Jetson Linux 36.2 Flashing Problem and HDMI support
I want to install Linux 36.2 on the Jetson Orin Nano Custom Carrier Device the installation is successful, but the device does not turn on.
[ 3.446525] Root device found: PARTUUID=1dfbf9b6-eee1-4ffb-a13b-f36eb53104ab
[ 14.363678] ERROR: PARTUUID=1dfbf9b6-eee1-4ffb-a13b-f36eb53104ab mount fail…
The bord I use for flashing is a custom-made carrier pcb.
This bord was working smoothly on 35.4.
My device has an HDMI output instead of a DP output, which is different from Devkit.
Question:
I was using the dtb file below when flashing in version 35.4, but the file below is not available for 36.2.
DTB_FILE=“tegra234-p3767-0004-p3509-a02.dtb”;
In the new version, the following dtb file is used in jetson-orin-nano-devkit.conf.
DTB_FILE=“tegra234-p3768-0000+p3767-0000-nv.dtb”;
Will I have any problems with HDMI because I use this file, or will it work if I copy the old dtb file to the relevant address?
We have many HDMI carrier cards in production and I want to run DS 6.4 on them without any problems.
I know Linux 36.2 is in testing phase now. The question I ask are for March 2024.
Jetson Orin Nano Devkit gives similar problems. Flashing is successful, but the system does not boot.
flash_9-3.4.1.3_0_20231221-193247.log (51.2 KB)
Device_Log.txt (131.3 KB)
We don’t support this setup. Please check the explanation in
Boot up error when enabling HDMI by using p3509-a02+p3767-0000.conf , the Jetpack is 5.1.2 - #2 by DaneLLL
