This is my first time using AGX Xavier, I have some questions about Jetson AGX Xavier.
I am trying to control a motor through Controller Areal Network (CAN) connections using the Nvidia Jetson Xavier Developer Kit. I made the following adjustments for canbus.
sudo busybox devmem 0x0c303000 32 0x0000C400
sudo busybox devmem 0x0c303008 32 0x0000C458
sudo busybox devmem 0x0c303010 32 0x0000C400
sudo busybox devmem 0x0c303018 32 0x0000C458
sudo modprobe can
sudo modprobe can_raw
sudo modprobe mttcan
sudo ip link set down can0
sudo ip link set down can1
sudo ip link set can0 type can bitrate 200000 loopback on
sudo ip link set can1 type can bitrate 200000 loopback on
sudo ip link set up can0
sudo ip link set up can1
I verified CAN connections using a loopback test and it works perfectly fine over CAN0 and CAN1: I am getting traffic using candump can0 in loopback mode. However there is no traffic in normal test mode.(sudo ip link set can0 type can bitrate 200000 sudo ip link set can1 type can bitrate 200000)
Besides, wiring is OK, and bitrate of two device matches, My Xavier is running JetPack 4.4.0
Someone had the same question as me, and the answer he got was enable PLLAON clock. Follow: āTo use PLLAON as clock sourceā https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/clocks.html#wwpID0E06B0HA
But I canāt find where ātegra194-a02-bpmp-p2888-a04.dtbā is. So, can anybody help me?
I am having a similar issue with the Jetson Nano Nx linked here Jetson nano CAN via J17 pins only works with loopback on
hello syujen_1997,
assume youād install JetPack release via https://developer.nvidia.com/nvidia-sdk-manager.
itāll save the release image to your local host machine, the default path as ~/nvidia/nvidia_sdk/
and you shall find the binary file as below.
$OUT/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb
thanks
I do use Nvidia SDK Manager to initialize AGX Xavier, but there is no ~/nvidia/nvidia_sdk
Does the hardware version lead to different results? Maybe my device is an earlier versionļ¼
you should check on your local host for the release image.
Can you describe it in more detail? How should I check itļ¼
hello syujen_1997,
please see the āTarget HW image folderā for the Step-2 of SDK Manager.
hi, JerryChang
On my host, I can find ātegra194-a02-bpmp-p2888-a04.dtbā and path ā~/nvidia/nvidia_sdk/ā, but this is the new version of JetPack I just download tody. So, what I should do is to flash this new one to my AGX Xavierļ¼
hi JerrtChang
I flash on my AGX Xavier again, and āflash of target hardware was skippedā, there is still no "~/nvidia/nvidia_sdk/"
on my Xavier
hello syujen_1997,
you should check your local host machine (i.e. x86 desktop) for the release image.
Maybe I understand, please check it for me:
file tegra194-a02-bpmp-p2888-a04.dtb is under /home/johnsyu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/
can make sure in its .dts file look like:
clock@can1 {
allow_fractional_divider = <0x1>;
allowed-parents = <0x121 0x5b 0x13a 0x5e>;
clk-id = <0x9>;
clock@can2 {
clk-id = <0xb>;
and tegra194-p2888-0001-p2822-0000.dtb is under /home/johnsyu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/ (Although there are three files with the same name ātegra194-p2888-0001-p2822-0000.dtbā)
clocks-init {
compatible = ānvidia,clocks-configā;
status = āokayā;
disable {
clocks = <0x4 0x9 0x4 0xb>;
mttcan@c310000 {
pll_source = āpllaonā;
clocks = <0x4 0x11c 0x4 0xa 0x4 0x9 0x4 0x5e>;; /New entry/
clock-names = ācan_coreā, ācan_hostā, ācanā, āpllaonā;
mttcan@c320000 {
when turn these two .dts back to .dtb, flash OS on AGX Xavier
should I do something else?
hello syujen_1997,
it looks correct, please overwrite the binary files under $OUT/Linux_for_Tegra/bootloader/ and re-flash your target.
please, how can I overwrite the binary files under $OUT/Linux_for_Tegra/bootloader/
on web enable PLLAON it write āConvert the DTS file to DTB, or build the kernel DTB if you edited the source files.ā
how can I build the kernel DTB?
copy files: tegra194-a02-bpmp-p2888-a04.dtb and tegra194-p2888-0001-p2822-0000.dtb to $OUT/Linux_for_Tegra/bootloader/ ?
but the file tegra194-p2888-0001-p2822-0000.dtb is under $OUT/Linux_for_Tegra/kernel/dtb/, do I should overwrite this .dtb file in $OUT/Linux_for_Tegra/bootloader/ ?
hello syujen_1997,
donāt you disassembler the dtb file into text file for modification?
please overwrite the binary where it came from.
oh! I got it, Iām trying to re-flash my Xavier to verify can-bus
Now, I have finish flashing my Xavier, but under /sys/kernel/debug/bpmp/debug/clk/can1/parent, it shows āoscā, how can i choose pllaon as parent clock
hello syujen_1997,
by default, the PLLAON clock is disabled on T194 L4T platforms to conserve power.
please see developer guide, Configuring Clocks for the [To use PLLAON as clock source] session to enable PLLAON.
thanks
