- I use L4T Driver Package of Jetson Linux 34.1 to flash xavier dev board, the xavier can bring up successfully and lcd display normally.
- Then I build an Image from source code of Jetson Linux 34.1, and replace the Image in the target with the one I just built.
- The problem is that: the lcd can not bring up, but log can be output from serial port, and I can log in from serial terminal.
I see there are lots of nvgpu driver error.
[ 12.333366] nvgpu: Unknown symbol nvlink_shutdown (err -2)
[ 12.336607] nvgpu: Unknown symbol nvlink_register_link (err -2)
[ 12.336923] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 12.342899] nvgpu: Unknown symbol nvlink_unregister_device (err -2)
[ 12.355471] nvgpu: Unknown symbol nvlink_unregister_link (err -2)
[ 12.356019] nvgpu: Unknown symbol nvlink_enumerate (err -2)
[ 12.356035] nvgpu: Unknown symbol nvlink_transition_intranode_conn_off_to_safe (err -2)
[ 12.356322] nvgpu: Unknown symbol nvlink_register_device (err -2)
[ 12.356447] nvgpu: Unknown symbol nvlink_train_intranode_conn_safe_to_hs (err -2)
[ 12.398296] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 12.399727] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 12.410479] systemd[1]: Starting Load/Save Random Seed...
[ 12.416987] systemd[1]: Starting Create System Users...
[ 12.421765] systemd[1]: Finished Load Kernel Modules.
[ 12.425252] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 12.435487] systemd[1]: Mounting Kernel Configuration File System...
[ 12.441813] systemd[1]: Started OP-TEE Client Supplicant.
[ 12.447396] systemd[1]: Starting Apply Kernel Variables...
[ 12.454324] systemd[1]: Finished Set the console keyboard layout.
[ 12.461314] systemd[1]: Finished Load/Save Random Seed.
[ 12.465855] systemd[1]: Mounted Kernel Configuration File System.
[ 13.116217] nvgpu: Unknown symbol nvlink_shutdown (err -2)
[ 13.123157] nvgpu: Unknown symbol nvlink_register_link (err -2)
[ 13.124516] nvgpu: Unknown symbol nvlink_unregister_device (err -2)
[ 13.141224] nvgpu: Unknown symbol nvlink_unregister_link (err -2)
[ 13.142870] nvgpu: Unknown symbol nvlink_enumerate (err -2)
[ 13.143938] nvgpu: Unknown symbol nvlink_transition_intranode_conn_off_to_safe (err -2)
[ 13.145341] nvgpu: Unknown symbol nvlink_register_device (err -2)
[ 13.146552] nvgpu: Unknown symbol nvlink_train_intranode_conn_safe_to_hs (err -2)
What is your step to build kernel? Do you know that jp5.0 is using new toolchain?
I forgot to replace nvgpu.ko.
