I am using a 1080p HDMI monitor with my jetson nano 2gb. The resolution cannot be changed and the resolution is always 640x480. What can be the issue for this ?
The green power LED also takes few seconds to light up
Thanks in advanced
Thanks in advanced
Please connect the monitor to it, boot up and dump the dmesg.
Thank you @WayneWWW I was able to solve the problem. It was a power supply issue
The power supply to jetson?
I am using a external power supply with a power distribution circuit made by me using a relay. The relay had an issue and was not working properly
