My nvidia jetson nano 2gb developer board is stuck in a bootloop. I flashed the latest image intented for the 2gb developer board and I went through the settings. After I somehow couldn’t log in, I turned off the power and flashed the image again. From there it has been stuck in a bootloop and sdk manager can’t find the device because it doesn’t provide a ttyACM0 anymore (it did before).
The log starts with:
[0001.227] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):b5eeb33
NOTICE: BL31: Built : 08:56:32, Feb 19 2022
ERROR: Error initializing runtime service trusty_fast
[0001.349] RamCode = 1
[0001.353] LPDDR4 Training: Read DT: Number of tables = 2
[0001.358] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.371] EMC Training Successful
[0001.374] 408000 not found in DVFS table
[0001.381] RamCode = 1
[0001.384] DT Write: emc-table@204000 succeeded
[0001.390] DT Write: emc-table@1600000 succeeded
[0001.394] LPDDR4 Training: Write DT: Number of tables = 2
[0001.436]
[0001.437] Debug Init done
[0001.440] Marked DTB cacheable
[0001.443] Bootloader DTB loaded at 0x83000000
[0001.448] Marked DTB cacheable
[0001.450] Kernel DTB loaded at 0x83100000
[0001.454] DeviceTree Init done
[0001.467] Pinmux applied successfully
[0001.472] gicd_base: 0x50041000
[0001.475] gicc_base: 0x50042000
[0001.478] Interrupts Init done
[0001.482] Using base:0x60005090 & irq:208 for tick-timer
[0001.488] Using base:0x60005098 for delay-timer
[0001.492] platform_init_timer: DONE
[0001.496] Timer(tick) Init done
[0001.499] osc freq = 38400 khz
[0001.503]
[0001.504] Welcome to L4T Cboot
[0001.507]
[0001.508] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
[0001.513] calling constructors
[0001.516] initializing heap
[0001.519] initializing threads
[0001.522] initializing timers
[0001.525] creating bootstrap completion thread
[0001.529] top of bootstrap2()
[0001.532] CPU: ARM Cortex A57
[0001.535] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.540] initializing platform
[0001.547] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.552] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.556] Macronix QSPI chip present
[0001.560] SPI device register
[0001.563] init boot device
[0001.565] allocating memory for boot device(SPI)
[0001.570] registering boot device
[0001.578] QSPI bdev is already initialized
[0001.582] Enable APE clock
and ends with
[0000.652] No write function to write to current BFS 0
[0000.656] Clobber: returns e=0x1
[0000.659] - failover failed; Continuing with bad image …
[0000.665] Loading NvTbootKernelDTB
[0000.731] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.800] Kernel DTB Load Address: 0x83100000
[0000.804] BoardID = 3448, SKU = 0x3
[0000.807] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.811] Nano-SD: checking PT table on QSPI …
[0000.816] NvTbootFailControlDoFailover: Doing failover: Cboot partition 0 is corrupted (ec=0x0).
[0000.824] NvTbootFailControlDoClobber:
[0000.828] Current BFS=0
[0000.830] No write function to write to current BFS 0
[0000.835] Clobber: returns e=0x1
[0000.838] - failover failed; Continuing with bad image …
[0000.845] Loading cboot binary
[0000.961] Verifying EBT in OdmNonSecureSBK mode
[0001.002] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.009] Bootloader downloaded successfully.
[0001.013] BoardID = 3448, SKU = 0x3
[0001.017] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.020] Nano-SD: checking PT table on QSPI …
[0001.025] NvTbootFailControlDoFailover: Doing failover: Cboot partition 0 is corrupted (ec=0x0).
[0001.033] NvTbootFailControlDoClobber:
[0001.037] Current BFS=0
[0001.039] No write function to write to current BFS 0
[0001.044] Clobber: returns e=0x1
[0001.047] - failover failed; Continuing with bad image …
[0001.052] PT: Partition NCT NOT found !
[0001.056] Warning: Find Partition via PT Failed
[0001.060] Next binary entry address: 0x92c00258
[0001.065] BoardId: 3448
[0001.069] Overriding pmu board id with proc board id
[0001.074] Display board id is not available
[0001.078] No Bpmp FW loaded
[0001.081] Not loading WB0 as no bpmp/sc7entry fw
[0001.085] Set NvDecSticky Bits
[0001.089] GSC2 address ff93fffc value c0edbbcc
[0001.095] GSC MC Settings done
[0001.098] BoardID = 3448, SKU = 0x3
[0001.101] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.105] Nano-SD: checking PT table on QSPI …
[0001.110] NvTbootFailControlDoFailover: Doing failover: Cboot partition 0 is corrupted (ec=0x0).
[0001.118] NvTbootFailControlDoClobber:
[0001.122] Current BFS=0
[0001.124] No write function to write to current BFS 0
[0001.129] Clobber: returns e=0x1
[0001.132] - failover failed; Continuing with bad image …
[0001.138] TOS Image length 53680
[0001.141] Monitor size 53680
[0001.144] OS size 0
[0001.159] Secure Os AES-CMAC Verification Success!
[0001.164] TOS image cipher info: plaintext
[0001.167] Loading and Validation of Secure OS Successful
[0001.183] NvTbootPackSdramParams: start.
[0001.188] NvTbootPackSdramParams: done.
[0001.192] Tegraboot started after 84906 us
[0001.196] Basic modules init took 1088926 us
[0001.200] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.206] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.211] Next stage binary read took 11286 us
[0001.216] Carveout took -91856 us
[0001.219] CPU initialization took 128029 us
[0001.223] Total time taken by TegraBoot 1136385 us
