Hi there,
I've just made a clean flash of an AGX Orin dev kit and now trying to… setup jetson-copilot. After starting the ollama server I get this error message when trying to connect to localhost. Any idea why the connection is refused?
2024-11-28 17:08:58.946 Uncaught app exception
File "/usr/local/lib/python3.10/dist-packages/httpx/_transports/default.py", line 69, in map_httpcore_exceptions
yield
File "/usr/local/lib/python3.10/dist-packages/httpx/_transports/default.py", line 233, in handle_request
resp = self._pool.handle_request(req)
File "/usr/local/lib/python3.10/dist-packages/httpcore/_sync/connection_pool.py", line 216, in handle_request
raise exc from None
File "/usr/local/lib/python3.10/dist-packages/httpcore/_sync/connection_pool.py", line 196, in handle_request
response = connection.handle_request(
File "/usr/local/lib/python3.10/dist-packages/httpcore/_sync/connection.py", line 99, in handle_request
raise exc
File "/usr/local/lib/python3.10/dist-packages/httpcore/_sync/connection.py", line 76, in handle_request
stream = self._connect(request)
File "/usr/local/lib/python3.10/dist-packages/httpcore/_sync/connection.py", line 122, in _connect
stream = self._network_backend.connect_tcp(**kwargs)
File "/usr/local/lib/python3.10/dist-packages/httpcore/_backends/sync.py", line 205, in connect_tcp
with map_exceptions(exc_map):
File "/usr/lib/python3.10/contextlib.py", line 153, in __exit__
self.gen.throw(typ, value, traceback)
File "/usr/local/lib/python3.10/dist-packages/httpcore/_exceptions.py", line 14, in map_exceptions
raise to_exc(exc) from exc
httpcore.ConnectError: [Errno 111] Connection refused
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.10/dist-packages/streamlit/runtime/scriptrunner/script_runner.py", line 589, in _run_script
exec(code, module.__dict__)
File "/opt/jetson_copilot/app/app.py", line 42, in <module>
models = [model["name"] for model in ollama.list()["models"]]
File "/usr/local/lib/python3.10/dist-packages/ollama/_client.py", line 333, in list
return self._request('GET', '/api/tags').json()
File "/usr/local/lib/python3.10/dist-packages/ollama/_client.py", line 69, in _request
response = self._client.request(method, url, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/httpx/_client.py", line 827, in request
return self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.10/dist-packages/httpx/_client.py", line 914, in send
response = self._send_handling_auth(
File "/usr/local/lib/python3.10/dist-packages/httpx/_client.py", line 942, in _send_handling_auth
response = self._send_handling_redirects(
File "/usr/local/lib/python3.10/dist-packages/httpx/_client.py", line 979, in _send_handling_redirects
response = self._send_single_request(request)
File "/usr/local/lib/python3.10/dist-packages/httpx/_client.py", line 1015, in _send_single_request
response = transport.handle_request(request)
File "/usr/local/lib/python3.10/dist-packages/httpx/_transports/default.py", line 232, in handle_request
with map_httpcore_exceptions():
File "/usr/local/lib/python3.10/dist-packages/httpx/_transports/default.py", line 86, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.ConnectError: [Errno 111] Connection refused
