after you press the hardware key.
please have a try, thanks
hello Jerry,
Thank you for the answer. I appreciate it.
I also would like you to tell us which file we should modify.
Could you please share the information of the file we should modify for entering for Deep sleep(SC7)?
thanks
hello H_Y,
please refer to AGX Xavier device tree,
for example, $public_sources/kernel_src/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2822-0000-a00.dtsi
here show an example of default gpio-keys for the power button.
gpio-keys {
compatible = "gpio-keys";
gpio-keys,name = "gpio-keys";
power_key {
label = "power-key";
gpios = <&tegra_aon_gpio TEGRA194_AON_GPIO(EE, 4) GPIO_ACTIVE_LOW>;
linux,code = <KEY_POWER>;
gpio-key,wakeup;
