hello, recently i buyed a jetson nano.
I flashed a 128GB sd and tried to boot it, but the display turn on and off (it works with my raspberry), sometimes the first configuration screen appears. I used 5V-4A and 5V-2A power supplies, in both cases the same happened. The display just has a dvi analog and digital port, and a VGA port.
I connected the board with a HDMI adapter. That would be the problem?
Do i need a Screen with only HDMI or DP?
here you can see the problem:
