When I was testing i2c, I modified the eeprom value by mistake.
nvidia@ubuntu:/opt/nvidia/jetson-gpio$ i2cdump -f -y 2 0x50
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 01 00 fc 00 78 0d 02 00 04 4d 00 00 00 00 00 00 ?.?.x??.?M......
10: 00 00 00 00 36 39 39 2d 31 33 34 34 38 2d 30 30 ....699-13448-00
20: 30 32 2d 34 30 31 20 4d 2e 30 00 00 00 00 00 00 02-401 M.0......
30: 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
40: ff ff ff ff da 30 e0 2d b0 48 31 34 32 31 32 32 ....?0?-?H142122
50: 33 30 34 33 37 37 37 00 00 00 00 00 00 00 00 00 3043777.........
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
90: 00 00 00 00 00 00 4e 56 43 42 1c 00 4d 31 00 00 ......NVCB?.M1..
a0: ff ff ff ff ff ff ff ff ff ff ff ff da 30 e0 2d ............?0?-
b0: b0 48 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ?H..............
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 bf ...............?
nvidia@ubuntu:/opt/nvidia/jetson-gpio$ sudo i2cset -r 2 0x50 0x00 0x99
WARNING! This program can confuse your I2C bus, cause data loss and worse!
DANGEROUS! Writing to a serial EEPROM on a memory DIMM
may render your memory USELESS and make your system UNBOOTABLE!
I will write to device file /dev/i2c-2, chip address 0x50, data address
0x00, data 0x99, mode byte.
Continue? [y/N] y
Warning - readback failed
00: 99 00 fc 00 78 0d 02 00 04 4d 00 00 00 00 00 00 ?.?.x??.?M......
Then my Nano cannot boot.My carrier is B01.My nano is with eMMC.
So I try to use flash.sh to rebulid the system.
And I followed the steps in this link,but I failed.
After i2cset test, nano can’t boot in eMMC boot evironment - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
This is what i changed .
bk@ubuntu:~/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra$ sudo ./flash.sh jetson-nano-emmc mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 6.1
# Target Board Information:
# Name: jetson-nano-emmc, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
# Disk encryption: disabled ,
Board ID(3448) version(400)
copying bctfile(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
copying bcffile(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cfg/board_config_p3448.xml)... done.
Existing sosfile(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
copying wb0boot(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)... done.
Copying nv_boot_control.conf to rootfs
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra210-p3448-0002-p3449-0000-b00.dtb to rootfs... done.
Making system.img...
populating rootfs from /home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)... done.
copying cfgfile(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_emmc_p3448.xml) to flash.xml... done.
copying flasher(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin –bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0002-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --boardconfig board_config_p3448.xml --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --skipuid --bins "EBT cboot.bin; DTB tegra210-p3448-0002-p3449-0000-b00.dtb"
saving flash command in /home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/bk/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
assign_value: crc-flash.xml.bin 1 131056 1
printf '\x1' | dd of=crc-flash.xml.bin bs=1 seek=131056 count=1 conv=notrunc
1+0 records in
1+0 records out
1 byte copied, 0.000108442 s, 9.2 kB/s
assign_value: crc-flash.xml.bin 0 131057 1
printf '\x0' | dd of=crc-flash.xml.bin bs=1 seek=131057 count=1 conv=notrunc
1+0 records in
1+0 records out
1 byte copied, 0.000109074 s, 9.2 kB/s
assign_string: crc-flash.xml.bin PTHD 131064 4
echo PTHD | dd of=crc-flash.xml.bin bs=1 seek=131064 count=4 conv=notrunc
4+0 records in
4+0 records out
4 bytes copied, 8.9836e-05 s, 44.5 kB/s
*** Flashing target device started. ***
File "./tegraflash.py", line 1238, in <module>
chip = chip.replace(' ', ' ')
AttributeError: 'NoneType' object has no attribute 'replace'
Failed flashing t210ref.
I have tried several time it all failed with the same error. I am wondering what I should do now.
Hi caodingrui,
Are you using the devkit or custom board for Jetson Nano?
So, do you write the correct data back to EEPROM before flash?
Please try using the following command to flash the board.
$ sudo FAB=400 BOARDID=3448 BOARDSKU=0002 ./flash.sh jetson-nano-emmc mmcblk0p1
1.I am using a devkit.
2.I am using Jetpack 4.6.
3.It wasn’t until the next time I rebooted the device that I realized I had made the mistake.The system was no longer booting, so I couldn’t change the value back.
4.This is the result after executing the command, which looks the same as before.
bk@ubuntu:~/Desktop/flashnano/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra$ sudo FAB=400 BOARDID=3448 BOARDSKU=0002 ./flash.sh jetson-nano-emmc mmcblk0p1
[sudo] password for bk:
1+0 records in
1+0 records out
1 byte copied, 0.000140216 s, 7.1 kB/s
1+0 records in
1+0 records out
1 byte copied, 0.000100961 s, 9.9 kB/s
4+0 records in
4+0 records out
4 bytes copied, 8.463e-05 s, 47.3 kB/s
Let me be clear about what I have changed .
Jetson-nano-emmc.conf
BOARDID="3448";
FAB="400";
BOARDSKU="0002";
BOARDREV="70";
p3448-0000.conf.common
BCT="–bct ";
VERFILENAME="qspi_bootblob_ver.txt";
BCFFILE="bootloader/${target_board}/cfg/board_config_p3448.xml";
All right .It seems that I find whats wrong.
The following is correct.I deleted one of the - before the bct.
BCT="-–bct ";
After I fix that mistake,it still cannot work.
./tegraflash.py --bl cboot.bin -–bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0002-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --boardconfig board_config_p3448.xml --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --skipuid --bins "EBT cboot.bin; DTB tegra210-p3448-0002-p3449-0000-b00.dtb"
1+0 records in
1+0 records out
1 byte copied, 5.8771e-05 s, 17.0 kB/s
1+0 records in
1+0 records out
1 byte copied, 6.1376e-05 s, 16.3 kB/s
4+0 records in
4+0 records out
4 bytes copied, 3.71e-05 s, 108 kB/s
Usage: tegraflash [--bct <file>] [--bct_cold_boot <file>] [--cfg <file>] [--bl <file>] [--instance <number>]
[--chip <number>] [--dtb <file>] [--bldtb <file>] [--kerneldtb <file>] [--key <file>] [--encrypt_key <file> [--cmd "commands"] [--bpfldtb <file>]
[--applet <file>] [--nct <file>] [--hostbin <dir>] [--out <dir>]
[--boardconfig <file>] [--skipuid] [--securedev] [--keyindex <number>]
[--bl-load <addr>] [--dev_params <file>] [--sdram_config <file>] [--ramcode <index>]
[--bins <image_type> <file> [load_address][;...]]
[--misc_config <file>] [--mb1_bct <file>] [--blversion <number> <number>]
[--pinmux_config <file>] [--pmc <file>] [--scr_config <file>]
[--pmic_config <file>] [--br_cmd_config <file>] [--prod_config <file]
[--gpioint_config <file>] [--uphy_config <file>] [--device_config <file>]
[--deviceprod_config <file>] [--minratchet_config <file>] [--skipsanitize] [--keep]
[--external_device]
--bct : Bootrom Boot Config Table file
--bct_cold_boot : Bootrom Boot Config Table file for cold boot
--cfg : Partition layout configuration file
--bl : Command line bootloader
--bl-load : Bootloader load/entry address
--chip : Chip Id
--blversion : Major and Minor version of bootloader loaded by BOOTROM
--dtb : DTB file to be used by both (old implementation, to deprecate in future)
--bldtb : DTB file to be used by cboot
--kerneldtb : DTB file to be used by kernel
--bpfdtb : DTB file to be used by BPMP-FW
--key : Key for signing required files
--encrypt_key : Key for encrypting required files
--applet : Applet to be sent to BootRom
--nct : NCT file
--boardconfig : File containing board configuration
--skipuid : Skip reading Chip UID
--skipsanitize : Skip SDMMC sanitize
--securedev : path for flashing fused devices
--keyindex : FSKP key index
--cmd : List of comma(;) separated commands
--dev_params : Boot device parameters
--sdram_config : Sdram configuration
--ramcode : The ramcode value
--bins : List of binaries to be downloaded separated by commad(;)
--misc_config : Misc BCT configuration
--misc_cold_boot_config : Misc BCT configuration to be used in coldboot
--pinmux_config : Pinmux BCT configuration
--scr_config : SCR BCT configuration
--scr_cold_boot_config : SCR BCT configuration to be used in coldboot
--pmc_onfig : Pad voltage - DPD BCT configuration
--pmic_config : PMIC - Rails MMIO/I2C Commands BCT configuration
--br_cmd_config : BootROM MMIO/I2C Commands BCT configuration
--prod_config : Pinmux prod setings BCT configuration
--gpioint_config : GPIO interrupt routing configurations
--uphy_config : Uphy Lane ownership mapping configrations
--device_config : Device specific platform configurations
--deviceprod_config : Device specific Prod configurations
--minratchet_config : Minimum ratchet level of oem-fw
--mb1_bct : MB1 BCT file
--mb1_cold_boot_bct: MB1 BCT file used in coldboot
--soft_fuses : MB1 Soft fuse config
--hostbin : Directory contaning host binaries
--out : Directory containing device files
--keep : Keep temporary directory
--external_device: Generate images for an external device
--ignorebfs : If user use this option, NO Fail-safe OTA
--trim_bpmp_dtb : Remove unused emc strap data from BPMP dtb
Could you verify with the latest JP4.6.4(R32.7.4) w/o any change?
and use this command to flash the board.
I cannot find where to download the whole JP4.6.4.So I downloaded Jetson-210_Linux_R32.7.4_aarch64.tbz2,and tried the command.
This time I hit a different error.
bk@ubuntu:~/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra$ sudo FAB=400 BOARDID=3448 BOARDSKU=0002 ./flash.sh jetson-nano-emmc mmcblk0p1
# R32 , REVISION: 7.4
copying bctfile(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Existing sosfile(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
copying wb0boot(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/eks.img) reused.
./flash.sh: line 2661: [: : integer expression expected
copying dtbfile(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)... done.
sed: can't read /home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/rootfs/etc/nv_boot_control.conf: Not a directory
/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/rootfs/boot/extlinux/extlinux.conf is not found, exiting...
Jetson Linux R32.7.4 | NVIDIA Developer
In this link ,I can see many links which one I should download.Can you point it out for me?
Jetpack4.6.4 is 32.7.4. No need to find anything else.
What you are missing is you should follow the whole steps here to prepare the BSP.
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3273/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/quick_start.html#
→ To flash Jetson Developer Kit operating software
Otherwise you will hit such issue again. The flash process is totally not started.
/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/rootfs/boot/extlinux/extlinux.conf is not found, exiting…
All right.I think I understand how to do this.I refered to the following links steps.
This solution should work on rel-32.3.1 as well.
I did it in rel-32.3.1 like following step.
Step 1: uncompress Tegra210_Linux_R32.3.1_aarch64.tbz2
Step 2: uncompress Tegra_Linux_Sample-Root-Filesystem_R32.3.1_aarch64.tbz2
Step 3: run “sudo ./apply_binaries.sh”
Step 4: modify p3448-0000.conf.common
[Linux_for_Tegra/p3448-0000.conf.common]
BCT="–bct ";
VERFILENAME=“qspi_bootblob_ver.txt”;
BCFFILE=“bootloader/${target_board}/cfg/board_config_p3448.xml”;
Step 5: confirm board_…
But I still failed. Here is my steps.
1.uncompress Jetson-210_Linux_R32.7.4_aarch64;
2.uncopress Tegra_Linux_Sample-Root-Filesystem_R32.7.4_aarch64;
3.
sudo ./applu_binaries.sh
set Nano to RCM
populating rootfs from /home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
Existing tbcfile(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)... done.
copying cfgfile(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_emmc_p3448.xml) to flash.xml... done.
copying flasher(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0002-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --skipuid --bins "EBT cboot.bin; DTB tegra210-p3448-0002-p3449-0000-b00.dtb"
saving flash command in /home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/flash_win.bat
1+0 records in
1+0 records out
1 byte copied, 6.2038e-05 s, 16.1 kB/s
1+0 records in
1+0 records out
1 byte copied, 4.3623e-05 s, 22.9 kB/s
4+0 records in
4+0 records out
4 bytes copied, 3.7751e-05 s, 106 kB/s
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0115 ] tegrasign --getmode mode.txt --key None
[ 0.0141 ] Assuming zero filled SBK key
[ 0.0196 ]
[ 0.0199 ] Generating RCM messages
[ 0.0255 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0272 ] RCM 0 is saved as rcm_0.rcm
[ 0.0337 ] RCM 1 is saved as rcm_1.rcm
[ 0.0337 ] List of rcm files are saved in rcm_list.xml
[ 0.0337 ]
[ 0.0337 ] Signing RCM messages
[ 0.0363 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0382 ] Assuming zero filled SBK key
[ 0.0425 ]
[ 0.0426 ] Copying signature to RCM mesages
[ 0.0454 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0489 ]
[ 0.0491 ] Parsing partition layout
[ 0.0519 ] tegraparser --pt flash.xml.tmp
[ 0.0539 ]
[ 0.0541 ] Using default ramcode: 0
[ 0.0541 ] Disable BPMP dtb trim, using default dtb
[ 0.0541 ]
[ 0.0542 ] Creating list of images to be signed
[ 0.0573 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0919 ]
[ 0.0919 ] Generating signatures
[ 0.0944 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0959 ] Assuming zero filled SBK key
[ 0.1886 ]
[ 0.1888 ] Generating br-bct
[ 0.1945 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.2038 ]
[ 0.2039 ] Updating boot device parameters
[ 0.2087 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.2113 ] Warning: No sdram params
[ 0.2118 ]
[ 0.2118 ] Updating bl info
[ 0.2144 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.2174 ]
[ 0.2174 ] Updating secondary storage information into bct
[ 0.2204 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.2223 ]
[ 0.2224 ] Updating Odmdata
[ 0.2254 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 0.2268 ] Warning: No sdram params
[ 0.2272 ]
[ 0.2273 ] Get Signed section of bct
[ 0.2301 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.2331 ]
[ 0.2332 ] Signing BCT
[ 0.2387 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.2408 ] Assuming zero filled SBK key
[ 0.2415 ]
[ 0.2415 ] Updating BCT with signature
[ 0.2449 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.2468 ]
[ 0.2469 ] Copying signatures
[ 0.2495 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.2722 ]
[ 0.2728 ] Updating BFS information on BCT
[ 0.2775 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.2787 ] BFS:
[ 0.2804 ] 0: [PT ] crc-flash.xml.bin (size=131072/131072)
[ 0.2807 ] 1: [TBC] nvtboot_cpu.bin.encrypt (size=80672/196608)
[ 0.2810 ] 2: [RP1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.2820 ] 3: [EBT] cboot.bin.encrypt (size=485952/655360)
[ 0.2825 ] 4: [WB0] warmboot.bin.encrypt (size=3952/131072)
[ 0.2829 ] 5: [BPF] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 0.2832 ] BFS0: 131072 @ 2560 SUM c91fd17f over 2883584 bytes
[ 0.2846 ] BFS:
[ 0.2848 ] 0: [PT-1] crc-flash.xml.bin (size=131072/131072)
[ 0.2850 ] 1: [TBC-1] nvtboot_cpu.bin.encrypt (size=80672/196608)
[ 0.2852 ] 2: [RP1-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.2863 ] 3: [EBT-1] cboot.bin.encrypt (size=485952/655360)
[ 0.2870 ] 4: [WB0-1] warmboot.bin.encrypt (size=3952/131072)
[ 0.2880 ] 5: [BPF-1] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 0.2888 ] 8: [VER_b] emmc_bootblob_ver.txt (size=102/32768)
[ 0.2892 ] 9: [VER] emmc_bootblob_ver.txt (size=102/32768)
[ 0.2895 ] BFS1: 131072 @ 8704 SUM c91fd17f over 2981888 bytes
[ 0.2897 ] KFS:
[ 0.3454 ] 0: [DTB] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.3465 ] 1: [TOS] tos-mon-only.img.encrypt (size=54208/6291456)
[ 0.3468 ] 2: [EKS] eks.img (size=1028/81920)
[ 0.3470 ] 3: [LNX] boot.img.encrypt (size=667648/67092480)
[ 0.3485 ] KFS0: 1048576 @ 29376546 SUM c97b90a6 over 8089600 bytes
[ 0.3541 ] KFS:
[ 0.3971 ] 0: [DTB-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.3979 ] 1: [TOS-1] tos-mon-only.img.encrypt (size=54208/6291456)
[ 0.3984 ] 2: [EKS-1] eks.img (size=1028/81920)
[ 0.3986 ] 3: [LNX-1] boot.img.encrypt (size=667648/67092480)
[ 0.3999 ] KFS1: 1048576 @ 29522082 SUM c97b90a6 over 8089600 bytes
[ 0.4087 ]
[ 0.4088 ] Boot Rom communication
[ 0.4124 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.4136 ] RCM version 0X210001
[ 2.1063 ] Boot Rom communication completed
[ 3.1334 ]
[ 3.1334 ] Sending BCTs
[ 3.1365 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 3.1375 ] Applet version 00.01.0000
[ 3.2759 ] Sending bct
[ 3.2759 ] [................................................] 100%
[ 3.4144 ]
[ 3.4181 ] tegrahost --chip 0x21 --align cboot.bin
[ 3.4195 ]
[ 3.4223 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 3.4263 ]
[ 3.4284 ] tegrasign --key None --list cboot.bin_list.xml
[ 3.4295 ] Assuming zero filled SBK key
[ 3.4415 ]
[ 3.4434 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 3.4460 ]
[ 3.4501 ] tegrahost --chip 0x21 --align tegra210-p3448-0002-p3449-0000-b00.dtb
[ 3.4522 ]
[ 3.4552 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0002-p3449-0000-b00.dtb tegra210-p3448-0002-p3449-0000-b00.dtb_blheader
[ 3.4592 ]
[ 3.4631 ] tegrasign --key None --list tegra210-p3448-0002-p3449-0000-b00.dtb_list.xml
[ 3.4656 ] Assuming zero filled SBK key
[ 3.4713 ]
[ 3.4735 ] tegrahost --updatesigheader tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.hash zerosbk
[ 3.4759 ]
[ 3.4766 ] Sending bootloader and pre-requisite binaries
[ 3.4808 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt 0
[ 3.4830 ] Applet version 00.01.0000
[ 3.7515 ] Sending ebt
[ 3.8901 ]
Error: Return value 1
Command tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt 0
Here is the uart log .
[0115.302] Enabled early print
[11:18:06.625] [0115.304] [L4T TegraBoot] (version 遘濵qY罂蘹Aj恾罶狌┹r ǜ魻薅搬xhx誄蕷!螜
[11:18:06.625] [0115.313] Processing in recovery mode
[11:18:06.625] [0115.316] A02 Bootrom Patch rev = 1023
[11:18:06.625] [0115.320] Power-up reason: pmc por
[11:18:06.625] [0115.323] Established communication link with host
[11:18:06.625]
[0116.453] Odmdata from BCT: 0x000a4000
[11:18:07.784] [0116.457] DebugPort= 0x3
[11:18:07.784] [0116.459] SkipQspiOnly= 0x0
[11:18:07.784]
[0116.511] EEPROM CRC failed. Calculated crc=0x6c CRC stored = 0xbf
[11:18:07.844] [0116.517] Reading Board-Type unsuccessful
[11:18:07.844] [0116.521] BoardId read from EEPROM/NCT: 0
[11:18:07.854] [0116.525] Unsupported Platform 0
[11:18:07.854] [0116.528] Downloaded BCT successfully
[11:18:07.854]
I can flash after this step.But the connected moniter is still black.I think the Nano still cannot boot.
Add lines BCFFILE="bootloader/${target_board}/cfg/board_config_p3448.xml" to file p3448-0000.conf.common
Sorry, try again.
copying bcffile(/home/bk/32.7/Jetson-210_Linux_R32.7.4_aarch64/Linux_for_Tegra/bootloader/t210ref/cfg/board_config_p3448.xml)... done.
./tegraflash.py --bl cboot.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0002-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --boardconfig board_config_p3448.xml --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --skipuid --bins "EBT cboot.bin; DTB tegra210-p3448-0002-p3449-0000-b00.dtb"
1+0 records in
1+0 records out
1 byte copied, 6.4852e-05 s, 15.4 kB/s
1+0 records in
1+0 records out
1 byte copied, 3.8252e-05 s, 26.1 kB/s
4+0 records in
4+0 records out
4 bytes copied, 5.7297e-05 s, 69.8 kB/s
version 1.0.0
[ 0.0122 ] tegrasign --getmode mode.txt --key None
[ 0.0143 ] Assuming zero filled SBK key
[ 0.0190 ]
[ 0.0192 ] Generating RCM messages
[ 0.0244 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0256 ] RCM 0 is saved as rcm_0.rcm
[ 0.0300 ] RCM 1 is saved as rcm_1.rcm
[ 0.0304 ] List of rcm files are saved in rcm_list.xml
[ 0.0304 ]
[ 0.0304 ] Signing RCM messages
[ 0.0331 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0353 ] Assuming zero filled SBK key
[ 0.0426 ]
[ 0.0427 ] Copying signature to RCM mesages
[ 0.0442 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0471 ]
[ 0.0472 ] Parsing partition layout
[ 0.0502 ] tegraparser --pt flash.xml.tmp
[ 0.0519 ]
[ 0.0520 ] Using default ramcode: 0
[ 0.0521 ] Disable BPMP dtb trim, using default dtb
[ 0.0521 ]
[ 0.0521 ] Creating list of images to be signed
[ 0.0552 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0872 ]
[ 0.0873 ] Generating signatures
[ 0.0902 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0914 ] Assuming zero filled SBK key
[ 0.1846 ]
[ 0.1847 ] Generating br-bct
[ 0.1893 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.1975 ]
[ 0.1976 ] Updating boot device parameters
[ 0.2013 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.2029 ] Warning: No sdram params
[ 0.2041 ]
[ 0.2042 ] Updating bl info
[ 0.2073 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.2096 ]
[ 0.2097 ] Updating secondary storage information into bct
[ 0.2121 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.2144 ]
[ 0.2145 ] Updating board information from board config into bct
[ 0.2174 ] tegraparser --boardconfig board_config_p3448.xml --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.2196 ]
[ 0.2196 ] Updating Odmdata
[ 0.2232 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 0.2248 ] Warning: No sdram params
[ 0.2262 ]
[ 0.2263 ] Get Signed section of bct
[ 0.2304 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.2322 ]
[ 0.2323 ] Signing BCT
[ 0.2383 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.2401 ] Assuming zero filled SBK key
[ 0.2410 ]
[ 0.2411 ] Updating BCT with signature
[ 0.2443 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.2458 ]
[ 0.2458 ] Copying signatures
[ 0.2484 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.2622 ]
[ 0.2624 ] Updating BFS information on BCT
[ 0.2644 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.2656 ] BFS:
[ 0.2669 ] 0: [PT ] crc-flash.xml.bin (size=131072/131072)
[ 0.2674 ] 1: [TBC] nvtboot_cpu.bin.encrypt (size=80672/196608)
[ 0.2678 ] 2: [RP1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.2697 ] 3: [EBT] cboot.bin.encrypt (size=485952/655360)
[ 0.2707 ] 4: [WB0] warmboot.bin.encrypt (size=3952/131072)
[ 0.2716 ] 5: [BPF] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 0.2728 ] BFS0: 131072 @ 2560 SUM 6c8a34e0 over 2883584 bytes
[ 0.2738 ] BFS:
[ 0.2740 ] 0: [PT-1] crc-flash.xml.bin (size=131072/131072)
[ 0.2773 ] 1: [TBC-1] nvtboot_cpu.bin.encrypt (size=80672/196608)
[ 0.2781 ] 2: [RP1-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.2792 ] 3: [EBT-1] cboot.bin.encrypt (size=485952/655360)
[ 0.2797 ] 4: [WB0-1] warmboot.bin.encrypt (size=3952/131072)
[ 0.2804 ] 5: [BPF-1] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 0.2812 ] 8: [VER_b] emmc_bootblob_ver.txt (size=101/32768)
[ 0.2821 ] 9: [VER] emmc_bootblob_ver.txt (size=101/32768)
[ 0.2830 ] BFS1: 131072 @ 8704 SUM 6c8a34e0 over 2981888 bytes
[ 0.2839 ] KFS:
[ 0.3118 ] 0: [DTB] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.3129 ] 1: [TOS] tos-mon-only.img.encrypt (size=54208/6291456)
[ 0.3133 ] 2: [EKS] eks.img (size=1028/81920)
[ 0.3135 ] 3: [LNX] boot.img.encrypt (size=667648/67092480)
[ 0.3152 ] KFS0: 1048576 @ 29376546 SUM c97b90a6 over 8089600 bytes
[ 0.3218 ] KFS:
[ 0.3573 ] 0: [DTB-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.3584 ] 1: [TOS-1] tos-mon-only.img.encrypt (size=54208/6291456)
[ 0.3587 ] 2: [EKS-1] eks.img (size=1028/81920)
[ 0.3588 ] 3: [LNX-1] boot.img.encrypt (size=667648/67092480)
[ 0.3591 ] KFS1: 1048576 @ 29522082 SUM c97b90a6 over 8089600 bytes
[ 0.3674 ]
[ 0.3674 ] Boot Rom communication
[ 0.3704 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.3718 ] RCM version 0X210001
[ 0.6703 ] Boot Rom communication completed
[ 1.6938 ]
[ 1.6938 ] Sending BCTs
[ 1.6972 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 1.6982 ] Applet version 00.01.0000
[ 1.8441 ] Sending bct
[ 1.8442 ] [................................................] 100%
[ 2.0684 ]
[ 2.0703 ] tegrahost --chip 0x21 --align cboot.bin
[ 2.0713 ]
[ 2.0740 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 2.0773 ]
[ 2.0809 ] tegrasign --key None --list cboot.bin_list.xml
[ 2.0833 ] Assuming zero filled SBK key
[ 2.0935 ]
[ 2.0970 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 2.1006 ]
[ 2.1042 ] tegrahost --chip 0x21 --align tegra210-p3448-0002-p3449-0000-b00.dtb
[ 2.1057 ]
[ 2.1076 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0002-p3449-0000-b00.dtb tegra210-p3448-0002-p3449-0000-b00.dtb_blheader
[ 2.1111 ]
[ 2.1143 ] tegrasign --key None --list tegra210-p3448-0002-p3449-0000-b00.dtb_list.xml
[ 2.1182 ] Assuming zero filled SBK key
[ 2.1246 ]
[ 2.1286 ] tegrahost --updatesigheader tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.hash zerosbk
[ 2.1327 ]
[ 2.1337 ] Sending bootloader and pre-requisite binaries
[ 2.1370 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt 0
[ 2.1391 ] Applet version 00.01.0000
[ 2.2787 ] Sending ebt
[ 2.2788 ] [................................................] 100%
[ 2.4559 ] Sending rp1
[ 2.4806 ] [................................................] 100%
[ 2.6015 ]
[ 2.6036 ] tegrarcm --boot recovery
[ 2.6051 ] Applet version 00.01.0000
[ 2.9159 ]
[ 2.9159 ] Retrieving storage infomation
[ 2.9205 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 2.9218 ] Applet is not running on device. Continue with Bootloader
[ 3.5569 ]
[ 3.5623 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 3.5642 ] Cboot version 00.01.0000
[ 3.7068 ] Saved platform info in storage_info.bin
[ 3.7616 ]
[ 3.7617 ] Flashing the device
[ 3.7655 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 3.7680 ] Cboot version 00.01.0000
[ 3.9177 ] Writing partition GPT with gpt.bin
[ 3.9180 ] [................................................] 100%
[ 3.9563 ] Writing partition PT with crc-flash.xml.bin
[ 5.1751 ] [................................................] 100%
[ 5.2228 ] Writing partition PT-1 with crc-flash.xml.bin
[ 5.2563 ] [................................................] 100%
[ 5.3168 ] Writing partition NVC with nvtboot.bin.encrypt
[ 5.3788 ] [................................................] 100%
[ 5.4400 ] Writing partition TBC with nvtboot_cpu.bin.encrypt
[ 5.4892 ] [................................................] 100%
[ 5.5460 ] Writing partition RP1 with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 5.6233 ] [................................................] 100%
[ 5.6970 ] Writing partition EBT with cboot.bin.encrypt
[ 5.7677 ] [................................................] 100%
[ 5.8718 ] Writing partition WB0 with warmboot.bin.encrypt
[ 5.9445 ] [................................................] 100%
[ 5.9933 ] Writing partition BPF with sc7entry-firmware.bin.encrypt
[ 6.0629 ] [................................................] 100%
[ 6.1115 ] Writing partition NVC-1 with nvtboot.bin.encrypt
[ 6.1797 ] [................................................] 100%
[ 6.2472 ] Writing partition TBC-1 with nvtboot_cpu.bin.encrypt
[ 6.3297 ] [................................................] 100%
[ 6.3864 ] Writing partition RP1-1 with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 6.4663 ] [................................................] 100%
[ 6.5412 ] Writing partition EBT-1 with cboot.bin.encrypt
[ 6.6246 ] [................................................] 100%
[ 6.7305 ] Writing partition WB0-1 with warmboot.bin.encrypt
[ 6.8168 ] [................................................] 100%
[ 6.8643 ] Writing partition BPF-1 with sc7entry-firmware.bin.encrypt
[ 6.9459 ] [................................................] 100%
[ 6.9943 ] Writing partition VER_b with emmc_bootblob_ver.txt
[ 7.0746 ] [................................................] 100%
[ 7.1226 ] Writing partition VER with emmc_bootblob_ver.txt
[ 7.1930 ] [................................................] 100%
[ 7.2416 ] Writing partition APP with system.img
[ 7.3116 ] [................................................] 100%
[ 871.4611 ] Writing partition DTB with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 872.7645 ] [................................................] 100%
[ 872.8352 ] Writing partition TOS with tos-mon-only.img.encrypt
[ 872.8943 ] [................................................] 100%
[ 872.9427 ] Warning: EKS partition magic header mismatch!
[ 872.9996 ] Writing partition EKS with eks.img
[ 872.9998 ] [................................................] 100%
[ 873.0420 ] Writing partition LNX with boot.img.encrypt
[ 873.0964 ] [................................................] 100%
[ 873.2179 ] Writing partition DTB-1 with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 873.2823 ] [................................................] 100%
[ 873.3526 ] Writing partition TOS-1 with tos-mon-only.img.encrypt
[ 873.4103 ] [................................................] 100%
[ 873.4552 ] Writing partition EKS-1 with eks.img
[ 873.5092 ] [................................................] 100%
[ 873.5522 ] Writing partition LNX-1 with boot.img.encrypt
[ 873.6080 ] [................................................] 100%
[ 873.7263 ] Writing partition BMP with bmp.blob
[ 873.7944 ] [................................................] 100%
[ 873.8535 ] Writing partition RP4 with rp4.blob
[ 873.9120 ] [................................................] 100%
[ 874.0269 ]
[ 874.0406 ] tegradevflash --write BCT P3448_A00_lpddr4_204Mhz_P987.bct
[ 874.0426 ] Cboot version 00.01.0000
[ 874.1940 ] Writing partition BCT with P3448_A00_lpddr4_204Mhz_P987.bct
[ 874.1944 ] [................................................] 100%
[ 874.6419 ]
[ 874.6420 ] Flashing completed
[ 874.6422 ] Coldbooting the device
[ 874.6453 ] tegradevflash --reboot coldboot
[ 874.6462 ] Cboot version 00.01.0000
[ 874.8316 ]
*** The target t210ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
please check your serial console log. Please do not rely on the monitor to debug in this situation.
I tried flash again. It looks the same . What should I do now ?
[15:21:30.681] [0992.151] partition APP write successful.
[15:21:30.681]
[0992.188] Writing DTB partition
[15:21:30.704]
[0992.281] partition DTB write successful.
[15:21:30.784]
[0992.318] Writing TOS partition
[15:21:30.824]
[0992.385] partition TOS write successful.
[15:21:30.894]
[0992.421] Writing EKS partition
[15:21:30.924]
[0992.483] partition EKS write successful.
[15:21:30.994]
[0992.518] Writing LNX partition
[15:21:31.024]
[0992.666] partition LNX write successful.
[15:21:31.174]
[0992.702] Writing DTB-1 partition
[15:21:31.204]
[0992.794] partition DTB-1 write successful.
[15:21:31.304]
[0992.831] Writing TOS-1 partition
[15:21:31.334]
[0992.900] partition TOS-1 write successful.
[15:21:31.404]
[0992.935] Writing EKS-1 partition
[15:21:31.444]
[0992.994] partition EKS-1 write successful.
[15:21:31.504]
[0993.032] Writing LNX-1 partition
[15:21:31.534]
[0993.186] partition LNX-1 write successful.
[15:21:31.694]
[0993.225] Writing BMP partition
[15:21:31.734]
[0993.305] partition BMP write successful.
[15:21:31.814]
[0993.342] Writing RP4 partition
[15:21:31.844]
[0993.420] partition RP4 write successful.
[15:21:31.924]
[0993.633] Writing BCT partition
[15:21:32.134]
[0994.047] partition BCT write successful.
[15:21:32.553]
[0994.262] Change state to cold boot mode
[15:21:32.774] [0994.265] Flushing data to stroage
[0000.152] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[15:21:33.154] [0000.157] Processing in cold boot mode Bootloader 2
[15:21:33.154] [0000.162] A02 Bootrom Patch rev = 1023
[15:21:33.154] [0000.165] Power-up reason: software reset
[15:21:33.154] [0000.169] No Battery Present
[15:21:33.154] [0000.172] pmic max77620 reset reason
[15:21:33.154] [0000.175] pmic max77620 NVERC : 0x0
[15:21:33.154] [0000.178] RamCode = 0
[15:21:33.154] [0000.181] Platform has DDR4 type RAM
[15:21:33.154] [0000.184] max77620 disabling SD1 Remote Sense
[15:21:33.154] [0000.188] Setting DDR voltage to 1125mv
[15:21:33.154] [0000.192] Serial Number of Pmic Max77663: 0x261666
[15:21:33.154] [0000.200] Entering ramdump check
[15:21:33.154] [0000.203] Get RamDumpCarveOut = 0x0
[15:21:33.154] [0000.206] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[15:21:33.154] [0000.211] Last reboot was clean, booting normally!
[15:21:33.154] [0000.216] Sdram initialization is successful
[15:21:33.154] [0000.220] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[15:21:33.154] [0000.226] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[15:21:33.154] [0000.232] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[15:21:33.154] [0000.238] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[15:21:33.154] [0000.244] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[15:21:33.154] [0000.249] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[15:21:33.154] [0000.255] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[15:21:33.154] [0000.261] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[15:21:33.154] [0000.277] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[15:21:33.154] [0000.283] Platform-DebugCarveout: 0
[15:21:33.154] [0000.286] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[15:21:33.154] [0000.292] Non secure mode, and RB not enabled.
[15:21:33.154] [0000.296] *** Booting BFS0.
[15:21:33.154] [0000.299] Initialize FailControl
[15:21:33.154] [0000.302] Read PT from (0:3)
[15:21:33.154] [0000.317] Csd NumOfBlocks=0
[15:21:33.154] [0000.357] PT crc32 and magic check passed.
[15:21:33.154] [0000.360] Using BFS PT to query partitions
[15:21:33.154] [0000.365] PT: Partition LNX NOT found !
[15:21:33.154] [0000.368] *** Booting KFS0.
[15:21:33.154] [0000.371] NvTbootFailControlDoFailover: No failover; Continuing ...
[15:21:33.154]
[0000.377] BoardID = 3448, SKU = 0x0
[15:21:33.174] [0000.380] QSPI-ONLY: SkipQspiOnlyFlag = 0
[15:21:33.174] [0000.384] Nano-SD: checking PT table on QSPI ...
[15:21:33.174] [0000.388] NvTbootFailControlDoFailover: No failover; Continuing ...
[15:21:33.174] [0000.395] Loading Tboot-CPU binary
[15:21:33.174] [0000.401] Verifying TBC in OdmNonSecureSBK mode
[15:21:33.184]
[0000.412] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[15:21:33.204] [0000.419] Bootloader downloaded successfully.
[15:21:33.204] [0000.423] Downloaded Tboot-CPU binary to 0xa0000258
[15:21:33.204] [0000.428] MAX77620_GPIO5 configured
[15:21:33.214] [0000.432] CPU power rail is up
[15:21:33.214] [0000.435] CPU clock enabled
[15:21:33.214] [0000.438] Performing RAM repair
[15:21:33.224] [0000.441] Updating A64 Warmreset Address to 0xa00002e9
[15:21:33.224]
[0000.446] BoardID = 3448, SKU = 0x0
[15:21:33.244] [0000.450] QSPI-ONLY: SkipQspiOnlyFlag = 0
[15:21:33.244] [0000.453] Nano-SD: checking PT table on QSPI ...
[15:21:33.244] [0000.458] NvTbootFailControlDoFailover: No failover; Continuing ...
[15:21:33.244] [0000.464] Loading NvTbootBootloaderDTB
[15:21:33.244]
[0000.481] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[15:21:33.264]
[0000.552] Bootloader DTB Load Address: 0x83000000
[15:21:33.334]
[0000.557] BoardID = 3448, SKU = 0x0
[15:21:33.354] [0000.560] QSPI-ONLY: SkipQspiOnlyFlag = 0
[15:21:33.354] [0000.564] Nano-SD: checking PT table on QSPI ...
[15:21:33.354] [0000.568] NvTbootFailControlDoFailover: No failover; Continuing ...
[15:21:33.354] [0000.575] PT: Partition DTB NOT found !
[15:21:33.364] [0000.578] Warning: Find Partition via PT Failed
[15:21:33.364] [0000.583] Error is 1
[15:21:33.364]
Here is the flash log.
1+0 records in
1+0 records out
1 byte copied, 6.355e-05 s, 15.7 kB/s
1+0 records in
1+0 records out
1 byte copied, 3.6603e-05 s, 27.3 kB/s
4+0 records in
4+0 records out
4 bytes copied, 4.4868e-05 s, 89.2 kB/s
version 1.0.0
[ 0.0108 ] tegrasign --getmode mode.txt --key None
[ 0.0127 ] Assuming zero filled SBK key
[ 0.0160 ]
[ 0.0161 ] Generating RCM messages
[ 0.0309 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0329 ] RCM 0 is saved as rcm_0.rcm
[ 0.0384 ] RCM 1 is saved as rcm_1.rcm
[ 0.0386 ] List of rcm files are saved in rcm_list.xml
[ 0.0390 ]
[ 0.0390 ] Signing RCM messages
[ 0.0421 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0441 ] Assuming zero filled SBK key
[ 0.0484 ]
[ 0.0485 ] Copying signature to RCM mesages
[ 0.0520 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0554 ]
[ 0.0554 ] Parsing partition layout
[ 0.0590 ] tegraparser --pt flash.xml.tmp
[ 0.0611 ]
[ 0.0614 ] Using default ramcode: 0
[ 0.0614 ] Disable BPMP dtb trim, using default dtb
[ 0.0614 ]
[ 0.0614 ] Creating list of images to be signed
[ 0.0650 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0987 ]
[ 0.0988 ] Generating signatures
[ 0.1025 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.1045 ] Assuming zero filled SBK key
[ 0.1964 ]
[ 0.1964 ] Generating br-bct
[ 0.2005 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.2080 ]
[ 0.2080 ] Updating boot device parameters
[ 0.2121 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.2141 ] Warning: No sdram params
[ 0.2141 ]
[ 0.2141 ] Updating bl info
[ 0.2175 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.2195 ]
[ 0.2196 ] Updating secondary storage information into bct
[ 0.2224 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.2247 ]
[ 0.2248 ] Updating board information from board config into bct
[ 0.2278 ] tegraparser --boardconfig board_config_p3448.xml --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.2303 ]
[ 0.2304 ] Updating Odmdata
[ 0.2334 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 0.2348 ] Warning: No sdram params
[ 0.2352 ]
[ 0.2353 ] Get Signed section of bct
[ 0.2366 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.2384 ]
[ 0.2384 ] Signing BCT
[ 0.2424 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.2433 ] Assuming zero filled SBK key
[ 0.2439 ]
[ 0.2439 ] Updating BCT with signature
[ 0.2450 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.2464 ]
[ 0.2464 ] Copying signatures
[ 0.2494 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.2660 ]
[ 0.2661 ] Updating BFS information on BCT
[ 0.2682 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.2699 ] BFS:
[ 0.2715 ] 0: [PT ] crc-flash.xml.bin (size=131072/131072)
[ 0.2727 ] 1: [TBC] nvtboot_cpu.bin.encrypt (size=80672/196608)
[ 0.2734 ] 2: [RP1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.2748 ] 3: [EBT] cboot.bin.encrypt (size=485952/655360)
[ 0.2757 ] 4: [WB0] warmboot.bin.encrypt (size=3952/131072)
[ 0.2762 ] 5: [BPF] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 0.2766 ] BFS0: 131072 @ 2560 SUM f496a615 over 2883584 bytes
[ 0.2769 ] BFS:
[ 0.2769 ] 0: [PT-1] crc-flash.xml.bin (size=131072/131072)
[ 0.2772 ] 1: [TBC-1] nvtboot_cpu.bin.encrypt (size=80672/196608)
[ 0.2775 ] 2: [RP1-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.2780 ] 3: [EBT-1] cboot.bin.encrypt (size=485952/655360)
[ 0.2782 ] 4: [WB0-1] warmboot.bin.encrypt (size=3952/131072)
[ 0.2786 ] 5: [BPF-1] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 0.2789 ] 8: [VER_b] emmc_bootblob_ver.txt (size=101/32768)
[ 0.2792 ] 9: [VER] emmc_bootblob_ver.txt (size=101/32768)
[ 0.2794 ] BFS1: 131072 @ 8704 SUM f496a615 over 2981888 bytes
[ 0.2804 ] KFS:
[ 0.3138 ] 0: [DTB] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.3143 ] 1: [TOS] tos-mon-only.img.encrypt (size=54208/6291456)
[ 0.3146 ] 2: [EKS] eks.img (size=1028/81920)
[ 0.3149 ] 3: [LNX] boot.img.encrypt (size=667648/67092480)
[ 0.3157 ] KFS0: 1048576 @ 29376546 SUM c97b90a6 over 8089600 bytes
[ 0.3233 ] KFS:
[ 0.3542 ] 0: [DTB-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[ 0.3553 ] 1: [TOS-1] tos-mon-only.img.encrypt (size=54208/6291456)
[ 0.3564 ] 2: [EKS-1] eks.img (size=1028/81920)
[ 0.3570 ] 3: [LNX-1] boot.img.encrypt (size=667648/67092480)
[ 0.3576 ] KFS1: 1048576 @ 29522082 SUM c97b90a6 over 8089600 bytes
[ 0.3607 ]
[ 0.3608 ] Boot Rom communication
[ 0.3645 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.3658 ] RCM version 0X210001
[ 0.7245 ] Boot Rom communication completed
[ 1.7510 ]
[ 1.7510 ] Sending BCTs
[ 1.7523 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 1.7532 ] Applet version 00.01.0000
[ 2.0256 ] Sending bct
[ 2.0257 ] [................................................] 100%
[ 2.2514 ]
[ 2.2538 ] tegrahost --chip 0x21 --align cboot.bin
[ 2.2554 ]
[ 2.2589 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 2.2616 ]
[ 2.2634 ] tegrasign --key None --list cboot.bin_list.xml
[ 2.2648 ] Assuming zero filled SBK key
[ 2.2767 ]
[ 2.2796 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 2.2840 ]
[ 2.2880 ] tegrahost --chip 0x21 --align tegra210-p3448-0002-p3449-0000-b00.dtb
[ 2.2909 ]
[ 2.2938 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0002-p3449-0000-b00.dtb tegra210-p3448-0002-p3449-0000-b00.dtb_blheader
[ 2.2966 ]
[ 2.2999 ] tegrasign --key None --list tegra210-p3448-0002-p3449-0000-b00.dtb_list.xml
[ 2.3011 ] Assuming zero filled SBK key
[ 2.3075 ]
[ 2.3095 ] tegrahost --updatesigheader tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.hash zerosbk
[ 2.3140 ]
[ 2.3144 ] Sending bootloader and pre-requisite binaries
[ 2.3170 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt 0
[ 2.3192 ] Applet version 00.01.0000
[ 2.4556 ] Sending ebt
[ 2.4557 ] [................................................] 100%
[ 2.6321 ] Sending rp1
[ 2.6578 ] [................................................] 100%
[ 2.7855 ]
[ 2.7893 ] tegrarcm --boot recovery
[ 2.7905 ] Applet version 00.01.0000
[ 2.9788 ]
[ 2.9789 ] Retrieving storage infomation
[ 2.9822 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 2.9836 ] Applet is not running on device. Continue with Bootloader
[ 3.6230 ]
[ 3.6275 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 3.6289 ] Cboot version 00.01.0000
[ 3.7719 ] Saved platform info in storage_info.bin
[ 3.8390 ]
[ 3.8391 ] Flashing the device
[ 3.8424 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 3.8448 ] Cboot version 00.01.0000
[ 4.0121 ] Writing partition GPT with gpt.bin
[ 4.0125 ] [................................................] 100%
[ 4.0505 ] Writing partition PT with crc-flash.xml.bin
[ 4.8543 ] [................................................] 100%
[ 4.9044 ] Writing partition PT-1 with crc-flash.xml.bin
[ 4.9368 ] [................................................] 100%
[ 4.9989 ] Writing partition NVC with nvtboot.bin.encrypt
[ 5.0598 ] [................................................] 100%
[ 5.1231 ] Writing partition TBC with nvtboot_cpu.bin.encrypt
[ 5.1743 ] [................................................] 100%
[ 5.2308 ] Writing partition RP1 with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 5.2991 ] [................................................] 100%
[ 5.3740 ] Writing partition EBT with cboot.bin.encrypt
[ 5.4455 ] [................................................] 100%
[ 5.5521 ] Writing partition WB0 with warmboot.bin.encrypt
[ 5.6264 ] [................................................] 100%
[ 5.6747 ] Writing partition BPF with sc7entry-firmware.bin.encrypt
[ 5.7425 ] [................................................] 100%
[ 5.7912 ] Writing partition NVC-1 with nvtboot.bin.encrypt
[ 5.8595 ] [................................................] 100%
[ 5.9260 ] Writing partition TBC-1 with nvtboot_cpu.bin.encrypt
[ 6.0065 ] [................................................] 100%
[ 6.0621 ] Writing partition RP1-1 with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 6.1425 ] [................................................] 100%
[ 6.2139 ] Writing partition EBT-1 with cboot.bin.encrypt
[ 6.2964 ] [................................................] 100%
[ 6.4010 ] Writing partition WB0-1 with warmboot.bin.encrypt
[ 6.4889 ] [................................................] 100%
[ 6.5367 ] Writing partition BPF-1 with sc7entry-firmware.bin.encrypt
[ 6.6171 ] [................................................] 100%
[ 6.6642 ] Writing partition VER_b with emmc_bootblob_ver.txt
[ 6.7454 ] [................................................] 100%
[ 6.7919 ] Writing partition VER with emmc_bootblob_ver.txt
[ 6.8634 ] [................................................] 100%
[ 6.9140 ] Writing partition APP with system.img
[ 6.9842 ] [................................................] 100%
[ 866.3666 ] Writing partition DTB with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 867.7537 ] [................................................] 100%
[ 867.8238 ] Writing partition TOS with tos-mon-only.img.encrypt
[ 867.8844 ] [................................................] 100%
[ 867.9302 ] Warning: EKS partition magic header mismatch!
[ 867.9878 ] Writing partition EKS with eks.img
[ 867.9879 ] [................................................] 100%
[ 868.0305 ] Writing partition LNX with boot.img.encrypt
[ 868.0833 ] [................................................] 100%
[ 868.2054 ] Writing partition DTB-1 with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 868.2689 ] [................................................] 100%
[ 868.3366 ] Writing partition TOS-1 with tos-mon-only.img.encrypt
[ 868.3958 ] [................................................] 100%
[ 868.4453 ] Writing partition EKS-1 with eks.img
[ 868.5011 ] [................................................] 100%
[ 868.5406 ] Writing partition LNX-1 with boot.img.encrypt
[ 868.5975 ] [................................................] 100%
[ 868.7196 ] Writing partition BMP with bmp.blob
[ 868.7903 ] [................................................] 100%
[ 868.8491 ] Writing partition RP4 with rp4.blob
[ 868.9077 ] [................................................] 100%
[ 869.0208 ]
[ 869.0345 ] tegradevflash --write BCT P3448_A00_lpddr4_204Mhz_P987.bct
[ 869.0367 ] Cboot version 00.01.0000
[ 869.1993 ] Writing partition BCT with P3448_A00_lpddr4_204Mhz_P987.bct
[ 869.1998 ] [................................................] 100%
[ 869.6494 ]
[ 869.6495 ] Flashing completed
[ 869.6497 ] Coldbooting the device
[ 869.6511 ] tegradevflash --reboot coldboot
[ 869.6524 ] Cboot version 00.01.0000
[ 869.8386 ]
One question here. Does your board use sdcard to boot or emmc to boot? Or you are not sure?
I am confident that nano used to use emmc to boot.It can boot normally untill I mistakely changed the EEPROM value.
What did you write in the xml file for flashing?
I only add this line.I did not make any other changes to 32.7.4.
caodingrui:
Then that is the problem here.
board_config_p3448.xml has the info of the module. You have to write the correct info in the xml.
sku=0 means the sdcard module.
sku=2 means the emmc module.
Previous flash and boot log tells that it is trying to boot a sku0 module. But it is obviously wrong.
I modified the board_config_p3448.xml .But it seems that after the command sudo FAB=400 BOARDID=3448 BOARDSKU=0002 ./flash.sh jetson-nano-emmc mmcblk0p1,the value comes to the original value.
