Jetson Nano 2gb developer kit not booting
A few days ago I tried to flash the newest image for the jetson nano onto the sd card (with belena etcher). After that I was able to set username and password on first boot. After rebooting there was no more response on all input/output devices (keyboard, monitor, etc). Flashing the old image on the sd card did not work, using another sd card did not work either. Flashing with SDK Manager did not work (the jetson nano is not detected as a device if connected with micro USB to another pc). So I bought a USB- to TTL Adapter. The output in minicom indicates a corrupted TOS partition:
[L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 1
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1e1bf7
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.204] BpmpFw Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.210] GSC1 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.216] Resize the SecureOs Carveout to 0x00100000
[0000.221] GSC2 Carveout Base=0x00000000ff900000 Size=0x00100000
[0000.226] GSC4 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.232] GSC5 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.238] GSC3 Carveout Base=0x00000000bf800000 Size=0x00200000
[0000.244] RamDump Carveout Base=0x0000000000000000 Size=0x00000000
[0000.250] Platform-DebugCarveout: 0
[0000.253] Nck Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.259] Non secure mode, and RB not enabled.
[0000.263] BoardID = 3448, SKU = 0x3
[0000.266] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.270] Nano-SD: checking PT table on QSPI …
[0000.274] Initialize FailControl
[0000.277] Read PT from (2:0)
[0000.308] PT crc32 and magic check passed.
[0000.312] Using BFS PT to query partitions
[0000.318] Loading Tboot-CPU binary
[0000.346] Verifying TBC in OdmNonSecureSBK mode
[0000.356] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.363] Bootloader downloaded successfully.
[0000.367] Downloaded Tboot-CPU binary to 0xa0000258
[0000.372] MAX77620_GPIO5 configured
[0000.375] CPU power rail is up
[0000.378] CPU clock enabled
[0000.382] Performing RAM repair
[0000.385] Updating A64 Warmreset Address to 0xa00002e9
[0000.390] BoardID = 3448, SKU = 0x3
[0000.393] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.397] Nano-SD: checking PT table on QSPI …
[0000.401] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.407] Loading NvTbootBootloaderDTB
[0000.474] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.543] Bootloader DTB Load Address: 0x83000000
[0000.548] BoardID = 3448, SKU = 0x3
[0000.551] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.555] Nano-SD: checking PT table on QSPI …
[0000.559] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.565] Loading NvTbootKernelDTB
[0000.631] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.700] Kernel DTB Load Address: 0x83100000
[0000.704] BoardID = 3448, SKU = 0x3
[0000.708] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.711] Nano-SD: checking PT table on QSPI …
[0000.716] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.723] Loading cboot binary
[0000.839] Verifying EBT in OdmNonSecureSBK mode
[0000.881] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.888] Bootloader downloaded successfully.
[0000.892] BoardID = 3448, SKU = 0x3
[0000.895] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.899] Nano-SD: checking PT table on QSPI …
[0000.903] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.910] PT: Partition NCT NOT found !
[0000.913] Warning: Find Partition via PT Failed
[0000.918] Next binary entry address: 0x92c00258
[0000.922] BoardId: 3448
[0000.927] Overriding pmu board id with proc board id
[0000.932] Display board id is not available
[0000.936] No Bpmp FW loaded
[0000.938] Not loading WB0 as no bpmp/sc7entry fw
[0000.943] Set NvDecSticky Bits
[0000.946] GSC2 address ff93fffc value c0edbbcc
[0000.953] GSC MC Settings done
[0000.955] BoardID = 3448, SKU = 0x3
[0000.959] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.963] Nano-SD: checking PT table on QSPI …
[0000.967] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.974] TOS Image length 53680
[0000.977] Monitor size 53680
[0000.980] OS size 0
[0000.995] Secure Os Aes-CMAC Verification Failed!
[0000.999] Error in NvTbootValidateTOS [18]
[0001.003] Validation of secure os failed!
[0001.007] TOS partition is corrupted!
[0001.011] *** Set to failover in the next boot ***
[0001.015] NvTbootFailControlSetClobber:
[0001.019] *** Rebooting ***
[0000.157] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.162] Processing in cold boot mode Bootloader 2
[0000.167] A02 Bootrom Patch rev = 1023
[0000.171] Power-up reason: software reset
[0000.174] No Battery Present
[0000.177] pmic max77620 reset reason
[0000.180] pmic max77620 NVERC : 0x0
[0000.184] RamCode = 1
[0000.186] Platform has DDR4 type RAM
[0000.189] max77620 disabling SD1 Remote Sense
[0000.193] Setting DDR voltage to 1125mv
[0000.197] Serial Number of Pmic Max77663: 0x1e1bf7
[0000.205] Entering ramdump check
[0000.208] Get RamDumpCarveOut = 0x0
[0000.211] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.216] Last reboot was clean, booting normally!
[0000.221] Sdram initialization is successful
[0000.225] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.231] Lp0 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.237] BpmpFw Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.243] GSC1 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.249] Resize the SecureOs Carveout to 0x00100000
[0000.253] GSC2 Carveout Base=0x00000000ff900000 Size=0x00100000
[0000.259] GSC4 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.265] GSC5 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.271] GSC3 Carveout Base=0x00000000bf800000 Size=0x00200000
[0000.277] RamDump Carveout Base=0x0000000000000000 Size=0x00000000
[0000.283] Platform-DebugCarveout: 0
[0000.286] Nck Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.291] Non secure mode, and RB not enabled.
[0000.296] BoardID = 3448, SKU = 0x3
[0000.299] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.303] Nano-SD: checking PT table on QSPI …
[0000.307] NvTbootFailControlDoFailover: Doing failover: NvTboot partition 1 is.
[0000.316] NvTbootFailControlDoClobber:
[0000.319] Current BFS=0
[0000.322] No write function to write to current BFS 0
[0000.326] Clobber: returns e=0x1
[0000.329] - failover failed; Continuing with bad image …
[0000.335] Read PT from (2:0)
[0000.365] PT crc32 and magic check passed.
[0000.369] Using BFS PT to query partitions
[0000.375] Loading Tboot-CPU binary
[0000.403] Verifying TBC in OdmNonSecureSBK mode
[0000.413] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.420] Bootloader downloaded successfully.
[0000.424] Downloaded Tboot-CPU binary to 0xa0000258
[0000.429] MAX77620_GPIO5 configured
[0000.433] CPU power rail is up
[0000.435] CPU clock enabled
[0000.439] Performing RAM repair
[0000.442] Updating A64 Warmreset Address to 0xa00002e9
[0000.447] BoardID = 3448, SKU = 0x3
[0000.451] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.454] Nano-SD: checking PT table on QSPI …
[0000.459] NvTbootFailControlDoFailover: Doing failover: NvTboot partition 1 is.
[0000.467] NvTbootFailControlDoClobber:
[0000.471] Current BFS=0
[0000.473] No write function to write to current BFS 0
[0000.478] Clobber: returns e=0x1
[0000.481] - failover failed; Continuing with bad image …
[0000.486] Loading NvTbootBootloaderDTB
[0000.553] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.622] Bootloader DTB Load Address: 0x83000000
[0000.627] BoardID = 3448, SKU = 0x3
[0000.630] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.634] Nano-SD: checking PT table on QSPI …
[0000.638] NvTbootFailControlDoFailover: Doing failover: NvTboot partition 1 is.
[0000.647] NvTbootFailControlDoClobber:
[0000.650] Current BFS=0
[0000.652] No write function to write to current BFS 0
[0000.657] Clobber: returns e=0x1
[0000.660] - failover failed; Continuing with bad image …
[0000.666] Loading NvTbootKernelDTB
[0000.732] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.801] Kernel DTB Load Address: 0x83100000
[0000.805] BoardID = 3448, SKU = 0x3
[0000.808] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.812] Nano-SD: checking PT table on QSPI …
[0000.816] NvTbootFailControlDoFailover: Doing failover: NvTboot partition 1 is.
[0000.825] NvTbootFailControlDoClobber:
[0000.828] Current BFS=0
[0000.831] No write function to write to current BFS 0
[0000.836] Clobber: returns e=0x1
[0000.839] - failover failed; Continuing with bad image …
[0000.846] Loading cboot binary
[0000.961] Verifying EBT in OdmNonSecureSBK mode
[0001.003] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.010] Bootloader downloaded successfully.
[0001.014] BoardID = 3448, SKU = 0x3
[0001.018] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.021] Nano-SD: checking PT table on QSPI …
[0001.026] NvTbootFailControlDoFailover: Doing failover: NvTboot partition 1 is.
[0001.034] NvTbootFailControlDoClobber:
[0001.038] Current BFS=0
[0001.040] No write function to write to current BFS 0
[0001.045] Clobber: returns e=0x1
[0001.048] - failover failed; Continuing with bad image …
[0001.054] PT: Partition NCT NOT found !
[0001.057] Warning: Find Partition via PT Failed
[0001.062] Next binary entry address: 0x92c00258
[0001.066] BoardId: 3448
[0001.071] Overriding pmu board id with proc board id
[0001.075] Display board id is not available
[0001.080] No Bpmp FW loaded
[0001.082] Not loading WB0 as no bpmp/sc7entry fw
[0001.087] Set NvDecSticky Bits
[0001.090] GSC2 address ff93fffc value c0edbbcc
[0001.096] GSC MC Settings done
[0001.099] BoardID = 3448, SKU = 0x3
[0001.103] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.106] Nano-SD: checking PT table on QSPI …
[0001.111] NvTbootFailControlDoFailover: Doing failover: NvTboot partition 1 is.
[0001.120] NvTbootFailControlDoClobber:
[0001.123] Current BFS=0
[0001.125] No write function to write to current BFS 0
[0001.130] Clobber: returns e=0x1
[0001.133] - failover failed; Continuing with bad image …
[0001.139] TOS Image length 53680
[0001.142] Monitor size 53680
[0001.145] OS size 0
[0001.161] Secure Os Aes-CMAC Verification Failed!
[0001.165] Error in NvTbootValidateTOS [18]
[0001.169] Validation of secure os failed!
[0001.173] TOS partition is corrupted!
[0001.176] *** Set to failover in the next boot ***
[0001.181] NvTbootFailControlSetClobber:
[0001.184] *** Rebooting ***
[0000.626] BoardID = 3448, SKU = 0x3
I have no experience with this kind of problem and don’t even know where to start searching in the forum and what topics are relevant for further error analysis. So thanks for any help :)
Please reflash the board with sdkmanager. sdcard image cannot save this situation.
