Dear all,
Using the Nano, I have an Internet connection through an USB LTE modem.
Also, I have a Wifi card embedded in the Jetson Nano Dev. Board.
Is it possible to build a bridge between the Modem and Wifi to have a Wifi Hotspot ?
Thanks for your help and support.
Best regards,
We have a usecase in which bridging the usb device with the host ethernet.
If you connect usb otg cable to your nano, there would be a device mount on your host and there is a document README-usb-dev-mode.txt. Please take a look at the ip-forwarding section.
Thank you WayneWWW,
I will have a look and let you know.
Regards,
