Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
Hi, I am Jaeyoon
I am doing some research which takes raw Bayer data from camera and process this data using GPU in Jetson. Actually it is possible by taking raw data using v4l2.
However, I want to do some additional action. I want to insert the processed result data into Jetson ISP (to run ISP pipeline).
I searched “Camera architecture stack” and found that there is only one path that passes Tegra Driver to run ISP.
Thus, I speculate I should modify firmware to modify some data path (from Camera Sensor to GPU to again ISP)
I want to ask that if it is possible, and if yes, how can I do it??
Thanks in advance
Jaeyoon
