Jetson HDMI no sound
I connected the Jetson board to a TV with HDMI. The screen is displayed, but no sound.
I have L4T 21.1 installed on the board. I tested the sound from System Settings > Sound.
Here is what did work:
  • sound from the speakers
  • screen and sound on the TV worked through HDMI from my laptop
Does anyone know how to solve this?
Hi Uriv,
Do you see any errors while booting up?
Can you please upload the output of “pactl list” in a text file here?
Thanks & Regards,
Rahool
Hi Rahool,
No errors on boot.
I uploaded the output of pactl list to http://s000.tinyupload.com/?file_id=05384427629522923385
Hello, I have the same problem.
Welcome to Ubuntu 14.04.1 LTS (GNU/Linux 3.10.40-ga7da876 armv7l)
GNU nano 2.2.6 File: fix_clocks.sh
echo 0 > /sys/devices/system/cpu/cpuquiet/tegra_cpuquiet/enable
echo 1 > /sys/devices/system/cpu/cpu0/online
echo 1 > /sys/devices/system/cpu/cpu1/online
echo 1 > /sys/devices/system/cpu/cpu2/online
echo 1 > /sys/devices/system/cpu/cpu3/online
echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo 852000000 > /sys/kernel/debug/clock/override.gbus/rate
echo 1 > /sys/kernel/debug/clock/override.gbus/state
                         [ Read 8 lines ]
ubuntu@tegra-ubuntu:~$ ls
cuda-l4t
cudnn
Desktop
Documents
Downloads
fix_clocks.sh
fix_clocks.sh~
GameWorksOpenGLSamples
libvisionworks-repo_1.4.3_armhf_l4t-r21.deb
libvisionworks-sfm-repo_0.86.2_armhf_l4t-r21.deb
libvisionworks-tracking-repo_0.82.3_armhf_l4t-r21.deb
Music
NVIDIA_CUDA-6.5_Samples
OpenCV4Tegra
PerfKit
Pictures
Public
run_gameworks_sample.sh
tegrastats
Templates
Videos
VisionWorks-SFM-0.86-Samples
ubuntu@tegra-ubuntu:~$ pactl list
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = “Lennart Poettering”
module.description = “Automatically restore the volume/mute state of devices”
module.version = “4.0”
Module #1
Argument:
Usage counter: n/a
Properties:
module.description = “Automatically restore the volume/mute/device state of streams”
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = “Automatically restore profile of cards”
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = “Augment the property sets of streams with additional static information”
Module #4
Argument:
Usage counter: n/a
Properties:
Module #5
Argument: device_id=“1” name=“platform-tegra-snd-rt5639.0” card_name=“alsa_card.platform-tegra-snd-rt5639.0” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties=“module-udev-detect.discovered=1”
Usage counter: 2
Properties:
module.description = “ALSA Card”
Module #6
Argument: device_id=“0” name=“platform-tegra30-hda” card_name=“alsa_card.platform-tegra30-hda” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties=“module-udev-detect.discovered=1”
Usage counter: 0
Properties:
Module #7
Argument:
Usage counter: n/a
Properties:
module.description = “Detect available audio hardware and load matching drivers”
Module #8
Argument:
Usage counter: n/a
Properties:
module.author = “David Henningsson”
module.description = “Android Audio HAL (Voice call helper)”
Module #9
Argument:
Usage counter: n/a
Properties:
module.author = “Frédéric Dalleau”
module.description = “When a bluetooth sink or source is added, load module-loopback”
Module #10
Argument:
Usage counter: n/a
Properties:
module.author = “Joao Paulo Rechi Vita”
module.description = “Detect available bluetooth audio devices and load bluetooth audio drivers”
Module #11
Argument:
Usage counter: n/a
Properties:
module.description = “Native protocol (UNIX sockets)”
Module #12
Argument:
Usage counter: n/a
Properties:
module.description = “Automatically restore the default sink and source”
Module #13
Argument:
Usage counter: n/a
Properties:
module.description = “When a sink/source is removed, try to move their streams to the default sink/source”
Module #14
Argument:
Usage counter: n/a
Properties:
module.author = “Colin Guthrie”
module.description = “Always keeps at least one sink loaded even if it’s a null one”
Module #15
Argument:
Usage counter: n/a
Properties:
module.description = “Automatically set device of streams based of intended roles of devices”
Module #16
Argument:
Usage counter: n/a
Properties:
module.description = “When a sink/source is idle for too long, suspend it”
Module #17
Argument:
Usage counter: n/a
Properties:
module.description = “Create a client for each login session of this user”
Module #18
Argument:
Usage counter: n/a
Properties:
module.description = “Position event sounds between L and R depending on the position on screen of the widget triggering them.”
Module #19
Argument:
Usage counter: n/a
Properties:
module.description = “Detect when various filters are desirable”
Module #20
Argument:
Usage counter: n/a
Properties:
module.description = “Load filter sinks automatically when needed”
Module #21
Argument: display=:0
Usage counter: n/a
Properties:
module.description = “X11 credential publisher”
Module #22
Argument: display=:0 sample=bell.ogg
Usage counter: n/a
Properties:
module.description = “X11 bell interceptor”
Module #23
Usage counter: n/a
Properties:
module.description = “Synthesize X11 media key events when cork/uncork is requested”
Module #24
Argument: display=:0 session_manager=local/tegra-ubuntu:@/tmp/.ICE-unix/1185,unix/tegra-ubuntu:/tmp/.ICE-unix/1185
Usage counter: n/a
Properties:
module.description = “X11 session management”
Sink #0
State: SUSPENDED
Description: tegra-rt5639 Analog Stereo
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 44100Hz
Channel Map: front-left,front-right
Owner Module: 5
Mute: no
Volume: 0: 47% 1: 47%
0: -19.50 dB 1: -19.50 dB
balance 0.00
Base Volume: 100%
0.00 dB
Monitor Source: alsa_output.platform-tegra-snd-rt5639.0.analog-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY Properties:
alsa.resolution_bits = “16”
device.api = “alsa”
device.class = “sound”
alsa.class = “generic”
alsa.subclass = “generic-mix”
alsa.name = “”
alsa.id = “rt5639 PCM rt5639-aif1-0”
alsa.subdevice = “0”
alsa.subdevice_name = “subdevice #0
alsa.device = “0”
alsa.card = “1”
alsa.card_name = “tegra-rt5639”
alsa.long_card_name = “tegra-rt5639”
device.bus_path = “platform-tegra-snd-rt5639.0”
sysfs.path = “/devices/platform/tegra-snd-rt5639.0/sound/card1”
device.string = “hw:1”
device.buffering.buffer_size = “32768”
device.buffering.fragment_size = “8192”
device.access_mode = “mmap+timer”
device.profile.name = “analog-stereo”
device.profile.description = “Analog Stereo”
device.description = “tegra-rt5639 Analog Stereo”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card”
Ports:
analog-output-speaker: Speakers (priority: 10000)
Active Port: analog-output-speaker
Formats:
pcm
Sink #1
State: SUSPENDED
Description: HDA NVIDIA Tegra Digital Stereo (HDMI)
Owner Module: 6
Mute: no
Volume: 0: 100% 1: 100%
0: 0.00 dB 1: 0.00 dB
balance 0.00
Base Volume: 100%
0.00 dB
Monitor Source: alsa_output.platform-tegra30-hda.hdmi-stereo.monitor
Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
device.api = “alsa”
alsa.name = “HDMI 0”
alsa.id = “HDMI 0”
alsa.device = “3”
alsa.card = “0”
alsa.card_name = “HDA NVIDIA Tegra”
alsa.long_card_name = “HDA NVIDIA Tegra at 0x70038000 irq 113”
device.bus_path = “platform-tegra30-hda”
sysfs.path = “/devices/platform/tegra30-hda/sound/card0”
device.string = “hdmi:0”
device.buffering.buffer_size = “65536”
device.buffering.fragment_size = “32768”
device.profile.name = “hdmi-stereo”
device.profile.description = “Digital Stereo (HDMI)”
device.description = “HDA NVIDIA Tegra Digital Stereo (HDMI)”
alsa.mixer_name = “Nvidia Tegra12x HDMI”
alsa.components = “HDA:10de0028,10de0101,00100100”
Ports:
hdmi-output-0: HDMI / DisplayPort (priority: 5900, available)
Active Port: hdmi-output-0
Formats:
pcm
Source #0
State: SUSPENDED
Name: alsa_output.platform-tegra-snd-rt5639.0.analog-stereo.monitor Description: Monitor of tegra-rt5639 Analog Stereo
Owner Module: 5
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Monitor of Sink: alsa_output.platform-tegra-snd-rt5639.0.analog-stereo
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = “Monitor of tegra-rt5639 Analog Stereo”
device.class = “monitor”
alsa.card = “1”
device.string = “1”
Formats:
pcm
Source #1
State: RUNNING
Owner Module: 5
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Monitor of Sink: n/a
Latency: 34163 usec, configured 56000 usec
Properties:
device.api = “alsa”
alsa.name = “”
alsa.device = “0”
alsa.card = “1”
Ports:
analog-input: Analog Input (priority: 10000)
Active Port: analog-input
Formats:
pcm
Source #2
State: SUSPENDED
Description: Monitor of HDA NVIDIA Tegra Digital Stereo (HDMI)
Owner Module: 6
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Monitor of Sink: alsa_output.platform-tegra30-hda.hdmi-stereo
Properties:
device.description = “Monitor of HDA NVIDIA Tegra Digital Stereo (HDMI)”
alsa.card = “0”
device.string = “0”
Formats:
pcm
Source Output #0
Driver: protocol-native.c
Owner Module: 11
Client: 9
Source: 1
Sample Specification: float32le 1ch 25Hz
Channel Map: mono
Format: pcm, format.sample_format = “"float32le"” format.rate = “25” format.channels = “1” format.channel_map = “"mono"”
Corked: no
Mute: no
Volume: 0: 100%
0: 0.00 dB
balance 0.00
Buffer Latency: 0 usec
Source Latency: 45007 usec
Resample method: peaks
Properties:
application.id = “org.gnome.VolumeControl”
media.name = “Peak detect”
application.name = “GNOME Volume Control Dialog”
native-protocol.peer = “UNIX socket client”
native-protocol.version = “28”
application.icon_name = “unity-sound-panel”
application.version = “14.04.3”
application.process.id = “2223”
application.process.user = “ubuntu”
application.process.host = “tegra-ubuntu”
application.process.binary = “unity-control-center”
application.language = “en_US.UTF-8”
window.x11.display = “:0”
application.process.machine_id = “ce4e241f4b856b2e8d667714535054ff”
application.process.session_id = “c2”
module-stream-restore.id = “source-output-by-application-id:org.gnome.VolumeControl”
Source Output #1
Owner Module: 11
Client: 9
Source: 1
Channel Map: mono
Corked: no
Mute: no
Volume: 0: 100%
0: 0.00 dB
balance 0.00
Source Latency: 45082 usec
Properties:
Client #0
Driver: module-systemd-login.c
Owner Module: 17
Properties:
application.name = “Login Session c2”
systemd-login.session = “c2”
Client #1
Owner Module: 17
Properties:
application.name = “Login Session c1”
systemd-login.session = “c1”
Client #4
Owner Module: 11
Properties:
application.name = “Ubuntu Audio Settings”
application.id = “com.canonical.settings.sound”
application.icon_name = “multimedia-volume-control”
application.version = “0.1”
application.process.id = “1324”
application.process.binary = “indicator-sound-service”
Client #5
Owner Module: 11
Properties:
application.name = “GNOME Volume Control Media Keys”
application.version = “1.0”
application.process.id = “1172”
application.process.binary = “unity-settings-daemon”
Client #8
Driver: module-x11-xsmp.c
Owner Module: 24
Properties:
application.name = “XSMP Session on gnome-session as 10a232adf4bb24e06f148511018215427100000011850047”
xsmp.vendor = “gnome-session”
xsmp.client.id = “10a232adf4bb24e06f148511018215427100000011850047”
Client #9
Owner Module: 11
Properties:
Client #10
Owner Module: 11
Properties:
application.name = “pactl”
application.process.id = “2267”
application.process.binary = “pactl”
application.process.session_id = “c3”
Card #0
Owner Module: 5
Properties:
alsa.card = “1”
device.string = “1”
device.description = “tegra-rt5639”
Profiles:
input:analog-mono: Analog Mono Input (sinks: 0, sources: 1, priority. 1)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority. 60)
output:analog-mono: Analog Mono Output (sinks: 1, sources: 0, priority. 100)
output:analog-mono+input:analog-mono: Analog Mono Duplex (sinks: 1, sources: 1, priority. 101)
output:analog-mono+input:analog-stereo: Analog Mono Output + Analog Stereo Input (sinks: 1, sources: 1, priority. 160)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority. 6000)
output:analog-stereo+input:analog-mono: Analog Stereo Output + Analog Mono Input (sinks: 1, sources: 1, priority. 6001)
ubuntu@tegra-ubuntu:~$ pactl list Module #0
Argument:
Usage counter: n/a
Properties: module.author = “Lennart Poettering” module.description = “Automatically restore the volume/mute state of devices” module.version = “4.0”
Module #1
Argument: Usage counter: n/a Properties:
Module #2
Argument:
Usage counter: n/a
Properties:
Module #3
Argument:
Module #4
Argument:
Usage counter: n/a
Properties:
Module #5
Usage counter: 2
Properties:
Module #6
Usage counter: 0
Properties:
Module #7
Argument:
Usage counter: n/a
Properties:
Module #8
Argument:
Usage counter: n/a
Properties:
Module #9
Argument:
Usage counter: n/a
Properties:
Module #10
Argument:
Usage counter: n/a
Properties:
Module #11
Argument:
Usage counter: n/a
Properties:
Module #12
Argument:
Usage counter: n/a
Properties:
Module #13
Argument:
Usage counter: n/a
Properties:
Module #14
Argument:
Usage counter: n/a
Properties:
Module #15
Argument:
Usage counter: n/a
Properties:
Module #16
Argument:
Usage counter: n/a
Properties:
Module #17
Argument:
Usage counter: n/a
Properties:
Module #18
Argument:
Usage counter: n/a
Properties:
Module #19
Argument:
Usage counter: n/a
Properties:
Module #20
Argument:
Usage counter: n/a
Properties:
Module #21
Usage counter: n/a
Properties:
Module #22
Usage counter: n/a
Properties:
Module #23
Usage counter: n/a
Properties:
Module #24
Usage counter: n/a
Properties:
Sink #0
State: SUSPENDED
Owner Module: 5
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
device.api = “alsa”
alsa.name = “”
alsa.device = “0”
alsa.card = “1”
Ports:
Formats:
pcm
Sink #1
State: SUSPENDED
Owner Module: 6
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
device.api = “alsa”
alsa.id = “HDMI 0”
alsa.device = “3”
alsa.card = “0”
Ports:
Formats:
pcm
Source #0
State: SUSPENDED
Owner Module: 5
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
alsa.card = “1”
device.string = “1”
Formats:
pcm
Source #1
State: RUNNING
Owner Module: 5
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Latency: 5899 usec, configured 56000 usec
Properties:
device.api = “alsa”
alsa.name = “”
alsa.device = “0”
alsa.card = “1”
Ports:
Formats:
pcm
Source #2
State: SUSPENDED
Owner Module: 6
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
alsa.card = “0”
device.string = “0”
Formats:
pcm
Source Output #0
Owner Module: 11
Client: 9
Source: 1
Channel Map: mono
Corked: no
Mute: no
Volume: 0: 100%
0: 0.00 dB
balance 0.00
Source Latency: 11544 usec
Properties:
Source Output #1
Owner Module: 11
Client: 9
Source: 1
Channel Map: mono
Corked: no
Mute: no
Volume: 0: 100%
0: 0.00 dB
balance 0.00
Source Latency: 11681 usec
Properties:
Client #0
Owner Module: 17
Properties:
Client #1
Owner Module: 17
Properties:
Client #4
Owner Module: 11
Properties:
Client #5
Owner Module: 11
Properties:
Client #8
Owner Module: 24
Properties:
Client #9
Owner Module: 11
Properties:
Client #11
Owner Module: 11
Properties:
application.process.id = “2269”
Card #0
Owner Module: 5
Properties:
alsa.card = “1”
device.string = “1”
Profiles:
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority. 6060)
off: Off (sinks: 0, sources: 0, priority. 0)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input: Analog Input (priority: 10000, latency offset: 0 usec)
Part of profile(s): input:analog-mono, input:analog-stereo, output:analog-mono+input:analog-mono, output:analog-mono+input:analog-stereo, output:analog-stereo+input:analog-mono, output:analog-stereo+input:analog-stereo
analog-output-speaker: Speakers (priority: 10000, latency offset: 0 usec)
Properties:
device.icon_name = “audio-speakers”
Part of profile(s): output:analog-mono, output:analog-mono+input:analog-mono, output:analog-mono+input:analog-stereo, output:analog-stereo, output:analog-stereo+input:analog-mono, output:analog-stereo+input:analog-stereo
Card #1
Owner Module: 6
Properties:
alsa.card = “0”
device.string = “0”
device.description = “HDA NVIDIA Tegra”
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority. 5400)
Active Profile: output:hdmi-stereo
Ports:
hdmi-output-0: HDMI / DisplayPort (priority: 5900, latency offset: 0 usec, available)
Properties:
device.icon_name = “video-display”
device.product.name = “LG TV”
Part of profile(s): output:hdmi-stereo
Hi dtmoodie,
After doing below setting:
System settings → Sound → Play sound through “HDMI/DisplayPort”
Confirmed sound can be outputted on TK1/r21.5 and TX1/r24.2.1.
what about TX2?
seems that it got somehow resolved there: https://devtalk.nvidia.com/default/topic/1004298/jetson-tx2/no-sound-via-hdmi/
