Jetson Multicamera Pipelines
Hi Everyone!
I’d like to share with you my intern project completed during my time here at Nvidia.
It’s a python package which:
- Makes it easy to compose multi-camera pipelines
- Lets you take advantage of different HW accelerators on Nvidia Jetson modules for minimal CPU usage
- Allows you to build custom logic on top of the detections from multiple cameras
Demo
Below is a demo video of person-following logic built on top of jetmulticam package:
In this demo we have 3 intependent cameras with total ~270° field of view, like in the figure below. Red Boxes correspond to DashCamNet detections, green ones to PeopleNet. The PeopleNet detections are used to perform person following logic. Source code for this example is available on our github: example-person-following.py
Getting Started
The project allows you to implement complex logic (capture, batching, HW inference, HW encoding) with multiple cameras using relatively simple python code. A typical pipeline can look like in the flowchart below:
Below is a code snippet that presents you the capabilities of the package:
import time
from jetmulticam import CameraPipelineDNN
from jetmulticam.models import PeopleNet, DashCamNet
if __name__ == "__main__":
pipeline = CameraPipelineDNN(
cameras=[2, 5, 8],
models=[
PeopleNet.DLA1,
DashCamNet.DLA0,
# PeopleNet.GPU
save_video=True,
save_video_folder="/home/nx/logs/videos",
display=True,
while pipeline.running():
arr = pipeline.images[0] # np.array with shape (1080, 1920, 3), i.e. (1080p RGB image)
dets = pipeline.detections[0] # Detections from the DNNs
time.sleep(1/30)
With this snippet we create the pipeline that allows us to:
- Capture video from 3 cameras
- Batch the images for DNN inference
- Deploy 2 DNNs (PeopleNet and DashCamNet) on 2 different HW accelerators
- Encode the video with h264 HW encoder and save it to
mkvfile - Display video on the screen for debugging
- Write your own logic in python using parsed detentions in the main thread.
If you’re interested, please check out the project’s github repo and considering leaving a star!
Detailed info on how to install and get started with the project are available in the Quickstart in the repo.
If you have any questions, feel free to post them below!
